Drives: 2013 Scion FR-S 10 Series
Series 10 Carbon Fiber
Does anyone know if the Series 10 carbon fiber pieces are real carbon fiber or ABS with a carbon look?
I'm planning out this build and I'm gonna clean and polish these if they're real, replace them with real CF if they're faux. Sent from my SM-N975U using Tapatalk |
#2 |
Drives: Scion FR-S 10 Series
It is not real carbon.
| The Following User Says Thank You to Jdmjunkie For This Useful Post: | JonnyObnoxious (06-28-2020) |
#3 |
#4 |
TRACKBREAD
| The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post: | mrg666 (06-28-2020), soundman98 (06-28-2020) |
#5 |
I just Drive.
Drives: in the womb still
Real carbon fiber is made from different weaves of actual carbon filaments that have already been "spun". You mix that with resins and vacuum/heat to produce panels.
So not sure where "plastic" comes in..
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project |
#6 | |
ProCrastinationConsultant
'dry' or 'prepeg' carbon fiber prioritizes the carbon fibers strength over it's appearance by using as little resin as possible.
#7 |
pessimistic skeptic
Are you guys talking about an interior trim that makes no difference in anything? Not a carbon fiber drive shaft or something functionally important right?
I don't see any point of using real carbon fiber in a place where it has no strength and/or weight advantage over ordinary plastic. In that sense, it is waste of carbon fiber for inside trim, real, fake or whatever. To me, using unnecessary carbon fiber just for decoration is also fake. |
#8 |
Drives: Scion FR-S Series 10 #2462
There is no real carbon fiber on any of the 10-Series cars. It's just plastic with a molded fiber pattern.
| The Following User Says Thank You to MJones_RB For This Useful Post: | JonnyObnoxious (07-12-2020) |
#9 | |
TRACKBREAD
Real ‘Carbon Fiber’ is actually called Graphite fiber reinforced plastic, or carbon fiber reinforced plastic. The matrix is plastic. Spun/laid/woven/chopped whatever shape graphite fibers reinforcing said plastic. My point was that both can be shined up with plastic polish as they’re both plastic. Just don’t sand down to the fibers on the real thing. |
#10 | |
Though I may also replace some of the interior with CF. But not the dash since it lights up all fancy. I want to go with a blue trim interior that is otherwise Series 10 stock. Sent from my SM-N975U using Tapatalk |
#11 | |
Rust bucket enthusiast
My car has seen scenarios like the photo of it below, and my bumper/bezels and rear bumper are totally unscathed.
#12 | |
Also, my front bumper is pretty beat up from previous owners. I think my biggest challenge will be finding the silver ignition paint and a shop that can apply it to OEM spec. But I'm just starting to look. Sent from my SM-N975U using Tapatalk |
#13 | |
i can say for certain that the urethane/poly propalene 'plastic' bumpers and cowling pieces are much more durable than a rigid carbon fiber piece of in those areas. they have much more flexibility as a plastic variant than any carbon fiber process currently available. carbon fiber parts will retain more rigidity until they come into contact with something. and then they'll splinter like cordwood, or your wallet when you see the replacement costs...
#14 | |
Real CF is simply going to look better than the CF patterned plastics there now. Just like a real aluminum panel is going to look better than an aluminum wrap on a part. Yes, it costs more. |
| carbon fiber hood vs carbon fiber trunk which saves more weight? | stlgrym3 | Cosmetic Modification (Interior/Exterior/Lighting) | 43 | 09-05-2020 05:46 PM |
| FS: carbon fiber Password JDM side skirts and carbon fiber 3 pce BRZ front splitter | protpibe | Canada Classifieds | 9 | 02-07-2016 09:37 PM |
| Carbon Fiber Mirrors - Shark fin Antenna - Carbon Fiber Accessories-PRICES LISTED!!! | F-T | Exterior Parts - The Rest | 285 | 08-24-2015 04:42 PM |
| Vis racing ams carbon fiber trunk and Seibon carbon fiber diffuser | Mr.Frs | Cosmetic Modification (Interior/Exterior/Lighting) | 36 | 04-08-2015 10:51 AM |
| Carbon Fiber dash like a BMW? (pictures of M3 carbon fiber interior included) | master345 | Cosmetic Modification (Interior/Exterior/Lighting) | 56 | 05-04-2014 11:10 AM |
