Old 07-09-2020, 01:31 PM   #22107
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
Originally Posted by WNDSRFR View Post
I'd love to do that. But the 5,000 mile commute makes it impractical.
Well, you're only a little over 500 miles from Dahlonega Ga. and all the great roads in that neck of the woods! (But you've probably already done them, eh?)
Old 07-10-2020, 02:34 PM   #22108
Chamaco
Drives: Silver FR-S
Got my RPF1's mounted! She's dirty though...
Edti: don't know why the pictures are upside down. any suggestion?
Chamaco is offline   Reply With Quote
Old 07-10-2020, 02:37 PM   #22109
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Are you south of the equator? That's explains it. Do you toilets flush clockwise as well?
MJones_RB is offline   Reply With Quote
Old 07-10-2020, 02:47 PM   #22110
Chamaco
Drives: Silver FR-S
HAHAHAH nop. I'm in the Caribbean. Maybe my computer thinks it's at the south of the ecuator?
Old 07-10-2020, 03:54 PM   #22111
thedollarbill
Drives: 13 ZN6
TRD Carbon Fiber Fins!!!!! The stability on the highway is insane /s
thedollarbill is offline   Reply With Quote
Old 07-10-2020, 11:04 PM   #22112
soundman98
ProCrastinationConsultant
soundman98's Avatar
One of the tricks we used to use, when the sub boxes got too "boomy," was to fill the box with polyfill. It helped keep the bass tone deep without overpowering the rest of the signal, especially in cars with small cabins like ours.
fiberglass insulation is generally better, with some obvious physical differences that can be significant negatives.
i can't find the charts anymore, but there were a few studies in audio forums about it.
the entire concept of insulation in an audio sense is that it coverts movement into low level heat. by doing so, it slows air movement within the space, which is the fundamental part of how insulation makes a small box sound bigger.
fiberglass is a better conversion medium, but it's itchy to handle, and not great to breathe. polyfil is supposed to be a synthetic, healthier, and easier to work with medium that performs the same task. but because it doesn't convert the same, it's main advantage is for ported enclosures so you don't have to be breathing fiberglass strands.
Originally Posted by JonnyObnoxious View Post
I was considering some polyfill, but I think my real issue is a 300 watt max sub running on a 500w channel. I think a smaller amp is in order.
Also a smaller box as I now can just barely bring groceries home. I'd like a custom one that tucks into the passenger rear corner without protruding. Like the MTX thunderform that's discontinued. But I'm not ready to spend money on that yet.
Sent from my SM-N975U using Tapatalk
don't look at max wattage. companies lie. compare rms wattage. it's a little harder to lie about, and provides more equal footing. i suspect that it's not as far off as you're thinking.
the only 2 custom-formed boxes i'm aware of anymore are the jl audio stealthbox, and the oem+ subwoofer--which doesn't come separately from the very expensive package...
Old 07-11-2020, 12:25 AM   #22113
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
What the hell? Where in Canadia did you get those?
Old 07-11-2020, 03:10 AM   #22114
jeffs42885
Drives:
Wheee did you get these!!!
jeffs42885 is offline   Reply With Quote
Old 07-11-2020, 03:11 AM   #22115
jeffs42885
Drives:
Blacked out emblems; cleaned the exhaust tips real good, third brake light.
Old 07-11-2020, 07:23 PM   #22116
Originally Posted by jeffs42885 View Post
Blacked out emblems; cleaned the exhaust tips real good, third brake light. lk
You didn't clean the inside of the tips very good -
(jest ah messen wich ya - your car is looking good - )
Old 07-11-2020, 08:09 PM   #22117
jflogerzi
jflogerzi's Avatar
Super clean looks good!
2013 Series 10 FRS #553
Old 07-11-2020, 10:06 PM   #22118
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
Did you install this yourself? My fender fin garnish is fading. Auto body paint shop quoted me $500 to repaint only one side! Where did you order those from?
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 07-11-2020, 11:10 PM   #22119
Ashikabi
Ashikabi's Avatar
You need to find a new body shop
Sent from my ONEPLUS A5010 using Tapatalk
Old 07-12-2020, 02:41 AM   #22120
thedollarbill
Drives: 13 ZN6
Re:all - a seller (from Florida) on the 86 marketplace group on FB somehow had them sitting in his closet for three years... the zip ties, adhesive coverings were all intact. Basically BNIB. It was the craziest find I've come across in a long time. I think the seller was collecting JDM parts for his own build but life got in the way.
Re: 86geek - your OEM garnishes? For 500 bucks you are better off ordering TRD Paintmatched Garnishes for about 300-400 landed from importers. If you are C7P (FRS with 86 piston badge) if you pay for shipping I'll ship you mine in mint condition for free.
