Old 06-26-2020, 02:36 AM   #1
golemslord
Drives: 2014 White FRS
Yellow/green stain after badge removal with wd40 goo gone
Hello, there's a weird yellow stain after I debadged the front emblem and used wd40 and goo gone for residue?
I have no idea how it happened. I was using a yellow microfiber cloth, wd40 and, goo gone automotive spray. After several scrubs I notice the area I'm scrubbing is turning yellow
I immediately used nail polish remover in hopes of removing any chemical residue. It took away some stain but not all. The stain is all over the front emblem area but not where the adhesive was. If that makes sense. It's also in the area where I was scrubbing (area around emblem).
To add, after using wd40, I notice the tape residue is turning green. But wd40 won't normally cause stain?
What caused this and how should I fix it?
Thank you
golemslord is offline   Reply With Quote
Old 06-27-2020, 02:28 PM   #2
MyRx
MyRx's Avatar
Do you have a pic? I’m thinking you may have stained the clear coat. If that’s the case, put some rubbing compound on a mf towel and rub the affected areas. Don’t use any more chemicals.
Old 06-27-2020, 02:31 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Try a buffing complaint or wetsanding.
Old 06-27-2020, 02:38 PM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Small chance an iron/fallout remover may get it out.
I'd just use a polish with a MF, and if that doesn't work a compound will get it out. Follow up with a polish to bring back depth and clarity.
Old 06-27-2020, 04:33 PM   #5
MyRx
MyRx's Avatar
Wetsanding wouldn’t be for a beginner. Much more aggressive than using a medium/heavy cut compound and a mf towel. What the op decribes, the wd40 may have bled the yellow mf towel onto the clearcoat. Start with light/medium compound and mf towel.
Exactly 👍
No chance iron decon will remove a stain. That’s a chemical decon, he needs a mechanical action - compound and a mf towel.
Old 06-28-2020, 05:52 AM   #6
golemslord
Exactly 👍
Dam that might be the reason...the mf was new too. I have used a degreaser and it didn't work. So then I used a rubbing compound, polish, then wax. Around 80% of the stain is gone. I'll stop there incase I destroy the paint
Old 06-28-2020, 05:56 AM   #7
JD001
JD001's Avatar
Drives: Subaru BRZ
Just had a thought, if you can't make it go away then I suggest that you stick a badge over it.. the brilliance of this suggestion is that the bonnet has a small indentation and some carefully crafted lines that will take your eye to the badge.. almost as if it was designed to have badge there....
Old 06-28-2020, 05:47 PM   #8
MyRx
MyRx's Avatar
Nah, keep going. If you’re rubbing by hand, no worries. You won’t penetrate the clearcoat - you’re merely rubbing off a micro nano layer of the clearcoat. Use your phone light and check for micro swirls, stop if you see the swirls multiply. When rubbing, use different sections of the mf. The fibers tend to “lay down” and defeats its purpose after prolong rubbing.
Do you have a non-yellow mf towel? Or a washed clean one? Avoid using a brand new, unwashed yellow mf. Any slight cleaner on a colored mf can bleed out onto a surface.
Old 07-01-2020, 01:26 AM   #9
golemslord
haha yeah i already have black gloss scion badges ready, but this problem delayed the process of putting it on :P
Help. Got a yellow stain icecord Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 26 10-05-2016 12:53 PM
Oil Stain Removal FRSNewb Off-Topic Lounge [WARNING: NO POLITICS] 3 06-07-2015 10:07 AM
Green or Yellow Wheels on Ultramarine bfsnail Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 07-11-2014 02:15 PM
Check out this Green+Yellow+Red FRS Nitro Off-Topic Lounge [WARNING: NO POLITICS] 10 05-20-2013 02:18 PM
Thoughts on a Pearl Yellow, Lime Green FR-S? yormaX Scion FR-S / Toyota 86 GT86 General Forum 82 09-21-2012 11:21 AM
