Old 06-08-2020, 04:44 PM   #1
Bach415
Bach415's Avatar
Drives: Whiteout FRS
2017+ Cluster Menu Button Resistance
Does anyone know the resistance/resistor value for the cluster menu buttons on the 17+ steering wheels? Each button should have a different resistor value based off of looking at the electrical wiring diagram.
Bach415 is offline   Reply With Quote
Old 06-13-2020, 08:36 AM   #2
MachineHead
Drives: BRZ Limited
i hope this helps
dp and dp2
MachineHead is offline   Reply With Quote
Old 06-13-2020, 11:57 PM   #3
Bach415
Bach415's Avatar
Originally Posted by MachineHead View Post
i hope this helps
dp and dp2
Thank you! May I ask where did you find this?
Old 06-16-2020, 02:58 PM   #4
reh8388
Drives: 2016 Scion FR-S Release Series 2.0
i hope this helps
dp and dp2
This is awesome. Like asked above, are you willing to let us know what document you were able to pull this from?
reh8388 is offline   Reply With Quote
2017 Limited Gauge Cluster halleffect Electronics | Audio | NAV | Infotainment 26 10-22-2020 07:32 PM
2017 GR edition cluster mod vagthomas Cosmetic Modification (Interior/Exterior/Lighting) 63 06-29-2020 04:41 PM
LED Changed Dual Climate A/C Start Stop Button 2017 LCD Cluster Traction Controls! JNuman85 Interior Parts (Incl. Lighting) 0 04-03-2020 04:01 PM
gt86 2017 cluster working on a pre 17 car geraldjust Cosmetic Modification (Interior/Exterior/Lighting) 0 08-28-2018 06:02 AM
2017 gauge cluster Drakiv Cosmetic Modification (Interior/Exterior/Lighting) 2 11-14-2016 11:32 PM
