Old 06-16-2020, 01:37 PM   #15
Sam86
Drives: Toyota 86 GTS
Still on the topic of this, i've got D2H bulbs and waiting for my VLAND casing to arrive for install.
I've been given the impression it's all plug and play with no wiring required but sometimes I see people using some kind of blue clip that they use to attach the indicator wiring to the headlight for the sequentials on the VLAND to work. Is that something everybody with VLANDs has to do? I don't know anything about wiring and I don't have any clips or idea of what to do should I find myself in the position of installing my VLANDs only for the indicators on them to not work. I also am weary of my weak bumper clips and want to get it all done in one go and not have to remove the bumper additional times after the install.
This video is the only video i've found that actually goes in depth into the headlight install. Most of the time they just skip the cable connecting and just say they installed it easy. This guy also has the same d2h set up as me but unfortunately I don't understand anything he's saying.
The blue clip I referred to he shows at 12:44.
Can anyone who has done this explain to me what he's doing, what clips and other tools i'll need if this is something i'll have to do aswell
Sam86 is offline   Reply With Quote
Old 06-16-2020, 04:53 PM   #16
gpvecchi
gpvecchi's Avatar
Originally Posted by gpvecchi View Post
So, a Chinese D2H xenon kit would be better than OEM LEDs?
Anyone?
Old 06-16-2020, 07:45 PM   #17
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
Anyone?
You need to give more info if you want a true response. What lights, what housings, etc. that you are comparing.
If you're talking about a D2H HID kit in VLAND headlights, that's already been extensively discussed here.
sharpsicle is offline   Reply With Quote
Old 06-17-2020, 01:19 AM   #18
gpvecchi
gpvecchi's Avatar
I asked if a xenon hid kit in an aftermarket headlight like Vland is better that stock 2017 LED headlight.
Old 06-18-2020, 12:44 PM   #19
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
If there is a difference then it might be a difference of getting a 96% on a test and a 99%. Both people got an A.
My HIDs on my Vlands light up road signs further than what I can read, and I have better than 20/20 vision. They light up objects over a quarter mile away.
Old 06-18-2020, 06:07 PM   #20
mrg666
pessimistic skeptic
mrg666's Avatar
Feel free to correct me on this, but don't most aftermarket LEDs on the market perform worse than halogens?
I have upgraded D2S bulbs on my FRS Monogram but the LED H11 conversion bulbs on my Mazda 3's projector headlight are comparable in brightness and pattern. Quality of LED conversion strongly depends on the quality of the projector on the headlight. A good projector headlight and a good quality LED conversion bulb is comparable to a good quality HID based on my experience. Reflector headlights, on the other hand, are not good with LED conversion as I found with my Honda Odyssey.
Old 06-24-2020, 07:53 AM   #21
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
HeadlightRevolution recently tested 25 most popular LED headlight bulbs. Their #1 pick, which I also have now, is GTR Lighting Ultra Series 2 LED on my stock FRS headlamp. I used to have DiodeDynamics SL1 LED & was also able to compare them side by side. SL1 is about 2x brighter than the brightest halogen I could find back then, Philips X-treme Vision, & the GTR is even brighter than SL1. Both premium LED's are properly engineered to have distinct hot spots whether using a reflector or a projector headlamp.
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
Old 06-15-2022, 07:58 AM   #22
CarolWilks
CarolWilks's Avatar
Drives: x4
I believe mine is 7W, but I am not sure. I bought the LED lights I am using from vont.com, and luckily everything is working correctly. The alternator on this model is too weak for LED lights, so I had to change it before installing the lights. It wasn't a big problem, because the old one was already broken, so I decided to replace it with a better one which will allow better viability of the electric system in the car. I am very happy that I have the LED lights because now I can see the road well while driving at night.
CarolWilks is offline   Reply With Quote
Old 01-18-2024, 05:48 PM   #23
j5o5n
j5o5n's Avatar
Drives: Man
Send a message via ICQ to j5o5n Send a message via AIM to j5o5n Send a message via Yahoo to j5o5n
For LEDs, I had good results with the Auxbeam F-16 series. They're budget-friendly and throw a decent amount of lumens. For HIDs, Philips and Osram are reliable choices; they offer great brightness and longevity. Just make sure you match the colour temperature to your preference. If you're still undecided, consult a specialist or visit a website for more options that might help.
During quarantine, I redesigned my house and often used leds.to for lighting choices. They have informative articles and suggestions on various models, which simplifies everything. You can see more information on their website, maybe they will help you.
j5o5n is offline   Reply With Quote
Old 01-22-2024, 10:35 PM   #24
pope
has a funny hat
Drives: 2014 BRZ Limited
Reported
pope is offline   Reply With Quote
aftermarket, brz, frs, headlights, vland
OLM HID headlights (looks like VLAND for BRZ’s) Suparu Cosmetic Modification (Interior/Exterior/Lighting) 3 01-23-2020 07:55 PM
Vland headlights question gpvecchi Cosmetic Modification (Interior/Exterior/Lighting) 17 09-27-2019 01:43 AM
WTB SPEC D OR VLAND HEADLIGHTS tk1.frs Want-To-Buy Requests 0 09-16-2019 11:37 PM
WTB SPEC D OR VLAND HEADLIGHTS tk1.frs Want-To-Buy Requests 0 08-18-2019 07:10 PM
FRS Led Conversion (Vland Headlights) Help Michael41197 Electronics | Audio | NAV | Infotainment 2 07-05-2019 07:44 PM
