Old 07-04-2020, 03:04 AM   #9003
Setgo
Setgo's Avatar
Drives: '13 Subaru BRZ Crystal Black Silica
Originally Posted by ThucP View Post
which belt would you guys recommend? the kit comes with stock 75mm pulley and a 72.5mm raceseng pulley, I will be using the 72.5mm pulley
I'd consider the same belt. The belt that comes with the kit max's the tensioner anyways. A -2.5mm diameter, i would assume, would still be reasonable to use the same belt.
IG: setgo.moto
Setgo is offline   Reply With Quote
Old 07-04-2020, 01:56 PM   #9004
ThucP
Sorry I meant I want to replace the belt because it's a used kit, where would I find the belt?
ThucP is offline   Reply With Quote
Old 07-04-2020, 02:00 PM   #9005
jflogerzi
jflogerzi's Avatar
Look a several posts back. I link the exact belt and idler pulley I use. No issues with 72.5 and 69mm
2013 Series 10 FRS #553
Old 07-04-2020, 03:59 PM   #9006
86TOYO2k17
Drives: 2017 toyota 86
K061015 Is the belt that comes with it, 75mm to 72.5mm is only about a 1.25mm drop in needed belt length which unfortunately the next size down K061010 is 12mm shorter. The factory tensioner has room to pickup the slack. So the K061015 should work fine.
Alternatively you can get a larger diameter supercharger idler pulley and fit a belt accordingly
I posted this one about a year ago on here - Dorman 419-610 It is same bearing width/diameter but it is 76mm diameter instead of 70mm so more belt wrap on SC pulley, and 31mm width instead of 27mm so less chance of belt slipping off but requires about 3mm longer belt with 75mm sc pulley, i used it for a year no issues before switching to below.
I posted this one more recently been using about a month now Dorman 419-606 same bearing width/diameter but it is 82.5mm diameter and 30.5mm width so requires about 6.5mm longer belt with 75mm sc pulley.
K061015 paired with 72.5mm sc pulley and 76mm idler would be a hair tighter than before approximately 1.75mm tighter
K061016 Is 3mm longer paired With 72.5mm sc pulley and 76mm idler pulley it would be a hair looser then before approximately 1.25mm looser
Or with the 82.5mm idler would be approximately 2mm tighter
K061020 Is 12mm longer paired with the 72.5mm sc pulley and 82.5mm Idler pulley it would be a tad looser then before approximately 7mm looser
You want tensioner pulley at about 70-80% of its max Travel/tension so as belt stretches it has plenty of travel to pickup the slack, so you can decide based on current setup if slightly looser or tighter is better, and by how much you can deviate + or -
If you ever switch to the 69mm pulley the 82.5mm idler and k061016 should be a perfect pairing almost identical to original tension only about .5mm tighter.
The Following 3 Users Say Thank You to 86TOYO2k17 For This Useful Post:
BlankHugs (07-04-2020), kev0 (07-04-2020), Setgo (07-04-2020)
Old 07-11-2020, 06:10 PM   #9007
kev0
Drives: '14
Does anyone know at what IAT temp does the ECU pull timing? Afaik, the IAT's aren't accurate with this kit and my IAT's are sometimes sporadic. One day, it would go up to as high as 158-165f and other days it would be about 125F.
kev0 is offline   Reply With Quote
Old 07-11-2020, 06:14 PM   #9008
86TOYO2k17
Probably depends on how your tuner set it up. And if you relocated it to post blower or still using stock position. If you didn’t relocate your IAT sensor, those are really high.
If i am moving my IAT at stock location is at or below ambient. If I’m sitting idling it creeps up maybe to 120s if i sit long enough. Once moving it goes back down pretty quickly.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
kev0 (07-11-2020)
Old 07-11-2020, 06:21 PM   #9009
kev0
Drives: '14
Ah, gotcha. Forgot to say, my intake pulls in warm air from the engine bay since I'm using Xero-Limit's intake. That definitely makes my IAT's higher I guess.
Old 07-11-2020, 06:22 PM   #9010
jflogerzi
jflogerzi's Avatar
You should really think about going back to the stock airbox and Cai.
Old 07-11-2020, 06:35 PM   #9011
86TOYO2k17
If you have E85 i don’t think IATs are as big if a concern.
Because IAT sensor is in MAF pre blower i don’t think most tuners tune use the IAT sensor for tuning. If you relocated to post blower they could probably safely get a little more out of your setup when IAT temps where really low and detune if it got really high and have it adjust accordingly between instead of a general “blanket” tune. But you’ll probably be in the IAT temps that the “blanket” tune is at already in most conditions regardless so it really wouldn’t be much different. And again with E85 it’s less of a concern.
Also I am pretty sure the hotter air pre blower would mean less dense air going into the blower and thus less boost coming out post blower so pre blower IAT temps is already being “adjusted” for naturally because of that. IE at 100 degrees IAT you have say 12psi vs 150 degree IAT 11.5psi so timing and fuel wouldn’t need adjusting to accommodate the added heat if that makes sense.
kev0 (07-11-2020)
Old 07-29-2020, 10:09 AM   #9012
LOJOKO
LOJOKO's Avatar
Drives: Subaru BRZ 2013 6AT& Honda Odyssey
I run a oil catch for a month. The good news is that There's less oil leaking out.
The bad news is that A code P0108. Check no vacuum leakage. I bought a new map yesterday BOSCH 0261230283...Hope everything goes back to normal...
2013 Subaru BRZ 6AT; Rays 57XTREME STD SPEC 18' 9.5J Wheels; TEIN FLEX Z Coilovers; Brembo OE Gold Front Brake Kit(STI); Sprintex 210 SC;GReddy GT ver.2 Exhaust; CUSCO strut bar F/R...
LOJOKO is offline   Reply With Quote
Old 07-30-2020, 11:22 AM   #9013
LOJOKO
LOJOKO's Avatar
LOL I think I made a mistake about the MAP sensor mentioned in the CUSCO SC Japanese manual(sprintex in Japan),It is 4pins and bigger. I even bought it without comparing. LOL Now I have a maximum pressure of 0.7bar about 10.15psi, This seems normal. I just cleared my CEL and it hasn't show up right away. Hope everything will be fine.[IMG][/IMG]
Old 07-30-2020, 06:35 PM   #9014
Kodename47
Kodename47's Avatar
Drives: UK GT86
It's not ideal running a wider range sensor. You'll need to adjust the tune to get the MAP correct, but also it make it run worse at WOT. You'll need some custom mapping or move the sensor out of the runners. Best bet is to put an OEM sensor back on.
.: Stealth 86 :.
Kodename 47 DJ:
LOJOKO (07-31-2020)
Old 07-31-2020, 01:03 PM   #9015
LOJOKO
LOJOKO's Avatar
I've been using OEM sensors for years. I didn’t understand this during that time. (Learning slowly)
I bought a 2.5-bar sensor a few days ago when I found that it was OEM, but I may not need it now. Thanks to 86TOYO2k17, I asked him in Messages. As you said, OEM sensor with the correct MAF&MAP tune may be the best choice.
Old 08-04-2020, 01:36 AM   #9016
frostyfrs
Drives: Supercharged 2013 Scion FR-S
I just bought my frs a few weeks back and the owner had one of these installed, I will say, it is very fun
frostyfrs is offline   Reply With Quote
The Following User Says Thank You to frostyfrs For This Useful Post:
86TOYO2k17 (08-26-2020)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
