Old 05-12-2020, 02:25 PM   #155
Originally Posted by snowtaipan View Post
Bro I see your point, I see Mike's, in the end no one likes CARB. y'all can agree on that, the rest is semantics.
On the other hand, don't mess with Texas. You good.
Old 05-12-2020, 03:00 PM   #156
snowtaipan
snowtaipan's Avatar
Drives: '17 BRZ Series Yellow Edelbrock SC
Update
"We’re going to configure ROM version ZA1JS00C for your BRZ today to see if the performance changes."
-calibrations
They also modified the K00C to test the MAF before they run the new ROM.
It looks like they're digging into the tune, I'm hopeful I can help them help me help others by correcting their tune! I'm pretty stoked, and I'm optimistic they'll be able to identify and correct whatever bug is coming up.
edit: below are the data logs with Edelbrock's K00C MAF rescaled. It looks way better than it was.
https://datazap.me/u/snowtaipan/2020...1&data=7-10-11
https://datazap.me/u/snowtaipan/2020...data=2-7-10-11
snowtaipan is offline   Reply With Quote
The Following 4 Users Say Thank You to snowtaipan For This Useful Post:
CSG Mike (05-12-2020), Irace86.2.0 (05-12-2020), kev0 (05-12-2020), tomm.brz (05-18-2020)
Old 05-19-2020, 05:46 PM   #157
Skwerl
Drives: 2017 BRZ PP
I just got my kit installed on a 2017 BRZ, I'm seeing a similar issue. Who did you contact at Edelbrock? Maybe I can help by providing additional information/logs.
Skwerl is offline   Reply With Quote
Old 05-19-2020, 08:56 PM   #158
snowtaipan
snowtaipan's Avatar
I didn't get a specific name, just calibration@edelbrock.com
Did you get the 1556 with the ECUTEK tune?
Old 05-19-2020, 10:08 PM   #159
Skwerl
Drives: 2017 BRZ PP
I did get a 1556 with ECUTEK tune. I purchased it from Summit, but upon calling Edelbrock, I found it has a 3 bolt bypass valve. Pinching the line solved the issue.
The Following User Says Thank You to Skwerl For This Useful Post:
CSG Mike (05-20-2020)
Old 06-12-2020, 12:34 PM   #160
snowtaipan
snowtaipan's Avatar
When you say pinching the line solved the issue what do you mean? If you keep that closed at all times, you'll never have boost. That line on the back closes the port in the manifold allowing air to go through the SC.
Old 06-12-2020, 12:56 PM   #161
snowtaipan
snowtaipan's Avatar
Talking S10C tune update
So I've been using the K00C tune with the MAF scaling from Edelbrock for a while, and had no issues. It looks like it's pushing around 225HP (using an ELM scanner and TORQUEPro app.) The downside is that the K00C is it's an older ECUTek program.
Edelbrock was kind enough to send a modified 2019 S10C tune, which I'm now testing out. It has more bells and whistles. Initially the idle was pretty negative (-15 ish) but seems to have smoothed out. It had some hesitation during moderate acceleration but again that seems to be smoothing out as well. I'll keep updating as I go along.
https://datazap.me/u/snowtaipan/s10c-logs?log=1&data=2
I'm also going to update the original post as "Fixed" since the issue was clearly the tune, now it's just a question of how much better it can get.
Huge thanks to everyone who helped, you guys made a world of difference, and I'm back to shredding tires thanks to y'all.
Old 06-12-2020, 01:11 PM   #162
dreamwonder
Drives: GR86 2022
I will add a data point. May or may not be useful.
My car has a JRSC. About 6 or 8 months ago I have been getting p0172. LTFT will usually read -39ish when it happens. Attempts of solving it includes cleaning MAF and replacing MAF, which when performed will immediately drop LTFT back to 0ish. Also vented both breathers to atmosphere. But the code keeps coming back. Sometimes it takes days sometimes it takes weeks. So today when it happened again, I simply just disconnected the MAF connector and reconnected it and LTFT dropped back to 0ish!
My next step is when it happens again, I will just wiggle the connector a bit and see if it fixes the problem.
dreamwonder is offline   Reply With Quote
Old 06-12-2020, 01:45 PM   #163
mrg666
pessimistic skeptic
mrg666's Avatar
Replace MAF extension cable!
I use this one
https://www.bmotorsports.com/shop/pr...d/3307%7B2%7D5
Old 06-12-2020, 04:37 PM   #164
dreamwonder
Drives: GR86 2022
I use this one
Thanks! Bought one. Jackson wanted $80 + shipping. Saved $40.
Old 06-12-2020, 06:11 PM   #165
mrg666
pessimistic skeptic
mrg666's Avatar
You can see the cable in this picture. It does not come with the protection sleeve like JR cable but you can transfer from the older one.
Old 06-12-2020, 09:14 PM   #166
tomm.brz
Drives: brz 2017 hksv2
Man, at 6400 rpm you have direct injection PAST spark fire.. that s super bad and I can t believe they re going to keep you like that
Also why all these random logged values? did you purposely modified the live data list?
could be a mislogging but to be sure you should log with the default values and add cylinder misfire #1-4 and direct injection angle di
also Di duration in ms
Old 06-13-2020, 08:25 AM   #167
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
I believe he means "temporarily" solves the issue, i.e. closes the vacuum leak caused by the hole in the bypass valve diaphragm.
It is not recommended to cap off the bypass valve line as this would result in the valve returning to it's home, resting position which would mean all air would pass thru the SC rotors. (no bypass)
BirdTRD is offline   Reply With Quote
edelbrock, p0171, p117b, supercharger
P015A, P015B, P0171, P117B and P0170. kev0 Issues | Warranty | Recalls / TSB 5 08-21-2019 01:30 PM
too lean issue? p117B p0171 engine codes zackegle Issues | Warranty | Recalls / TSB 1 03-21-2017 08:03 PM
P1170 P117B Direct Injection Issue? gonzo Issues | Warranty | Recalls / TSB 4 01-11-2017 02:23 PM
Oft Tune E85 Showing Codes P1170 P117B gonzo Software Tuning 30 09-05-2015 02:50 PM
Engine Code: P0172 P117B *KID* Engine, Exhaust, Transmission 2 01-25-2013 04:23 PM
