Old 07-15-2020, 03:00 AM   #85
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm, but $2.3K at japanparts, +shipping/import costs .. imho by such price good clutch type LSD looks better choice.
Old 07-15-2020, 07:46 AM   #86
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I would say the best reply was given here:
https://www.ft86club.com/forums/show...7&postcount=36
Old 07-15-2020, 03:05 PM   #87
gpvecchi
gpvecchi's Avatar
That is not completely correct: Torsen doesn't have a lock rate, as it's stucture goes from 0 to 99.9% (if both wheels completely loose traction it will work as an open diff).
GRMN LSD is declared to be a little more "open" on the first phase, to help entering the curve. So I think it has different gears on Torsen leverage, basically related to wider rear wheels of the GRMN.
Old 07-15-2020, 08:26 PM   #88
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Originally Posted by nikitopo View Post
This was a build to order factory part. Meaning that Toyota Japan took a standard 17+ differential (4.3 FD ratio) and opened it to change the Torsen with the improved one.
Other parts like the GRMN intake manifold are discontinued, so it is much harder to find them.
I know the parts are harder to get. I’m just wondering the real benefit vs cost ratio for the GR unit, which is still Torsen, when better performing clutch types can be had for less.
That’s my thinking. I could get a 17+ OEM 4.3 FD or even a TRD 4.56 FD paired to a OS Giken diff for the same or less. I get the appeal for somebody who may want an OEM solution that’s just a bit better than standard (like OEM+ type of thing), but I have to wonder how noticeable the differences actually are in the real world.
This was my understanding of the GRMN unit too. Between the brakes, fender vents, intake manifold, seats, and so on... I’d try to source any of those before the diff, personally lol
Old 07-16-2020, 01:51 AM   #89
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It looks that you don't understand the details of how a Torsen differential work. Torsen has a torque bias ratio (TBR) and in the normal case it is a 4:1 rate. This is also called its lock rate, but the better terminology is TBR. So, the diff in the GRMN 86 has a higher TBR. It is close to a 6:1 rate.
You can find more information here: https://torsen.com/ask-torsen-torque...nal-questions/
I am not trying to build a GRMN 86 replica. I wanted to solve a specific problem I had, caused by bad road pavement conditions. I found that the best option would be to use the specific diff and it works perfectly. Someone might say that an OS Giken diff or other clutch plate would be better, but everyone can have its opinion here. What I can say for sure is that GRMN spent a lot of R&D to build the specific diff and yes it makes a difference. Another thing to know is that Torsen (JTEKT Corporation) is actually owned by Toyota, so they know what they are doing.
Old 07-16-2020, 09:09 AM   #90
gpvecchi
gpvecchi's Avatar
This is what I said, you were talking of lock rate not torque bias ratio, that's a completely different thing...
Old 07-16-2020, 12:54 PM   #91
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It looks that you still don't understand, but you are not the first nor the last. GRMN 86 differential has nothing to do with the wider wheels or about being more "open" like you said.
Old 07-16-2020, 02:59 PM   #92
TylerLieberman
Drives: '24 GR86
I’m not saying you’re building a replica; I was just saying that I would personally be more interested in some of the other items compared to the diff, because of reasons stated earlier.
But as you mentioned, the GRMN unit works best for you and the specific problem you had. That’s fine. If it works, it works.
The Following User Says Thank You to TylerLieberman For This Useful Post:
daviddgaf21 (07-25-2020)
Old 08-04-2020, 06:59 AM   #93
Snake
Drives: ADM Toyota 86 GT
Originally Posted by ck20090418 View Post
My grmn build, bonnet next
Jesus, how much was the manifold?
Sent from my CPH1979 using Tapatalk
Snake is offline   Reply With Quote
Old 08-04-2020, 07:07 AM   #94
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Nice!
Old 08-04-2020, 09:41 AM   #95
ck20090418
Drives: gt86
Just a little bit extra compare to the red aluminium manifold
But Some work need to be done to make it run correctly
Otherwise aftermarket ecu can bypass some sensor to activate the throttle plate inside to switch the long runner or short runner
ck20090418 is offline   Reply With Quote
Old 08-04-2020, 12:34 PM   #96
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Short length runners are for high rpm power and long length runners for mid rpm torque. This is a high quality factory spec'd intake manifold for getting a wider torque curve from this engine .
Old 08-04-2020, 11:27 PM   #97
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Awww where did the post go for the cool manifold??
MS, CSCS, TSAC-F, CPT
Old 08-04-2020, 11:35 PM   #98
ck20090418
Drives: gt86
it use a vacuum hose connect to the airbox and a vacuum pump to open up the throttle plate for stock setup.
still figure it out a how to run it properly if i use motec ecu
frs, grmn, gt86, st-autosport, toyota
GRMN 86 unveiled nikitopo Scion FR-S / Toyota 86 GT86 General Forum 103 07-22-2020 03:38 AM
What kind of wheels are these on the GRMN 86 Prototype? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 12-10-2018 08:23 AM
New article on the GRMN 86 (Tuned race ready spec) Wise Scion FR-S / Toyota 86 GT86 General Forum 15 02-16-2015 10:13 PM
GRMN SPORTS FR Concept PLATINUM PREDATOR786 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 12 01-21-2013 10:47 PM
GRMN 70NYD Scion FR-S / Toyota 86 GT86 General Forum 17 01-23-2011 03:29 AM
