Old 05-03-2020, 06:53 PM   #1905
AKITA
AKITA's Avatar
Drives: 2016 Scion FRS Halo
Perrin MAF scaling 2.75
I've been working on a MAF scaling since installing the Perrin CAI and tube using OFT /Romraider/Vimsh software. LTFT have gone from averaging -7 to just <+-1 as well as STFT averaging <+- 1 albeit seems to be a little leaner than LTFT. So I think data logging will show more as the ECU learns better, but I was curious what more trained eyes thought. The OL pull isn't exactly ideal starting a little high rpm and might have been in 4th gear but I think it reflects what's happening pretty well. Curious on thoughts, wasn't looking to change timing just yet but whether the MAF scaling is looking pretty good.
https://datazap.me/u/akita/0503204?l...zoom=4713-9384
https://datazap.me/u/akita/0503206?l...zoom=1655-1763
AKITA is offline   Reply With Quote
Old 05-15-2020, 09:54 AM   #1906
tomm.brz
Drives: brz 2017 hksv2
yes maf scaling is very good, good job
turn down a bit timings after 6400 and those random knocks triggering AM
AKITA (05-17-2020)
Old 05-24-2020, 02:15 AM   #1907
southside iraq
Drives: 2017 86
2015 brz
91 octane
SBD 500x 7psi
700cc DW
4th gear WOT
How does everything look, guys.
https://datazap.me/u/gillster91/91-w...?log=0&data=31
southside iraq is offline   Reply With Quote
Old 05-24-2020, 04:02 AM   #1908
tomm.brz
seems good, those heavy knock corrections at high lownlow rpm you d wanna reduce them a bit
southside iraq (05-24-2020)
Old 05-24-2020, 01:29 PM   #1909
southside iraq
Drives: 2017 86
I think that's from be going a WOT at low rpm at 91 octane gas?
Old 05-25-2020, 01:43 AM   #1910
tomm.brz
of course, but you might want to have it tamed down anyway somehow, those big correction down low at full gas seem like Low speed pre ignition and that is destructive over time
southside iraq (05-27-2020)
Old 05-27-2020, 03:42 AM   #1911
southside iraq
Drives: 2017 86
the knocking is due to lean not enough fuel on e73 ??,
2015 brz
91 octane
SBD 500x 7psi
700cc DW
4th gear WOT and partial
https://datazap.me/u/gillster91/log-...&zoom=881-1634
Old 05-27-2020, 04:30 AM   #1912
tomm.brz
Man, why you keep writing 91 octane, if you re E73 at the mom, i got super confused :P
you still have much DI headroom in that knock zone, reduce PI% and knock will ease
and/or make it richer, it seems to a bit too lean the target
Also DI seems a bit maxed out after 6000rpm, you may want to augment PI% at higher rpm specially if you get real E85 in your tank
Old 05-29-2020, 03:24 PM   #1913
southside iraq
Drives: 2017 86
2015 brz
e73
SBD 500x 7psi
700cc DW
https://datazap.me/u/gillster91/log-...16-25-26-31-36
Old 05-29-2020, 03:53 PM   #1914
tomm.brz
looks good
but you have to raise Port injection at high rpm
keep DI opening time under 6ms preferably lower so to have headroom when ambient air is cold
Ignition end of di to spark is too short, keep it higher than 2ms because if gets cold or you go e85, it starts misfiring around 1ms
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
solidONE (06-01-2020), southside iraq (06-02-2020)
Old 06-01-2020, 08:13 AM   #1915
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
https://datazap.me/u/solidone/z85cd?log=0&data=1-10
That increase IAT from oil cooler messing with fuel trims, but man this thing stays strong in the heat now. NO power fade with heatsoak via butt dyno. E85 log from earlier yesterday.
Intent > Content
The Following 2 Users Say Thank You to solidONE For This Useful Post:
AKITA (06-01-2020), tomm.brz (06-01-2020)
Old 06-02-2020, 03:48 PM   #1916
southside iraq
Drives: 2017 86
Hot day, on e78, hard to find full e85,
2015 brz, SBD 500x 7psi, 700cc DW
https://datazap.me/u/gillster91/log-...24?log=0&data=
Old 07-04-2020, 09:53 AM   #1917
randomthoughts
Drives: 2014 White BRZ
First Ecuteck Log
I made the switch from OFT to EcuTek. This is my first log using the Ecu Connect App.
I am running the SBD 400X with an ECBS.
Have I logged all the correct data points?
https://datazap.me/u/randomthoughts/...&data=14-23-24
randomthoughts is offline   Reply With Quote
Old 07-07-2020, 05:39 PM   #1918
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '18 440i GC, '24 CX-50 Meridian
Did some datalogging to try out VirtualDyno. Car feels really good, I've been on the same tune from Sasha at OnPoint Dyno for over a year, with only an update in May to increase the rev limit to 7500rpm (from 7200rpm for a bit more room on circuits).
Should I be concerned that my Advance Multiplier is defaulting to 0.7? As far as all the other data points, I don't see any issues.
https://datazap.me/u/jbezugs/3rd-gea...a=5-6-16-27-28
JBezugs is offline   Reply With Quote
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
