Old 06-25-2020, 11:02 AM   #71135
p1l0t
p1l0t's Avatar
I think my electrical gremlins jumped from our Suburban to my FRS when I figured out the issue on the Suburban (bad seat heater, unplugged it, no more issues).
Now I can't figure out why the GPS in the FRS has the wrong time on it. (my '13 has the US '14 Pioneer with GPS module). The time is off by an odd number, like 14hours and some change, not an exact hour amount or even half hour amount).
Even started a thread here but no responses.
All other functions are fine, even the remaining time, it's just the expected arrival time that is off (so I'm guessing the current time is off but it doesn't display that).
ARGHH!!!
You can't even set the clock? :facepalm:
p1l0t is offline
Old 06-25-2020, 11:27 AM   #71136
Not on the GPS unit, obviously I can set the one on the console, but GPS units pick their time up from the satellites, you don't normally manually enter it. That's why, when you go between time zones, it automatically changes based on position.
I did look for a place for time zone or to manually enter the time but didn't see one. Need to look at the manual I guess just to be sure.
Dadhawk is offline
Old 06-25-2020, 11:35 AM   #71137
p1l0t
p1l0t's Avatar
p1l0t is offline
Dadhawk (06-25-2020)
Old 06-25-2020, 12:24 PM   #71138
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Is the unit showing your current location correctly? If it is, then the source times should all be right.
Spuds is offline
Old 06-25-2020, 12:40 PM   #71139
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Someone local is selling '04 Benz CL600 coupe. Hm... v12 twin turbo 493hp/590tq to the rear wheels. Sounds like a fun... fun changing spark plugs lol
ichitaka05 is offline
p1l0t (06-25-2020)
Old 06-25-2020, 01:21 PM   #71140
Yep, location is spot on. I've used it for 400 mile trips since this started. Location data and time to arrival is all correct, it's just the estimated time of arrival that is wrong.
Dadhawk is offline
Spuds (06-25-2020)
Old 06-25-2020, 01:22 PM   #71141
Spuds
The Dictater
Spuds's Avatar
Easier than a boxer...
Spuds is offline
The Following User Says Thank You to Spuds For This Useful Post:
p1l0t (06-25-2020)
Old 06-25-2020, 01:27 PM   #71142
Spuds
The Dictater
Spuds's Avatar
Yeah, your unit is messed up then. Might not be handling the gps time reset correctly? It was last year, but maybe it has reverted to a prior time.... Wait... It could be resetting it's internal time and booting to some default clock, thus not knowing that the GPS reset has occurred.
Spuds is offline
Old 06-25-2020, 01:34 PM   #71143
Yea could be. I'm going to pull the power and see what happens. Might also drive across a time zone to see if that does anything (I'm 20 minutes from Central time when at work). In the end, it's not a big deal since it still is technically accurate, just aggrevating.
Dadhawk is offline
Old 06-25-2020, 01:46 PM   #71144
The HU in the wife's Impreza did that all the time. Be fine when you shut the car off and next time you used the GPS it would be a 16 hour trip around the block. Location was always perfect with just the time messed up. They were on something like system update #5 when she traded it in and it still screwed up at random times.
Tcoat is offline
Old 06-25-2020, 01:50 PM   #71145
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Just put tape over where the estimated arrival time is
NoHaveMSG is offline
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
humfrz (06-25-2020), soundman98 (06-25-2020)
Old 06-25-2020, 02:24 PM   #71146
Actually, I do the electronic version of that. I touch it switch it to time remaining instead of arrival time.
Dadhawk is offline
NoHaveMSG (06-25-2020)
Old 06-25-2020, 02:24 PM   #71147
Did it still show the HH:MM to arrive correctly though? That's what mine does.
Dadhawk is offline
Old 06-25-2020, 02:25 PM   #71148
ichitaka05
Site Moderator
ichitaka05's Avatar
Not sure on "easier" part. It's v12 twin turbo and by any mean, under the hood isn't big.
The Following 2 Users Say Thank You to ichitaka05 For This Useful Post:
p1l0t (06-25-2020), Spuds (06-25-2020)
