#141 |
Drives: 2018 BRZ Limited Perf Pack
Great thread!
Re the whole driver aids thing. I teach my novices that ABS and TC are your daily trainers. If you are routinely engaging ABS or TC, then you want to work on your control input smoothness (onset/release of throttle, braking onsets, etc) until you are coming up to those barriers consistently and in a controlled manner. Then go about turning them off stage by stage and keep working up to where you are controlling the car in and out of each successive stage under harder and harder conditions. Seriously - ABS is the best brake trainer there is. It enforces progressive and degressive braking beautifully when you consciously use it as a feedback tool. After a while, you are rewarded with lovely threshold braking burned into your muscle memory.
www.atomicalex.com
2018 BRZ Limited Perf Pack 6MT, a couple of motorcycles, and a stick shift station wagon |
#142 |
Drives: 2015 BRZ
track prep/maintenance questions...
I'm re-starting my second HPDE season, and checking and double checking the car beforehand. I'd love feedback on a couple of issues:
1) I just swapped out the brake pads to Carbotech XP10's I used previously, bedded them, and after the swap, it feels like my rotors are warped. Didn't feel like that with stock pads. Are the rotors actually warped, or is it pad deposits, uneven brake pad contact from swapping pad positions, other issues? 2) While under there, I saw a small amount of grease leaking from the small side of both inner CV boots. Enough to fling and get some on the frame parallel with that axis of rotation, but no holes in the boots, clamps seem tight, doesn't seem like the amount of grease I've seen thrown from torn boots, no clicking noise when turning or otherwise. Replace boots, or wait for other symptoms, or? Car is lowered ~1.5" all around. 3) Last time at track (March?) on second day I had vibration, seemed like from the rear, above 100mph. I checked everything I could, thought it might have been unbalanced tire from a lost wheel weight. Once home, I changed wheels and it went away. Had track wheels rebalanced, didn't re-emerge in brief venture to 100mph. Wheel balance seem like the likely cause, and not CV joints, given they aren't making noise? Thanks all.... |
#143 |
Drives: FRS Hot Lava
Slowmow,
First you need to change barke fluid as well, just in case i make the comments. To your first question, base on my experience you have uneven brake pad material deposit on the rotor. very well descripted problem in many blogs. Solution in my case, I change pads and rotors at the same time (OEM rotors are cheap), if not you can sand them before the bedding process. Here you have more info on that topic. Can not help on 2) and 3) https://www.apcautotech.com/getmedia...c-8-2018_1.pdf |
#144 |
Drives: 2015 BRZ
Awesome, thanks for the response, and apologies for the basic questions. I googled it first but couldn't figure out how the track pad switch was related to the appearance of the symptom. That article from Centric is really helpful. And yep, I flushed the brake fluid using Motul 660. Thanks!
#145 |
using Motul 660 as well, do no like the 600.
| The Following User Says Thank You to fminicooper For This Useful Post: | CSG Mike (06-08-2020) |
#146 |
@slowmow if you used used rotors, then likely you have mixed pad compounds giving you that vibration on brake application
2. clean and continue observing. small amounts of flung grease is normal. large amount is not 3. likely balance, uneven wear, and OPR. |
#147 |
Drives: 2015 BRZ
@CSG_Mike Thanks for the responses.
1) I definitely mixed compounds, switching back and forth from track pads to street pads several times. Do people switch pads and rotors at the same time, and keep "sets" together? 2) Awesome, thanks. I was worried having never seen that before. (never looked) 3) Good. OPR? I had to look that up, popped up on urban dictionary. Hilarious. Appreciate the advice. Cheers. |
#148 |
1. that's more ideal, but more work.
3. other people's rubber hehe |
#149 |
1) I am using track setting on DD. Not ideal, less work.
#150 | |
Drives: Crapcan
#151 |
Drives: 2015 BRZ
Thanks all for the help. The Essex /AP brake website has some great videos on bed-in and particularly swapping street to track pads. They used the track pads to clean the rotors of the street pad material (several hard stops while rotors are cold, two separate times) BEFORE bedding in the track pads. Cheers all.
#152 |
Drives: GR86
Got a 2020 BRZ and there's the newer screen in the car with temp readings.
![]() OP Suggests keeping oil temps under 250F; seems reasonable for 0-20w oil. Perhaps a poor design choice, but I would have hoped the in-car meter would be more helpful in informing the driver of when oil temps are actually too hot...the meter would suggest 270F is totally acceptable and there's not even a red-zone marking for 340F. |
#153 | |
Drives: Halo 860
Good luck keeping it under 250, I was over 255 after hot laps on my very first track day. Oil cooler becomes necessary on these cars if you don’t want to spend half your track time running cooldown laps. |
#154 | |
Drives: GR86
| FS: NRG Quick Releases, Hub, Quick Lock, Steering wheel | Pekingduck | Interior Parts (Incl. Lighting) | 7 | 02-12-2014 05:59 PM |
| prepping for winter | Celica00 | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 09-27-2012 08:17 AM |
| Prepping for rear spoiler install? | zooki | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 09-02-2012 03:56 PM |
| FR-S quick reference and warranty / maintenance guide is up | pkny | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 06-20-2012 11:33 PM |
| Clean & Dirty | trueno86power | Other Vehicles & General Automotive Discussions | 1 | 02-07-2012 12:54 PM |
