Old 07-14-2020, 01:45 PM   #1
Inter
Inter's Avatar
Tail lights not working, brake lights and turn signals are working
Hey guys I noticed last night that my night time running lights on my Valenti tails stopped working.. what I thought was just the tail-light crapping out turned to lead me down a rabbit hole I know nothing of. Here's the story:
At the same time my DRLs on my Spec-d headlights stopped working as well. So this morning I took out the Valenti's, put the stocks on.. still nothing. They both didn't work, same thing, brake lights and turn signals work fine. So next I checked the fuses, the fuse 4 on the inside panel was blown. 5 for the DRLs was not blown which I found strange since the DRL doesn't work either. So I drove my angry ass to auto-zone, bought more 10a fuses and changed them. But...fuse 4 blew again.. and again.. and again. Every time I changed it to a new one, tried to turn the lights on it blew instantly, I even tried putting the stock tails back on .. still blew. I know very little about wiring and I'm so stumped. I checked my wiring from the Spec-d headlights and made sure no exposed wiring was fouling and touching any metal in the engine bay.. nothing wrong there. I unplugged the main headlight harness from the car and reset the battery, still to no avail. I really want to avoid taking it to the shop... my only thought is that theres a really huge chance theres a bad ground, so maybe if someone knows a point where the ground can fail often that would be awesome. Any suggestions or help would be super appreciated.
UPDATE : Checked trunk dome lighting for any bad wires, nothing out of order there.. Removed license plate lights and put a new fuse in, tried again, still blew the fuse.
Inter is offline   Reply With Quote
The Following User Says Thank You to Inter For This Useful Post:
humfrz (07-14-2020)
Old 07-14-2020, 04:23 PM   #2
Well now, Inter, it's quite obvious that your car has an electrical short somewhere in the system. I would start looking at or around those lighting fixtures that you have been messing with. You may find an electrical diagram (found somewhere on this forum) helpful.
What Bubba does is to jump across the fuse block that keeps blowing with a piece of #9 wire, then look around the car for sparks and or burning wire. NO, DON'T DO THAT!
Old 07-14-2020, 10:32 PM   #3
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
Narrow down the short. Unplug the headlights and taillights, replace the fuse, then plug them in one by one until it blows. That will tell you which headlight/taillight to look at specifically.
If you unplug them all, and it still blows, then you've got an issue with the car wiring.
sharpsicle is offline   Reply With Quote
The Following 2 Users Say Thank You to sharpsicle For This Useful Post:
humfrz (07-14-2020), soundman98 (07-15-2020)
Old 07-14-2020, 11:31 PM   #4
Inter
Inter's Avatar
Yeah I've been fiddling with them and trying different things all day... Had to have gone through at least 20 fuses...
humfrz (07-15-2020)
Old 07-14-2020, 11:32 PM   #5
Inter
Inter's Avatar
I don't remember if I unplugged all 4 headlights and tail lights and then tried it, that's something I'll have to redo tomorrow..
humfrz (07-15-2020)
Old 10-19-2021, 02:28 AM   #6
Romansssee
Drives: Black Frs
Were you able to fix them? I’m currently having the same freakin problem, so anything you found out would help a lot
Romansssee is offline   Reply With Quote
Old 10-19-2021, 05:24 AM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
The next step is to start unplugging harnesses. There's a short somewhere, just need to narrow down if it's in front or back.
Always start with the parts that have been modded or fiddled with, then move on to unplugging car harnesses
Old 10-19-2021, 01:31 PM   #8
He hasn’t been here for a year so maybe he burned his car up by just throwing fuses at it.
As has been said if you blow a fuse it means in all probability you have a dead short someplace. They can be a bitch to find. If you recently changed or worked on something start there and look for pinched or cut wires. The hard part is it can be anywhere in the length of the car!
Old 10-22-2021, 12:54 PM   #9
Romansssee
Drives: Black Frs
Thank you bro, appreciate your help
Old 06-09-2022, 02:25 PM   #10
amaryeg
Drives: Black 2013 Scion FR-S
you fix ur tail lights???
amaryeg is offline   Reply With Quote
Old 09-15-2022, 02:50 AM   #11
SeriesB
Drives: 2015 Subaru BRZ Series.Blue Edition
* My solution *
My problem was the sidemarker wires were all screwed up and the positive and negative cables were wrapped around each other. I had them disconnected because I have widebody fenders. Now it works perfectly fine.
SeriesB is offline   Reply With Quote
Tail lights turn signal interfering with Valenti 4th Brake Light johnowow Cosmetic Modification (Interior/Exterior/Lighting) 8 06-16-2020 06:07 PM
Help! boomerang, sidemarkers, tail lights not working! thunderlights Cosmetic Modification (Interior/Exterior/Lighting) 5 01-08-2020 02:27 AM
Valenti Tail Lights - Running Lights not working at all Antstronaut Cosmetic Modification (Interior/Exterior/Lighting) 12 08-10-2017 08:11 AM
2015 OEM Headlights, turn signals, side markers, reverse light, & Valenti tail lights Vinsanity091 Exterior Parts (Aero, Lighting, Etc.) 4 06-11-2017 06:56 PM
My front turn signal lights not working after shop installed LED DRL bezel speedy racer Cosmetic Modification (Interior/Exterior/Lighting) 6 10-11-2013 06:08 PM
