Old 07-01-2020, 07:04 PM   #1
DiscoQuinn
DiscoQuinn's Avatar
Drives: 2017 BRZ
Question Simplifying the differences in engines
Hi! I'm new to the forums. This is my first post.
I was donated a 2017 BRZ with a rod through the block.
I'm looking to replace the motor with a stock motor, but like everyone else, looking for the lowest cost at the highest reward.
I don't know about about the FRS/BRZ/86 chassis, but I've spent a lot of time teaching racing in them, and really enjoy them. So I'm hoping to get this one back to stock.
My questions are:
1. What are the differences in engines between the FRS - BRZ - 86?
2. Do things change on the motors from 2012 to 2020? (read: Should I be looking for the same year and model of motor for my BRZ?)
When I accepted the donation my approximation for a used motor cost was well below what I they actually sell for used. It's more expensive then I'd assumed. It's still a great deal for me, and helping teach performance driving, but I need to find the right route for my project to be fruitful.
Perhaps there is some search terms I should be using, or posts I might've missed combing the forums.
Thanks for your time!
~Q
DiscoQuinn is offline   Reply With Quote
Old 07-01-2020, 08:28 PM   #2
dagle
Drives: assphalt FRS, couple s2000's
I believe all 2017+ are compatible with each other, or at least eBay and other parts websites suggest so. I think there were sensor changes 2013-2016 that make the earlier engines not directly compatible. If your components other than the window in the block are complete, you could purchase the engine I linked below and use your existing engine's components to make it whole (double check for yourself and/or your engine builder/shop). If you do not have the practical experience or wrench time to be removing the engine and swapping over the components yourself, I would highly advise a direct longblock replacement instead.
https://www.ebay.com/itm/2017-2018-2...8AAOSwuxZeolGD
dagle is offline   Reply With Quote
Old 07-01-2020, 10:13 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
nothing. it's all just a name.
there was a major engine update in 2016. anything '16-20 will be a direct swap. '13-15 is going to be more difficult due to the changes made, but i believe there are a few documented swaps between the years that took a lot of extra work.
Old 07-02-2020, 07:44 AM   #4
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Just to make a correction, I believe the engine update came in 2017, not 2016. Just using a random link, but they're all the same.
https://www.autoblog.com/2016/05/27/...ssion%20models.
Dzmitry is offline   Reply With Quote
Old 07-02-2020, 07:47 AM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
There are minor updates 13-15. Changes in the rocker pivots and rockers, I think the valve stem length was changed in 15'. 15's and up also have a different engine harness and coil packs to combat failures in the early model.
There are more changes, just can't think of them off the top of my head.
Old 07-02-2020, 09:15 AM   #6
Ernest72
Unfortunately I can’t find it, but there is a pdf from Subaru that outlines in detail every change for the 2017 update. I had it once but can’t find it. Someone more savvy then me might be able to find it and post. It is likely already in a thread somewhere.
Old 07-02-2020, 09:37 AM   #7
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Here is the file ...
Old 07-05-2020, 07:06 PM   #8
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
this is the perfect opportunity to swap in an EJ207
8200rpm bone stock, turbocharged and easily tunable.
JohnH is offline   Reply With Quote
Old 07-07-2020, 09:20 PM   #9
PulsarBeeerz
Drives: JRSC BRZ SOLD
Lol Yeah the cost to reward ratio would be horrible.
PulsarBeeerz is offline   Reply With Quote
Old 08-18-2021, 09:38 PM   #10
JohnH
Professional wrench
really? people are putting LS engines in, K24s, etc. This would probably bolt up. Wiring would be minimal. We already do turbo plumbing on these so no difference.
The cost of a supercharger kit is like $4000 USD, plus a few other items. A good older JDM EJ207 is a couple grand, and then some plumbing. Probably do it cheaper than a SC kit. And at the end of the day you have a STi engine, built for big boost and 8k+ rpm
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
4ugse, brz engine differences, fa20
How often do engines fail because of FI? Xxyion Forced Induction 53 06-24-2018 01:04 AM
VR6 engines... dem00n Other Vehicles & General Automotive Discussions 29 01-25-2013 01:41 AM
100 hp/l NA engines einzlr Other Vehicles & General Automotive Discussions 95 11-15-2012 07:55 PM
What other engines fit our transmissions 1strwdcar Engine, Exhaust, Transmission 36 08-02-2012 04:45 PM
So you think you know engines? Ryephile Other Vehicles & General Automotive Discussions 43 02-04-2012 03:49 AM
