Old 06-15-2020, 12:37 AM   #29
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
Front sway bar links with KW-based coilovers
Originally Posted by Chuckable View Post
Yes, that’s correct. Connect the endlinks to the sway bar, load the suspension, and then adjust the endlinks so that they will slide right on to the coilover mount with as little resistance as possible. Then, torque them down to spec. You dont want any preload on the endlinks if possible. Also, obviously make sure that you’re safe during the whole procedure. It’s sometimes tricky to load the suspension with just jack stands.
Thank you and yes, i made sure i did it the safe way. I did this and it was a big difference with the length of the endlinks initially on both side much better. But I thought this was the source of the noise i was hearing in low speed. Like clunking sound not metal to metal sound though. It is coming from the front. everything is tight and torqued to spec. Can binding springs can cause sound? Coilovers using stock top hats from a 2017.
tintumz22 is offline   Reply With Quote
Old 06-15-2020, 05:34 AM   #30
new2subaru
Weight Weenie
Drives: 15 FR-S
That’s exactly why I added that disclaimer. With that said, I have used jackstands under the control arms half a dozen or more times, and done it safely. The ideal setup would be with the car elevated and the 4 wheels/tires fully supported on turntables or platforms, or a drive-on lift.
I understand that, but if the OP doesn't have that kind of experience and maybe someone there who does I wouldn't do it.
I've done it myself and it's a bit sketchy. I'm building wheel cribs just to avoid doing it again.
Old 06-15-2020, 07:51 AM   #31
Chuckable
Drives: 2017 Toyota 86
Glad it worked and you were able to do it safely. It’s tough to isolate coilover noise.
Can you isolate the noise to a specific road condition? We know it’s low speed, but is that while driving on a smooth road? Over bumps? On one side or the other?
Did you remove the sway bar subframes (for lack of a better description) when you installed the sway bar? Some people have accidentally stripped the threads. That might be possible.
Are there any witness marks on the chassis near the sway bar endlinks?
Are the dust boots maybe hitting anything on compression?
Etc.
Might be worth a call to the coilover mfr to see if they have any ideas, and if not, try a local shop to help diagnose.
Chuckable is offline   Reply With Quote
The Following User Says Thank You to Chuckable For This Useful Post:
tintumz22 (06-15-2020)
Old 06-15-2020, 11:17 AM   #32
tintumz22
tintumz22's Avatar
Etc.
It was not my first time working on the car so I get the safety part what to watch out for.
it is in low speed (less the10-15 miles/hr). on smooth road and small bumps. I don't see any marks on any of the suspension parts. It is more audible in the driver's side front.
I'm on stock sway bars so I did not removed it. Just endlinks and coilovers.
Old 06-15-2020, 11:35 AM   #33
Racecomp Engineering
Are you using camber plates?
- Andrew
Old 06-15-2020, 11:46 AM   #34
tintumz22
tintumz22's Avatar
- Andrew
No. I'm on stock top mounts both front and rears.
Old 06-15-2020, 12:03 PM   #35
If you're sure your endlinks, top mounts, and coilovers are in good shape, I would double check your installation and give your front suspension a once over. Top mount nut could be loose for example. I'd also check your front control arm bushings.
But if your endlinks use spherical bearings, I would try to see if those are loose.
- Andrew
Old 06-16-2020, 11:20 AM   #36
tintumz22
tintumz22's Avatar
- Andrew
I checked everything. All nuts and bolts are tight. Endlink spherical bearings is tight too. I think the noise i'm hearing is from the plastic spring perch and the main spring of the front coilover. Is it okay to put a little grease between there?
Old 06-16-2020, 03:22 PM   #37
That's not usually where I'd expect to hear noise from over bumps...that's more of a turning the steering wheel at slow speeds and hearing a "sprong" noise.
I would try installing OEM endlinks and seeing if the noise goes away as a first step.
- Andrew
tintumz22 (06-16-2020)
Old 06-16-2020, 03:57 PM   #38
tintumz22
tintumz22's Avatar
- Andrew
I'll try that. But in any case that I'm be hearing that "sprong" noise, what is the remedy for that?
Old 06-16-2020, 06:07 PM   #39
That's fairly rare on KWs on stock top mounts, but lubricating the spring perches would help that.
- Andrew
Old 06-18-2020, 05:28 PM   #40
pslater
Drives: 2017 Golf R
- Andrew
hi andrew,
i just installed some lightly-used Tarmac 0's and while the performance is awesome, i am also getting some odd noises.
when the car is cold, i will get some weird groaning when turning the wheel maybe the first 5-7 times, and it's clunking over bumps/imperfections at very low speed. when the car is warmed up, the groaning and clunking goes away.
historically this latter noise has always been a slightly-loose top mount nut, but it's definitely tight. i do suspect that the mount is tired (it came used with the coilovers), so i have some Group N mounts on order. i suspect that will cure that. i also have some adjustable end links on order as the stock links are quite close to the lower front control arms.
as for the groaning... it does seem like it's the sound of the spring moving; shouldn't the bearing in the top mount allow the spring stay put? (i.e., the entire assembly turns.) if the spring is indeed turning, i guess a torrington bearing would work in between the spring and the perch, but i've never had to do that before with stock strut mounts (always with spherical bearing camber/caster plates, though).
this is on a 2018 BRZ RS (Performance Pack up here in canada) with roughly 9K miles on it, so everything else is super-fresh. the nice slotting of the upper strut housing bolt holes allowed me to dial in some negative camber, and that coupled with the spring rate/damping harmony have really amplified the joy i get from this car. thanks for the great setup!
peter
pslater is offline   Reply With Quote
Old 06-19-2020, 02:24 PM   #41
Originally Posted by pslater View Post
hi andrew,
peter
If the top mount is indeed a little old and crusty, that could also cause some of the groaning while turning the wheel. Start there and let me know how it goes.
- Andrew
pslater (06-22-2020)
Old 06-22-2020, 10:54 AM   #42
pslater
Drives: 2017 Golf R
- Andrew
will do. thanks andrew.
ISO Front sway bar and end links vladniko86 Want-To-Buy Requests 0 05-30-2019 02:59 PM
Front Sway bar end links rick s Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-09-2015 11:33 PM
Need help! coilovers/sway links issue P_say86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 03-19-2015 08:35 PM
WTB: Whiteline Front sway bar Links. Filipino Royale Brakes, Suspension, Chassis 0 08-06-2014 02:46 AM
Stance super sport coilovers with front sway bar end links 900.00 kimchangil424 Brakes, Suspension, Chassis 4 02-06-2013 02:25 AM
