Old 07-23-2012, 09:17 PM   #1303
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Originally Posted by DarkSunrise View Post
He's probably calculating that based on power-weight ration.
2013 Mustang GT: 3618lbs / 420hp = 8.61 lbs/hp
So an FR-S would need:
2758 lbs / 8.61 = 320 hp (~272 whp) to match.
well seeing all these post with basic mods adding alot of power i can see us hitting those numbers really easy.
WolfsFang is offline   Reply With Quote
Old 07-23-2012, 09:17 PM   #1304
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Don@Accelerated View Post
The only gauges I'd reccomend are Boost and Wideband. Nothing else is needed.
Don
Depends on usage IMO. As a track car I'll put oil pressure and oil temp in the car regardless of it being NA or having positive intake manifold pressure...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-23-2012, 09:21 PM   #1305
Synack
Boosted
Synack's Avatar
Drives: Sideways
We'll be super lucky to hit 225whp with intake, header, high flow cat, catback, and a tune. Let alone 275.....
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
The Following User Says Thank You to Synack For This Useful Post:
lordtakuban (07-24-2012)
Old 07-23-2012, 09:27 PM   #1306
WolfsFang
Scrape Master
WolfsFang's Avatar
pully, clutchmasters clutch, lighter rims, and maybe a few others things im forgetting.
Old 07-23-2012, 09:36 PM   #1307
Don@Accelerated
Don@Accelerated's Avatar
I'm thinking more like 205whp
Don@Accelerated is offline   Reply With Quote
The Following User Says Thank You to Don@Accelerated For This Useful Post:
Old 07-23-2012, 09:41 PM   #1308
Don@Accelerated
Yeah we have some sophisticated stuff in our race cars. But for street cars with stock engines. I think that is enough! Any more info and you make a nervous nelly out of everyone.
Old 07-23-2012, 09:43 PM   #1309
Don@Accelerated
Rode in the car today.. this is how the car should have come stock power wise. The difference was obvious when Don was pushing it as well as higher gear acceleration. Quality of parts/fabrication looked top notch also. Don had some very nice cars there that he has built.
Great bunch of guys, a buddy and myself probably ended up having them waste an entire day with Don having them take stuff off the BRZ, then reassemble it just to give us a ride in it
Thanks for stopping in. It wasn't to busy of a day. I really needed a slow day anyway. It was hot and nobody wanted to work after the long weekend. I hope you'll come back next month. By then I should've turned the wick up.
And we'll grab some of these:happy0180:
Old 07-23-2012, 09:44 PM   #1310
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
They have about 365whp stock at 3650lbs
We would need 275whp because we are 2750lbs.
Our car is about 900lbs lighter.
umm i think you forget about all the people that dynoed stock 5.0 mustangs at 398 rwhp
3453 lbs 260 whp 13.2807 v6 p/w
3875 lbs 395 whp 9.8101 v8 p/w
500 whp 7.75 p/w
2600 lbs 171 whp 15.2047 ( i did this calculation based off the weight im stripping out of the car, not actual stock weights but does give a good reference point)
195.7728 whp = 3.7L power to weight
265.0330 whp = 5.0L power to weight
335.4838 whp = GT500 power to weight
but put this in perspective, we need 200 less crank hp to accelerate as fast as a gt500... and a lot less tq
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 07-23-2012, 09:52 PM   #1311
carbonBLUE
Reverse Burnouts
Originally Posted by SUB-FT86 View Post
I think the auto can take the abuse since it isn't a lot of torque gained with this turbo. A lexus IS250 auto still makes more torque(184tq) with the same tranny.
not to mention our trannys have stuff the IS250's dont have, i bet our trannys are stronger as well, but we wont know till someone breaks one, the manual is quite beefy, i would expect the auto to be just a bit behind, prob could handle 100 less hp than the manual
(wont forget you)
2011 Infiniti G37x
Old 07-23-2012, 09:55 PM   #1312
GirlyScions
Drives: Mazda3
Lol....Its full spool at like 2600 rpm
Does that equate to full boost all the time? Also is 2600 rpm basically the rpm the engine speed you shift in to?
GirlyScions is offline   Reply With Quote
Old 07-23-2012, 09:56 PM   #1313
thorlius
Canadian
Drives: Frieda: Firestorm/MT (11/28/2012)
500 whp 7.75 p/w
Did you buy the car to drag race Rustangs?
On a side note, I'm going to miss the power:weight of my Corvette, and its 285 rears.
thorlius is offline   Reply With Quote
Old 07-23-2012, 10:02 PM   #1314
Synack
Boosted
Synack's Avatar
Drives: Sideways
500 whp 7.75 p/w
195.7728 whp = 3.7Lpower to weight
265.0330 whp = 5.0Lpower to weight
335.4838 whp = GT500power to weight
I just googled saw a few dynoes between 355 and 375 and took an average. My post wasn't supposed to be about a drag race between the two. I am personally looking for a peak whp to weight ratio better than a stock 5.0. That'll be my benchmark minimum for drifting to my standards.
Sent from my Galaxy Nexus
Sall (07-24-2012)
Old 07-23-2012, 10:05 PM   #1315
Synack
Boosted
Synack's Avatar
Drives: Sideways
To all of you concerned about gauges etc. If you have a smartphone or tablet you can use the Torque app to view a lot of data.
Very very tiny example.
This one is from my phone. Boost on the left. AFR on the right.
Old 07-23-2012, 10:07 PM   #1316
Gen
Drives: Scion FR-S
As far as people complaining about pricing...yes it's expensive. Cheaper than some cars, more expensive than a lot, but first to market carries a premium. Give it a year, throw in some competition, and you'll see prices fall to some degree.
Gen is offline   Reply With Quote
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 11:24 AM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-03-2012 11:24 PM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 07:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 08:14 PM
