Old 06-30-2020, 02:00 AM   #155
pinoy_dorifto
Tuloy po kayo!
Drives: 2019 Toyota 86 TRD SE
It will fit, you just can't run camber bolts. If you want to run camber bolts, you'll need some spacers. If you don't want spacers and want camber, you'll need to run camber plates.
Originally Posted by Buteo View Post
Will the 17x9 et42 wrapped in gt radial sx2 245/40/17 have any issues with fitment on a brz pp car? I saw your website says spacers may be needed but was curious if anyone has done this combo exactly.
Thanks
Tyler
I.G. @mytoy86
pinoy_dorifto is offline   Reply With Quote
The Following User Says Thank You to pinoy_dorifto For This Useful Post:
Pat (06-30-2020)
Old 06-30-2020, 03:29 PM   #156
APEX Race Parts
FT86Club Official Vendor
APEX Race Parts's Avatar
Drives: Launch-Year Whiteout FR-S
Originally Posted by timurrrr View Post
Aaaah, wheel porn! Nice concavity.
What are the dimensions, offset? Weight? I presume they clear PP Brembos?
Spoke concavity came up a lot in our conversations with the community, so we worked hard to deliver on that initiative while maintaining brake clearance. All APEX wheels for these chassis are engineered specifically to clear the PP/TRD Brembo BBK
Full release coming soon!
- Ryan
APEX Race Parts is offline   Reply With Quote
The Following User Says Thank You to APEX Race Parts For This Useful Post:
timurrrr (06-30-2020)
Old 06-30-2020, 04:35 PM   #157
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Found this on https://www.apexraceparts.com/wheels...-wheels/ec-7r/
The Following 2 Users Say Thank You to timurrrr For This Useful Post:
APEX Race Parts (11-23-2020), DarkPira7e (06-30-2020)
Old 07-07-2020, 12:45 PM   #158
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Just a PSA, but the 17x9 ARC-8's w/ 255/40/17 Hankook RS4's absolutely rubs the inner fender liner at less than full turn lock @ 3.0 degrees of camber and around 6 degrees of caster. I was able to lessen it with 3 mm spacers, but there is still a bit of rubbing occurring.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 07-07-2020, 01:17 PM   #159
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by Goingnowherefast View Post
... absolutely rubs the inner fender liner ...
Can you post a picture of the exact area, just so others know what to look for?
Old 07-07-2020, 01:22 PM   #160
Goingnowherefast
Yeah, I'll edit this post with pictures. Not sure how this hasn't been commented on yet, because I feel like there's a lot of people running 255's.
Old 07-07-2020, 07:57 PM   #161
APEX Race Parts
Results with 255's (which are approx. 25" tall) can vary from car to car due to the number of contributing factors like vehicle ride height, spring rate, tire model (not all are created equal), alignment settings, wheel offset, and even things like worn bushings which can cause deflection and movement.
The circumstances in which scrubbing can occur can also vary from car to car. Sometimes it only occurs under suspension compression, or under heaving braking zones, or at major steering angle... and sometimes it is a combination of more than one of these.
Adjustments to alignment, ride height, spring rate, compression and rebound settings (aftermarket coilovers), and tire model can change the outcome, but at the end of the day minor scrubbing of the plastic liners is not a barrier or deterrent for most track enthusiasts and racers looking to improve lap times. I have small divot marks in the front plastic liners on my E92 M3 race car from the wide wheel and tire configuration I'm running, but no real harm or damage comes from it "self-clearancing". With that said, some cars have sensitive components like oil coolers located behind the liners, so it's certainly something to pay attention to.
245/40-17 (approx. 24.6" tall) would be the safer bet for enthusiasts sensitive to scrubbing the liners, as this shorter tire size mirrors the stock rolling diameter.
- Ryan
Old 07-08-2020, 12:39 AM   #162
Goingnowherefast
Yeah not the end of the world, just didn't get too much heads up. Here's where it is rubbing. It has actually burned away the paint and left bare metal in the wheel well. Unfortunately, I didn't take a picture of the bare metal before I touched it up so it doesn't rust. For those running spacers, how much did it take to make clearance? 3mm isn't cutting it.
Old 07-08-2020, 12:53 AM   #163
APEX Race Parts
Thanks for following up with the photo.
While many are able to stuff the 17x9" ET42 & 255/40-17 setup on the car without the same type of rubbing, our new line of EC-7R forged wheels will offer 9" ET35 wheels (in both 17" & 18" diameters) which will result in 7mm of additional inner clearance. Of course there is always a trade-off - additional negative camber will be required for outer fender edge clearance.
- Ryan
Old 07-10-2020, 04:00 AM   #164
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I've created a new thread to discuss APEX EC-7R here: https://www.ft86club.com/forums/show....php?p=3347985
We can keep this thread focused on ARC-8 going forward.
Old 07-10-2020, 04:03 AM   #165
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I have the exact same rubbing with 17x9 +37 wheels wrapped into 245/40R17 GT Radial SX2 and -3º of camber.
I don't think even 6mm spacer would be enough for +42 wheels with 255 tires. Just don't turn your wheel that much?
Old 07-15-2020, 09:53 PM   #166
APEX Race Parts
SUBARU BRZ tS TRACK CAR | FEATURING APEX 17” ARC-8 WHEELS
This insanely clean BRZ tS has exchanged caretakers since we photographed it, but it remains one of our favorites to date. As you can see from the laundry list of aftermarket parts below, the original owner, James, was not gun-shy about modifying the car. With that said, it is evident that parts were carefully selected to improve performance on and off the race track, and aesthetic modifications were carried out with an overarching theme in mind.
It is quite easy for passionate enthusiasts to get a bit overzealous with modifications, and that often times leads to a "Frankenstein build" where parts have a hard time working cohesively with each other - both from a performance and visual perspective. When that happens the car looses a bit of its identity along the way.
James really knocked it out of the park with this build, and we look forward to seeing how the new owner will carry the torch. We hope you enjoy the photos as much as we did.
MODIFICATIONS & SPECS
Wheels/Tires:
APEX 17x9” ET42 ARC-8 Wheels in Satin Black
Hankook RS4 245/40-17
Power/Cooling:
Jackson Racing Supercharger (C30)
Jackson Racing Oil Cooler
PTuning FlexFuel Kit
PTuning Tune
PTuning Race Header
Perrin Overpipe
JDL UQFP
Perrin 2.5in Resonated CBE
Deatschwerks 700cc Injectors
Radium PCV Catch Can
Forge BPV
Jackson Racing 4 Bar Map Sensor
Koyo Radiator
Perrin Engine Mounts
Aero:
Verus Non-Aggressive Rear Diffuser
Verus Hood Vents
BRZ tS Carbon Wing
BRZ STI Lip Kit (Front Lip, Side Skirts, Rear Spats)
Transmission:
Southbend Clutch – Stage 2 Endurance
Southbend Cluth Flywheel
Verus Gear Fork/Pivot
JDM STI Transmission Mount
Suspension:
Fortune 510 Coilovers w/ Swift Springs
STI Flexible Strut Bar
Verus Adjustable LCAs
Whiteline Front Sway Bar
Whiteline Front Sway Bar Bushings
Whiteline Adjustable Front Endlinks
Whiteline Steering Rack Bushings
PTuning Custom Alignment
Fluids:
Motul 300V 5W-30 (02/2020)
Motul RBF660 (02/2020)
Motul Gear 300 – Differential and Transmission (02/2020)
Motul 5.1 Brake Fluid for Clutch (02/2020)
Brakes:
Project Mu Racing 999 Brake Pads
Exterior:
JDM Clear Sidemarkers
Premium Auto Styling Vinyl Badge Overlays
Premium Auto Styling Taillight Tint
35% Tint
STI JDM Fender Garnish
PTuning Front Tow Hook
PTuning Rear Tow Hook
Paint Protection:
Xpel Ultimate Plus PPF – Hood, Front Bumper, Fenders, Side Mirrors
Xpel Fusion Plus/CeramicPro Ceramic Coating – Entire Car
Previous Owner / @Javellin.motorsports
Current Owner / @juanjayzee
Photography / @danielkiserphotography
The Following 2 Users Say Thank You to APEX Race Parts For This Useful Post:
cirros (08-17-2020), tom@ptuning (04-21-2021)
Old 11-23-2020, 04:33 PM   #167
burnt_toast
Drives: 2017 BRZ CWP
@APEX Race Parts
Hope you guys have been safe and well. Just wanted to see if there were any updates on the new Arc-8 fitments that were mentioned for Q4? Debating on waiting for those especially if the 17x9 +35 will come in Profile 2 or 3, or just pulling the trigger on the current +42 with the Black Friday deal you have going.
Thank you!
burnt_toast is offline   Reply With Quote
The Following User Says Thank You to burnt_toast For This Useful Post:
Pat (11-23-2020)
Old 12-03-2020, 06:13 PM   #168
APEX Race Parts
Originally Posted by burnt_toast View Post
@APEX Race Parts
Thank you!
My apologies for the late reply. COVID and other factors have kept our production team on their toes, but the good news is that we do have the new ARC-8 17x9" ET35 finally going into production this month. This means wheels will be ready to ship to customers prior to 2021 track season.
In regards to the spoke profile, it has to be a profile 1 like the current 17x9" ET42 in order to clear the PP Brembo brakes, etc. BBK clearance is a non-negotiable for us
For enthusiasts looking for a more concave spoke design, I would urge you to look at our new EC-7R forged wheel line. These wheels offer the best of both worlds, brake clearance and spoke concavity.
- Ryan
Pat (12-03-2020)
Wheel Directory: Volk Racing TE37 17x9.0 +36 03Z33 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 04-11-2018 02:58 AM
Wheel Directory: Volk Racing TE37 17x9.5 +40 B L U E S L A T E Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 06-04-2017 12:29 AM
Wheel Directory: Volk Racing CE28 17x9.0 +38 Dpark27 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 03-14-2015 08:34 PM
Wheel Directory: Volk Racing TE37 17x8.0 +36 / 17x9.0 +36 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 46 05-06-2014 01:19 AM
Wheel Directory: Volk Racing TE37 17x9.5 +40 / 18x10.0 +44 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 04-16-2013 08:28 PM
