Old 07-23-2012, 08:21 PM   #1
vividracing
vividracing's Avatar
Agency Power Exhaust Thread PT II
  • Run#1 153whp 125wtq
  • Run#2 180whp 143wtq
  • Run#3 194whp 150wtq
Run#1 Was a BASE run. Bone stock!
Run#2 Was with the Flywheel and Crank Pulley.
Run#3 Was with Flywheel, Crank Pulley, Header, Crossover pipe, Catback exhaust system.
(STOCK ECU ALL RUNS, 91oct FUEL)
[ame="http://www.youtube.com/watch?v=A63O9TzYroA"]Frs system - YouTube[/ame]
Now we are working on which exhaust parts will give what gains. But since we have a flywheel/crank pulley in the car it is not going to be perfect. Results are also going to change from car to car and area to area. Fuel, Temp and so on.
As I get more info I will post it.
Here are the pictures of the system on the car and a under the hood shot.
Clutch Masters kit,
I have to get the details on the Clutch Masters kit in the morning.
AP light weight pulley
Clutch/Pulley
http://www.ft86club.com/forums/showt...024#post334024
vividracing is offline
The Following 2 Users Say Thank You to vividracing For This Useful Post:
BobDigi5060 (07-27-2012), clayrush (07-26-2012)
Old 07-23-2012, 08:33 PM   #2
karma003
auto-crosser/drifter
karma003's Avatar
Drives: 2013 scion FR-S black M/T
I like how much
karma003 is offline
Old 07-23-2012, 08:39 PM   #3
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
ANYONE post ANY previously what or how shitty Vividracing was or done, I'll delete it. If you don't like them, don't bother commenting, just move along.
K, guys let's make this thread painless as we can.
ichitaka05 is offline
The Following 10 Users Say Thank You to ichitaka05 For This Useful Post:
86design (07-24-2012), civicdrivr (07-23-2012), clayrush (07-26-2012), CoRi J (07-27-2012), denkigrve (07-27-2012), jedibow (07-25-2012), Sportsguy83 (07-23-2012), Starscream15 (07-24-2012), thebear21 (07-24-2012), TPO (07-23-2012)
Old 07-23-2012, 08:40 PM   #4
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Whats the flywheel and specs?
Silverdub is offline
Old 07-23-2012, 08:44 PM   #5
Opposed
Drives: 2013 Asphalt FR-S
Not being negative, just curious. There is a larger increase in whp and wtq from the pulley and flywheel than there is with full header and exhaust. Is caused by specific (Mustang) dyno that's being used? I know a lighter flywheel and pulley can "free" up hp, but I didn't know it showed up that much, if any on a dyno. Is this their pulley or was the Perrin one used?
Opposed is offline
Old 07-23-2012, 08:51 PM   #6
vividracing
I will make another thread for this and link to the 1st post.
Like to keep this about the exhaust.
Old 07-23-2012, 08:51 PM   #7
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
best looking/sounding exhaust so far. cant wait for my catback.
is the catless setup / header throwing a check light? (assuming it is)
wonder if you can trick it with a o2 spacer
Jesse is offline
Old 07-23-2012, 08:54 PM   #8
s2kdrew
Drives: 2013 hot lava FRS
I believe the stock flywheel is too heavy that's why we all have idle issue. I remember when evo x came out it also got the same problem as we do. I could say even worst, but don't know what's the fix for it. Does your shop FRS stop the idle problem after the light weight flywheel??
2013 FRS
2000 S2000
2004 RSX-S
2002 RSX
s2kdrew is offline
Old 07-23-2012, 08:58 PM   #9
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Thats a good one i should of checked after adding the pulley. I ll check tomorrow if it stabilized my idle
Old 07-23-2012, 09:22 PM   #10
drifter
Drives: truck and old car
I noticed it said all runs were done on 91 oct. fuel. Please continue to verify which set-ups are CA friendly, inlcuding CA admissions, smog etc. It will be much appreciated.
drifter is offline
Old 07-23-2012, 09:32 PM   #11
Jesse
wheel gap
Jesse's Avatar
numbers may improve with 93 octane, 200+ whp with bolt ons and a tune seems very plausible... will be awesome in a 2700lb car with good throttle response and no turbo lag.
Jesse is offline
Old 07-23-2012, 09:32 PM   #12
mike2100
mike2100's Avatar
Drives: 23 BRZ
Interesting theory. I was trying to determine earlier today if the crank pulley I installed was keeping my engine from stuttering after falling to idle. It seems to be doing it less, but it did do it once today.
So would Subaru intentionally leave the stuttering issue as is? Perhaps they thought it would motivate people to fix the issue by installing a lightweight pulley and flywheel. And since that mod nets 27 whp it would help spread excitement about the upgradability of this engine. (/conjecture)
mike2100 is offline
Old 07-23-2012, 09:53 PM   #13
xjohnx
Grip>Slip
xjohnx's Avatar
Can you dyno the exhaust on a stock car? (Read: no flywheel/crank pulley)
xjohnx is offline
Old 07-23-2012, 09:57 PM   #14
os86
Drives: 2jz
This is what I am interested in.^^^^
Originally Posted by vividracing View Post
Run#1 153whp 125wtq
Run#2 180whp 143wtq
Run#3 194whp 150wtq
(STOCK ECU ALL RUNS, 91oct FUEL).
So am I right in assuming this that you gained 14whp with the addition of exhaust ,headers and midpipe ?
There seems to be so much conflicting information about your exhaust and I just need some clarification from you .
Thanks and Yes I might be keen
os86 is offline
Agency Power Exhaust for the BRZ/FR-S at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 5 07-23-2012 11:57 PM
Agency Power Exhaust vividracing Engine, Exhaust, Bolt-Ons 17 07-23-2012 02:40 PM
Agency Power Exhaust | Best Price Anywhere IslandImportPerformance Engine, Exhaust, Bolt-Ons 13 07-21-2012 10:50 AM
Agency Power Exhaust in the works! PrimeMotoring Engine, Exhaust, Transmission 67 07-17-2012 06:57 AM
