Old 06-20-2020, 12:37 AM   #22037
Silviacrazed
Drives: 2016 Scion FR-S
Why don't you folks just weld the engine to the frame (body), weld the transmission to the engine, and weld all the other parts of the drive train together then weld that all up to the transmission? -
Why hadn't I thought of that! No movement at all ftw!
Sent from my SM-G960U using Tapatalk
Silviacrazed is offline   Reply With Quote
The Following User Says Thank You to Silviacrazed For This Useful Post:
humfrz (06-20-2020)
Old 06-21-2020, 12:14 AM   #22038
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
detailed my engine bay
RickyRacer is offline   Reply With Quote
The Following 8 Users Say Thank You to RickyRacer For This Useful Post:
humfrz (06-21-2020), JesseG (06-22-2020), Kaotic Lazagna (06-21-2020), MJones_RB (06-22-2020), new2subaru (06-22-2020), Silviacrazed (06-21-2020), trvth (07-02-2020), wolffbite (07-06-2020)
Old 06-21-2020, 06:34 PM   #22039
Kaotic Lazagna
Drives: GR Corolla
Ordered a dual channel dash cam to replace the front only cam I have now.
Old 06-21-2020, 07:32 PM   #22040
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
What did you lub to reduce the brake squealing?
I'm a little late to this, but all I've used was synthetic caliper grease from an O'Reilly's in my area.
So far it seems to work; my brakes have not squealed any louder from when I initially posted a few days ago.
The Following User Says Thank You to KR-S For This Useful Post:
humfrz (06-21-2020)
Old 06-21-2020, 11:17 PM   #22041
Not a bad job, but that oil filler cap looks like it needs a little work -
RickyRacer (06-22-2020)
Old 06-22-2020, 12:31 AM   #22042
soundman98
ProCrastinationConsultant
soundman98's Avatar
Nothing a little brake cleaner can't fix!
Old 06-22-2020, 04:30 AM   #22043
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
>>I looked at my car in my garage today.<<
It's dusty. I last washed it Sept. 2019...after a 3100 mile trip.
Since February 2, 2020 I've driven 234 miles and filled it's tank once again, in early June.
I've Gone to grocery store once... in late March...not since then.
I use the car to go to USPS and to Bread Outlet store, that's it for car trips.
Isn't Covid just great !
ToySub1946 is offline   Reply With Quote
The Following User Says Thank You to ToySub1946 For This Useful Post:
JesseG (06-22-2020)
Old 06-22-2020, 10:58 AM   #22044
Actually, I had the opposite idea.
What we need are motor mounts that have a mini "air suspension" setup for the bushings. That way, when it's time to change spark plugs, you push a button, raise the engine, batta bing, done.
Dadhawk is online now   Reply With Quote
humfrz (06-22-2020), MJones_RB (06-24-2020), soundman98 (06-22-2020)
Old 06-22-2020, 11:12 AM   #22045
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
The Following 4 Users Say Thank You to Yoshoobaroo For This Useful Post:
Dadhawk (06-22-2020), MJones_RB (06-24-2020), NoHaveMSG (06-24-2020), soundman98 (06-22-2020)
Old 06-24-2020, 07:00 AM   #22046
Compelica
Compelica's Avatar
Drives: 86 GT
Where did you specifically lubed it btw? Got a brake squeak for me that I need to fix real quick.
Compelica is offline   Reply With Quote
Old 06-24-2020, 09:18 AM   #22047
Why stop there?
MJones_RB (06-24-2020), soundman98 (06-24-2020)
Old 06-24-2020, 10:25 AM   #22048
Why stop there?
Works for me, although not sure I'd want to "drive" that.
Old 06-24-2020, 10:29 AM   #22049
In Transformer universe car drive you.
Dadhawk (06-24-2020), soundman98 (06-24-2020)
Old 06-24-2020, 01:48 PM   #22050
corry29
corry29's Avatar
Never thought I'd be getting this type of item because I've always considered them "rice" and never understood the function of these until now.
The bucket seats in my car was repositioning my seatbelt to slice my neck during driving. So I ended up getting seatbelt pads for my seatbelts
/mfGhost
corry29 is offline   Reply With Quote
The Following 2 Users Say Thank You to corry29 For This Useful Post:
MJones_RB (06-24-2020), Vic4uf (07-08-2020)
