Old 07-02-2020, 03:33 PM   #1
radon55
radon55's Avatar
Drives: 2017 Subaru BRZ
Brake Pad Chunking from Track
Hello all,
So far I've been fortunate to get to 6 track days this year. I have a 2017 non-PP BRZ with Project Mu Club Racer pads. Club Racer Advanced up front, and Club Racer in rear.
I've been looking at the pads after each weekend, and they've held up pretty well, but I started seeing some deterioration at the leading edge of the front pads after weekend #2.
I just took a look after weekend #3 and am wondering if I should be concerned about this chunking off the leading edge. The pads still stop the car very well and consistently on track.
Thanks for any feedback!
https://imgur.com/a/T6ZnY3G
radon55 is offline   Reply With Quote
Old 07-03-2020, 04:27 AM   #2
GrabTheWheel
Drives: 16' BRZ
Those look cooked. I would replace them. Looks like they got too hot. Are you sure you did a sufficient cool down after each session before parking in the pits? (hopefully with the ebrake down). I'd put temp stickers on your calipers and monitor temps next track day.
Also, depending on the number of laps 6 days isn't bad for pads although you'd get more on those if they weren't falling apart.
GrabTheWheel is offline   Reply With Quote
The Following User Says Thank You to GrabTheWheel For This Useful Post:
radon55 (07-03-2020)
Old 07-03-2020, 02:30 PM   #3
radon55
radon55's Avatar
I try to do the normal in-lap where you don't touch the brakes at all. It's been very hot the last two weekends I've done though.
Just very annoying to toss them since there's so much pad thickness left.
Good idea on the temp stickers. I'll pick some up.
Old 07-03-2020, 04:12 PM   #4
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Those look normal with a lot of ABS action and a bit of overcooking. There are other well known brake pad compounds that completely crumble and fall apart. Project Mu pads tend to have higher friction so it gives the initial impression of super nice bite. This does come at a slight detriment of getting users to initiate ABS a little sooner than usual. There are companies that mitigate this by having higher friction values but with squishier compounds to give a sense of "modulation". In reality, it's just deforming under heat kind of like how you can heat up a sheet of metal (such as aluminum) and be able to bend it giving you a sense of strength, but in reality the material was just deforming under handicapped circumstances.
CounterSpace Garage is offline   Reply With Quote
Old 07-03-2020, 05:26 PM   #5
radon55
radon55's Avatar
So theoretically if I'm able to nail threshold braking more the crumble resistance should be improved? This is my first track season so I do need improvement for sure getting my braking correct.
Are you also in agreement that the pad should be replaced at this point?
This squishier compound some companies use, as it is more pliable, is there an improvement in crumble resistance? Or is it more just of a driver preference type feel for the pedal adjustment.
Old 07-03-2020, 05:58 PM   #6
CounterSpace Garage
1. Not necessarily. Crumbling is normal for certain compounds. This is perfectly fine and can be reused again. What's not fine is if the pads have half the compound chunked off.
2. Squishier is manufacturing process based. Higher end manufacturing capabilities can get the pads to be more consistent and "stiffer". Squishier means pads operate less consistently with different pedal pressures and temperature. In other words, it's like pressing against a sponge and the friction characteristic changes. It's not that extreme, but as you drive more and experience more pads, you'll find that every manufacturer has unique characteristics.
For reference, our CSG pads are extremely stiff and the friction values are much lower than what other brands advertise, however the bite, consistency, modulation, etc. are very intuitive. Granted, our specified processes are very unique, hence the price point is much higher.
Back on topic, if this is your first season, enjoy the pads for what they are. Crumbling is normal and keep using the pads. If you're interested in trying a spectrum of brake pads, let us know. We can tailor the driving experience accordingly.
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
Old 07-04-2020, 02:51 AM   #7
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
After every couple sessions on track I will flip my pads on the rotor. Just (1) 14mm wrench to swing up the caliper and swap the inside pad with the outside pad. This will help them even out the taper and last much longer and will likely help reduce the crumble as well.
PRO86 | WTCC | STL
Old 07-04-2020, 04:28 PM   #8
redlined600
redlined600's Avatar
Drives: Fr-s
My club sports always crumbled as well. I just keep running them until they are used up, with no issues. They usually look worse than that by the end.
redlined600 is online now   Reply With Quote
Old 07-06-2020, 05:17 PM   #9
CSG Mike
CSG Mike's Avatar
Taper is a sign you're over the MOT of the pad!
Old 07-06-2020, 07:51 PM   #10
rice_classic
Taper from exceeding pad MOT is predominately longitudinal. Radial tapering is predominately a function of floating caliper flex.
You'll see many monoblock (4 pot/6pot) have different piston sizes from the leading side to the trailing side to mitigate longitudinal taper and I think the dual piston calipers on our cars do a lot to reduce this as well. The longitudinal taper on our cars is negligible.
The radial taper - that is the taper from the innermost radius to the rotor to the outermost radius - is not negligible. This is functionally unavoidable on a floating caliper once enough pedal pressure has been exerted to induce flex (which is always on a racetrack).
I think the OP is exceeding the MOT on the leading edge from a longitudinal perspective and would doubly benefit from pad rotation.
Edit: CSG Mike if you think there's a pad that out performs the ST47 in a meaningful way, send me a set and I'll provide an honest review. Better yet, be my pad supplier and I'll run a CounterSpace Garage windshield banner for the rest of the season including the Runoffs in exchange!
PRO86 | WTCC | STL
The Following User Says Thank You to rice_classic For This Useful Post:
dsc_pat (07-22-2020)
Old 07-06-2020, 08:54 PM   #11
CSG Mike
CSG Mike's Avatar
The CSG pads are already proven. I would encourage you to try them, but if you find the ST47 does the job for you regardless of tapering, then there's nothing wrong with sticking with what works for you!
Given the current life/cost ratio of the CSG pads, and your proven driving history, taking advantage of the CSG contingency program may effectively cut the cost of your program significantly
There are many factors involved in pad taper, but we all already agree on how, when, where, and why they taper on this platform, so that only adds to our evidence.
Old 07-07-2020, 08:40 AM   #12
radon55
radon55's Avatar
Uh, what's MOT?
From a quick google I keep getting a UK braking test lol
Thanks for the feedback from everyone. I have flipped the pads for my next weekend and I'll see how they go from there! Definitely bringing my spare pads just in case the crumbling gets significantly worse after a single day.
Old 07-07-2020, 10:04 AM   #13
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Uh, what's MOT?
From context, I'm pretty sure it's "maximum operating temperature" (of the pads).
nico_rsx is offline   Reply With Quote
The Following 2 Users Say Thank You to nico_rsx For This Useful Post:
CSG Mike (07-07-2020), radon55 (07-08-2020)
Old 07-07-2020, 01:26 PM   #14
CSG Mike
CSG Mike's Avatar
Uh, what's MOT?
Maximum Operating Temperature. Actual observed temperature is the result of a few factors, primarily in order, ABS use, kinetic energy converted, and pedal pressure (which contributes/causes ABS).
Taking Care of Tires on Track - How to Avoid Chunking OND Tracking / Autocross / HPDE / Drifting 24 06-06-2017 12:10 AM
FS: Hawk track brake pads, DTC-30 front/HP+ rear, 90% life left, best track day combo tampaSi Brakes, Suspension, Chassis 4 05-27-2017 02:31 PM
FS: Stock Tires (some chunking) bottle Canada Classifieds 4 07-28-2015 01:16 PM
Stock Tire Chunking PICS RMP Tracking / Autocross / HPDE / Drifting 12 10-27-2014 07:50 PM
Dunlop Z2's Chunking, Defective? kanundrum Tracking / Autocross / HPDE / Drifting 19 03-30-2014 09:49 PM
