Old 11-13-2014, 06:32 PM   #1
ShutterSpeed
Drives: Olive Drab/Army FRS
Notching Rear Subframe
Back in May I broke my stock axles at the inner CV joint. The cradle snap and all the ball bearings fell out. Well instead of replacing it with a stock unit, i upgraded to the Driveshaft Shop Stage 2 axles. Rated for 650hp i figured they would be more than capable on my stock motor FRS.
Fast forward about 6 months. I'd just arrived in Houston for Wekfest Texas 2014 when i begin to hear the all too familiar axle clicking sound. After quick inspection i notice the two inner cv boots are ripped and all the grease has been flung out of them. My diagnosis is that the joints aren't lubricated enough so i pack in some grease for the long drive back to Louisiana.
Get it home and bring it over to my fabricator, Justin Rosen, at EFI Services in Harahan, LA. I figured while I was over there i would have him install the Powered By Max rear subframe risers and differential risers to help alleviate the angle the axles sit at after lowering the frs.
***Note If you plan on removing the rear subframe bushing to install these solid mounts, I'd suggest skipping the air chisel all together and breaking out the oxygen torch and burning them out. Granted the smell is toxic and bad for you, it worked 10 fold better than any other method.
We begin the teardown on the car and notice that this time it is the outboard CV joint on the DSS axle that is frozen solid. So I'd have to send it back to have them replace or warranty the part, luckily it was warrantied. They aren't cheap.
After installing the risers we noticed that the DSS axles would now hit the subframe right as they were exiting the diff. So out came the grinder and cutter. Justin originally thought that we could notch out a small chunk of the subframe but we later realized that we would have to take out a large portion of it and then weld in new 1/4" plating to reinforce it.
The DSS axle just came back from being serviced and the car should be back tomorrow, when I hope to update this post with how the axles sit now after the risers and notching. Enjoy the crazy, anxious process i went through to keep all the upgraded parts.
Ripped Inner CV Boot
Subframe Dropped
Torching Stock Bushings Out
Clean Bushing Hole
Diff Dropped Out
Welding In PBM Solid Diff Mounts
Raw Finished Result
Front Diff Risers Installed
Notching Process Begins with some Grinding
Initial Subframe Notches
More Grinding
The New Size of the Hole
Sanding to Bare Metal
Ready for Filler Plates
Mocking Up Floor Plate
Floor Plate TIG'd In
After the Sides were Welded In
Comparison
Both Welded In
Notch Back on the Car
PBM Solid Diff Mounts Installed on the Car
Waiting to pick the car up from the shop tomorrow and then I will post pictures of how well the axles sit after being raised and a review on the NVH of the whole setup.
Picture for Reference
QUALITY OVER QUANTITY
ShutterSpeed is offline   Reply With Quote
The Following 4 Users Say Thank You to ShutterSpeed For This Useful Post:
Moto-P (05-26-2017), OmarGC (11-13-2014), THA STI GUY (08-26-2015), Wally86 (06-11-2020)
Old 11-13-2014, 09:32 PM   #2
puma
crew chief
puma's Avatar
Drives: Race car FR-S
nice, thanks for sharing, i installed the same bushings (or lack of bushings) but didn't need to notch the subframe as our axles are stock.
Have you had a problem with the driveshaft? we installed an aluminum driveshaft at the same time and it was too big, it would hit the transmission tunnel and fuel tank, had to lower the diff a little.
puma is offline   Reply With Quote
The Following User Says Thank You to puma For This Useful Post:
Moto-P (05-26-2017)
Old 11-14-2014, 01:29 AM   #3
ShutterSpeed
The driveshaft sits about a half inch away from everything. It'll be interesting to see what happens. Haven't driven the car yet.
The Following User Says Thank You to ShutterSpeed For This Useful Post:
Moto-P (05-26-2017)
Old 11-16-2014, 04:42 PM   #4
ShutterSpeed
Driving Impressions:
Car feels solid. The power feels like it is making to the ground much better now with the solid rear end. The noise and vibration is much less than i thought it would be. There is a whine from the solid diff mounts during acceleration, most notable in higher gears 4-6, but is noticeable in lower gears. The exhaust is just louder than the whine.
Overall i am very happy with the risers and notched subframe. Was definitely worth going the extra mile to do it right. The clearance of the driveshaft and the tunnel is very minimal so i do not believe that a one piece driveshaft from DSS will be possible.
Old 11-16-2014, 05:30 PM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
I'm surprised they didn't use any gussets where the frame was notched.
The Following 2 Users Say Thank You to Calum For This Useful Post:
wparsons (11-16-2014), ZDan (06-11-2020)
Old 11-16-2014, 06:22 PM   #6
Thorpedo
The SquadWhisperer
Agreed with Calum. While it might not make any difference whatsoever, they severely weakened that in a few ways. Not bashing their work, I hope for your sake there aren't stresses that will make it matter. Keep us updated and TBH I would check it fairly often for deformation/cracking.
Beautiful car BTW.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
The Following 2 Users Say Thank You to Thorpedo For This Useful Post:
Calum (11-16-2014), ZDan (06-11-2020)
Old 06-11-2020, 06:30 AM   #7
Alpha_noob
Alpha_noob's Avatar
Drives: Toyota Gt86
This thread is exactly what I needed! Is it possible to just install the subframe risers without the welded solid mount diff mounts?
There's no point in owning an 86 when you like to sell your cars at low mileage
Alpha_noob is offline   Reply With Quote
Old 06-11-2020, 09:49 AM   #8
ZDan
ZDan's Avatar
Drives: '23 BRZ
You've reduced the stiffness of the subframe *tremendously* in that area. On the order of -75% or more. It's worse than that really as the welded plate lines up with voids on either side so no direct load path into the intact front and rear structure. A lot of work for what looks to me to be serious reduction in stiffness and structural integrity. For what? I don't get it...
Old 06-11-2020, 10:15 AM   #9
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Well luckily this was 6yrs ago and the car never exploded, so you don’t need to lose any sleep worrying over it.
Old 06-11-2020, 10:15 AM   #10
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Dat stance lyfe, yo!
Old 06-11-2020, 10:17 AM   #11
TylerLieberman
Drives: '24 GR86
Yes, a few people have done it. Though most of the axle angle correction (if that’s what you’re after) will be gained from the diff risers.
Old 06-11-2020, 10:52 AM   #12
ZDan
ZDan's Avatar
Drives: '23 BRZ
Missed the thread necro...
Still IMO a not great idea extremely poorly executed as far as the basic design. Likely mitigated by more stiffly-mounted front and rear of subframe. But still...
*If* i were to notch the frame there, I'd go with a curved upper plate to of 2x the wall thickness or greater. So front and rear of curved upper meet up with the structures fore and aft.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
soundman98 (06-12-2020), Ultramaroon (08-06-2020)
Old 08-02-2020, 10:27 PM   #13
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
I just went through the same damn process
Wish I would of seen this sooner
Scalzo is offline   Reply With Quote
Tubular rear subframe Manji Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 09-24-2014 09:23 PM
rear subframe bushings? Roadcone Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-09-2014 10:25 PM
REVIEW | DC Sports rear subframe brace / rear subframe lateral brace mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-10-2014 09:59 PM
