Old 06-09-2020, 02:34 AM   #1
DaddyJalen23
Drives: 2020 Toyota GT86 Hakone Edition
Crack in intake box
Just got a 2020 And this box connected to where the engine air filter is cracked. Should I be worried? Is this causing leaks or damaging my engine and should it be replaced?
DaddyJalen23 is offline   Reply With Quote
Old 06-09-2020, 02:41 AM   #2
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
I would definitely take it back to the dealer and have them replace it. Its a 2020 should be under warranty.
Sent from my SM-G973U1 using Tapatalk
Oxyg3n is offline   Reply With Quote
Old 06-09-2020, 04:20 AM   #3
Welcome to our group -
I agree, it should be replaced under warranty.
Meanwhile, I'd suggest you just duct tape it up.
Old 06-09-2020, 08:32 AM   #4
That is the resonator and it's sole purpose is to make noise. It does enter into the "dirty" side of the filter so not sucking in dirty air.
But...
It has been demonstrated that having it opens messes with sensors to some extent.
https://www.ft86club.com/forums/show...&postcount=295
And...
It is a brand new car that should not be broken so get it fixed. That is a pretty tough piece of plastic so I am very curious how it was damaged in the first place!
Old 06-09-2020, 10:00 AM   #5
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
But...
And...
Yeah not sure how that got broken like that. I've had lots of them damage that bad and worse but it's taken the cars crashing into something to do it..
Maybe resting ones weight on it while cleaning/checking something?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-09-2020, 10:04 AM   #6
Old 06-09-2020, 02:03 PM   #7
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Hopefully they will replace that under warranty for you and not deem this as you fiddling around under the hood and breaking things.
N1rve
Old 06-09-2020, 02:19 PM   #8
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
First off, it's before the filter so no worries driving with it.
I'm having a hard time seeing how it broke from leaning on it. that resonator is supported on the other side and it's pretty sturdy.
Old 06-09-2020, 05:25 PM   #9
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
It actually looks more like someone yanked upwards on it rather than pushing it down.
Old 06-09-2020, 08:11 PM   #10
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
That's not true.
https://www.brighthubengineering.com...ic-efficiency/
Old 06-09-2020, 08:18 PM   #11
Originally Posted by RZNT4R View Post
That part in the Twins is most decidedly NOT a Helmholtz resonator.
I did provide a link showing the tiny effect it has on performance.
Old 06-09-2020, 08:27 PM   #12
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Technically, it won't do much, if any harm having it open there. It's upstream of both the filter and the MAF.
Only obvious drawback is that you're going to be pulling in hot air from the engine bay (hotter intake air, heat soak, lower performance).
Get them to replace it, or replace it yourself. Alternatively, plug the hole.
EndlessAzure is offline   Reply With Quote
Old 06-09-2020, 08:35 PM   #13
soundman98
ProCrastinationConsultant
soundman98's Avatar
too bad the pictures don't work anymore
Old 06-10-2020, 04:07 PM   #14
Kodename47
Kodename47's Avatar
Drives: UK GT86
Barely. You can see where the plastic has snapped and is still on the resonator. If you bolt it back together with the resonator in, it will be barely different to stock as they aren't sealed anyway.
.: Stealth 86 :.
Kodename 47 DJ:
Windshield Crack Repairable? wangson Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 04-29-2020 12:41 PM
What should i do with this crack? Yipzus Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 02-06-2019 12:21 AM
Crack in My ofh FISHBURGLAR Engine, Exhaust, Transmission 55 05-07-2017 03:02 PM
weird windshield crack uEih Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 26 12-21-2013 12:03 AM
Crack in the glass.. Miss_Red Scion FR-S / Toyota 86 GT86 General Forum 54 02-27-2013 01:06 PM
