Old 07-01-2020, 01:17 AM   #1
Bread1
Drives: Scion Frs
4ohm door speakers ok?
I want to replace the door subs for some 43DSC6504 KICKER 6.5-Inch (160-165mm) Coaxial Speakers, 4-Ohm will this sound fine with the stock amp, I currently have a sub in the truck so I don’t really need the subs in the doors and just want some extra sound.
Bread1 is offline   Reply With Quote
Old 07-01-2020, 10:34 AM   #2
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Those speakers will electrically work okay (they may not be quite as loud as factory) but I have no idea how they will sound to your ears. I believe the factory door amp has a low pass filter built in to it so there probably won't be any high frequencies coming out of the door speakers, coax or not.
Just an FYI, the factory door speakers are 2 ohm units which are not common. I don't think anyone has found an aftermarket speaker that is identical to the factory units in dimension and impedance. So if you are going to keep the factory door amp, using a 4 ohm replacement speaker that physically fits is about the best you can do. Also, here is a little more info about how the door speakers are wired:
https://www.ft86club.com/forums/show...7&postcount=35
LimitedSlip is offline   Reply With Quote
Old 07-01-2020, 06:49 PM   #3
Bread1
Drives: Scion Frs
Thanks bro I’m just gonna try and see what it’s like if it’s not decent I’ll just return and unplug them all together.
Changing the front dash speakers / door speakers jeffs42885 Electronics | Audio | NAV | Infotainment 8 06-21-2020 06:35 PM
New Door Speakers Fenrir_ Electronics | Audio | NAV | Infotainment 9 05-13-2020 09:11 PM
Get Big! (door speakers) Shankenstein Electronics | Audio | NAV | Infotainment 3 06-10-2014 02:55 PM
door speakers elfumador Electronics | Audio | NAV | Infotainment 3 04-25-2013 01:00 PM
