Old 07-23-2012, 08:55 PM   #1
vividracing
vividracing's Avatar
Agency Power Crank Pulley / Clutch Masters Flywheel
  • Run#1 153whp 125wtq
  • Run#2 180whp 143wtq
  • Run#3 194whp 150wtq
Run#1 Was a BASE run. Bone stock!
Run#2 Was with the Flywheel and Crank Pulley.
Run#3 Was with Flywheel, Crank Pulley, Header, Crossover pipe, Catback exhaust system.
Clutch Masters kit,
Clutchmasters Stage 1 with a lightweight steel flywheel.
AP light weight pulley
vividracing is offline   Reply With Quote
The Following 3 Users Say Thank You to vividracing For This Useful Post:
AJUSA.com (08-28-2012), Bonburner (07-24-2012), Wes (07-24-2012)
Old 07-23-2012, 08:59 PM   #2
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Whats the weight of the stock flywheel?
Silverdub is offline   Reply With Quote
Old 07-23-2012, 09:05 PM   #3
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
This is without tuning? I thought I read elsewhere that a lightweight flywheel and pulley combo could lead to a surging idle due to the ECU not being programmed to recognize the faster changes in crank speed?
How could all this be done without a tune an remain driveable?
Chewie4299 is offline   Reply With Quote
Old 07-23-2012, 09:10 PM   #4
vividracing
Car drives without issue.
The car/ECU is still new. No one really knows until you do it.
But so far we have not seen any cel lights.
The Following User Says Thank You to vividracing For This Useful Post:
Old 07-23-2012, 09:10 PM   #5
fenton
Can we get some in car driving videos of this car, i would like to see how it accelerates WOT and how the daily driveability stands.
These are nice gains but i want to see and hear if this is livable.
Thanks,
fenton is offline   Reply With Quote
Old 07-23-2012, 09:10 PM   #6
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
wow so your telling me that a pully and a clutch made almost 25 tq? god dam this car is going to yield huge performance with simple mods.
WolfsFang is offline   Reply With Quote
Old 07-23-2012, 09:10 PM   #7
vividracing
20.6 .. Will have all the weights in thread in the morning.
Old 07-23-2012, 09:14 PM   #8
AkaJabari
Drives: Scion FR-S, Scion tC
So let me get this straight. You're telling us that with this flywheel +pulley combo, you've managed to reduce drivetrain loss from ~24% (which is pretty standard for RWD platforms) to ~10%?
This is your story?
AkaJabari is offline   Reply With Quote
Old 07-23-2012, 09:16 PM   #9
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Ah yeahmy bad just noticed the picture on the scale was of the stock one! I ll keep an eye out for your update.
Old 07-23-2012, 09:18 PM   #10
Calum
That Guy
Drives: 2013 asphalt FRS MT
Palm, face. Face, palm. Ah, I see you've already met.
Fuck me. How do you expect to have any creditably if you post a light weight part but don't show the weight difference?
The Following User Says Thank You to Calum For This Useful Post:
Coheed (07-24-2012)
Old 07-23-2012, 09:22 PM   #11
fenton
This is your story?
The runs are two months apart so that could be some of the issue.
Old 07-23-2012, 09:23 PM   #12
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Is the flywheel going to be available as a single part or only sold with a flywheel?
Old 07-23-2012, 09:26 PM   #13
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
awesome gains with a flywheel, seems like the install wouldn't be too difficult with the position of the trans on the 86.
Jesse is offline   Reply With Quote
Old 07-23-2012, 09:27 PM   #14
fenton
stock at 153 is 23percent loss considering a perfect engine and mustang dyno.
Clutch flywheel and pulley result in 10 percent loss yes but i think alot is going to have to do with the car both breaking in and dyno conditions between the two months/calibration.
Just my 2 cents though
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
