Old 07-05-2020, 10:38 AM   #1
CokeSlap
Drives: 2014 Monogram FRS Whiteout
Question Paint defect or new issue
Hey all! It's been quite a while since I've been active here. I was going to install some new suspension as it's been long overdue, unfortunately with the heat and humidity here in nebraska I missed my window so I decided to do a little underhood cleaning only to find a very interesting area of bubbling paint under my passenger hood hinge.
This is a new one on me but looks to be a defect from paint pooling or something to that effect. I am curious if anyone has seen this on their twin before.
Previous Ride
1992 Acura Integra GSR in Aztec Green Pearl
CokeSlap is offline   Reply With Quote
Old 07-05-2020, 10:57 AM   #2
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
Looks like chemical attack. Clean it real good, treat it and paint.
Old 07-05-2020, 01:20 PM   #3
alphasaur
friendly
Drives: 17' 86
Agreed, looks like something corrosive got there. I would clean, sand, prime, tape off and use rattle can. Rusteoleum pearl white is actually a very close match for our pearl white and I've used to it touch up spots under the hood. I wouldn't use it on the outside of the car but under hood it's great.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 07-05-2020, 03:09 PM   #4
CokeSlap
What weird me out the most is that it looks like it was a puddle and id imagine if it was something caustic I'd think that it would be obvious as to where it came from.
Oh well not a big deal, simple enough to fix, just very strange!
Previous Ride
Old 07-05-2020, 04:50 PM   #5
WOW! The high heat and humidity in Nebraska strikes again.
Just put a sticker over it, it will be fine. -
Old 07-05-2020, 05:15 PM   #6
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Brake fluid spill will do that if left unchecked for too long.
ineedyourdiddly
Old 07-06-2020, 02:51 PM   #7
This ^
The majority of the spots I have seen just like that were brake fluid related.
Old 07-11-2020, 04:07 PM   #8
CokeSlap
I don't doubt that it could be brake fluid just very strange as it is on the opposite side of all the brake shenanigans going on.
Previous Ride
Old 07-11-2020, 06:08 PM   #9
soundman98
ProCrastinationConsultant
soundman98's Avatar
perfect spot to put a 'bleed bottle' while changing fluids or getting the caliper/wrench situated to bleed the brakes on the front passenger corner.
i usually just put stuff on the ground, but i could see someone putting the leaky bottle there
Old 07-11-2020, 08:47 PM   #10
ls1ac
ls1ac's Avatar
To me it looks like it is a build up under the surface paint and on top of the undercoat. Almost like a bird dropping, well maybe some kind of body adhesive. If you take up a small piece you might be able to determine what it is.
Old 07-11-2020, 11:23 PM   #11
soundman98
soundman98's Avatar
Old 07-19-2020, 08:08 PM   #12
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Originally Posted by alphasaur View Post
Rusteoleum pearl white is actually a very close match for our pearl white.
Are any of these the right stuff?
261411 Metallic Pearl Mist (Looks a little too yellow/cream)
https://www.rustoleum.com/product-ca...c-spray-paint/
352721 Matte Pearl White
https://www.rustoleum.com/product-ca...ustom-lacquer/
I was using the search on the Rustoleum site and these were about the closest thing I could find.
LimitedSlip is offline   Reply With Quote
Old 07-20-2020, 11:26 AM   #13
alphasaur
friendly
Drives: 17' 86
I'll take a pic when I head back home for you!
BRZ Paint Defect staplesja Issues | Warranty | Recalls / TSB 39 06-03-2018 11:23 PM
Paint defect FROM DAY OF DELIVERY! Raven_FR-S Issues | Warranty | Recalls / TSB 22 03-12-2015 09:46 PM
Paint expert opinion needed, paint defect or rocks? ducky369 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 02-08-2015 03:54 AM
Paint chip or paint defect? please help. BBYZILA Scion FR-S / Toyota 86 GT86 General Forum 11 01-16-2015 09:30 PM
VVT issue, TSB or defect? BRZPDX Issues | Warranty | Recalls / TSB 8 07-31-2014 10:57 AM
