Old 06-07-2020, 12:24 PM   #29
soundman98
ProCrastinationConsultant
soundman98's Avatar
or perhaps attempt getting out of the car in a way that doesn't resemble a grocery bag falling out?
humfrz (06-07-2020)
Old 06-07-2020, 12:52 PM   #30
p1l0t
p1l0t's Avatar
I'm highly offended by this post. I have had my car for 4 years now and I still haven't figured a graceful way in or out.
humfrz (06-07-2020)
Old 06-07-2020, 12:57 PM   #31
soundman98
soundman98's Avatar
it's a parkour move!
@1:44:
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
NWFRS (06-07-2020), p1l0t (06-07-2020)
Old 06-07-2020, 01:05 PM   #32
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
Jump over the iron fence at the beginning made my @$$H013 pucker.
NWFRS is offline   Reply With Quote
Old 06-07-2020, 01:09 PM   #33
soundman98
soundman98's Avatar
it's a little too staged for my preference. who keeps an airbag outside their bedroom inflated all the time?!?
Old 06-07-2020, 01:14 PM   #34
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
And why didn't he set an alarm?
I'm beginning to wonder if he woke up late on purpose.
The Following 2 Users Say Thank You to NWFRS For This Useful Post:
p1l0t (06-07-2020), soundman98 (06-07-2020)
Old 06-07-2020, 01:22 PM   #35
p1l0t
p1l0t's Avatar
Honestly since I threw out my alarm my quality of life has improved 10x.
Old 06-07-2020, 01:26 PM   #36
soundman98
soundman98's Avatar
now that can just loot for what i need, i no longer need a job either!
The Following 4 Users Say Thank You to soundman98 For This Useful Post:
humfrz (06-07-2020), NWFRS (06-07-2020), p1l0t (06-07-2020), Tcoat (06-08-2020)
Old 06-07-2020, 01:29 PM   #37
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by nickson555 View Post
I'm 5'8 170 pounds and I'm careful entering and exiting the vehicule. I turn and try not to touch it. I'm not wearing any metal ever. Right side is flawless because it's difficult to drive from that side especially with manual transmission so I mostly use the left seat 99.9% of the time. The seat portion of the side still looks perfect though. Why? The back is even torn where my back doesn't touch the seat at all at the top portion and at the bottom where it's impossible to reach.
Is there a part number I can order to replace only the seat cover, back portion? It's hard to find? Thank you!
You can get a free "fat check", the service is available 24/7 on this forum..
The Following 2 Users Say Thank You to JD001 For This Useful Post:
Old 06-07-2020, 02:41 PM   #38
soundman98
soundman98's Avatar
JD001 (06-07-2020), p1l0t (06-07-2020)
Old 06-07-2020, 03:18 PM   #39
booooooo..............
Old 06-07-2020, 03:24 PM   #40
Ya, I hear that!
Even if I can get the door all the way open, when I exit by trying to pivot on my left arm/wrist, I have to do this quick shuffle if my feet, which spins my body, out and along the side of the car.
I have learned not to make eye contact with anyone standing around - so as I don't feel soo bad -
Old 06-08-2020, 09:23 AM   #41
nickson555
Drives: 2015 Subaru BRZ Limited
Maybe trying not to touch the seat bolster is even more damaging to it? The seat section of the side still looks absolutly brand new when the bolster side leather is worn and the vinyl stiching is cut every inches.
I would like to get after market seats but it turn out quite expensive with the rails.
The reason I lost my temper at the seat and peeled the vinyl when I got my car back apart from the refusal to take car of it is because once, they had to change the throw out bearing and when i got the car back I got that huge loose in my shifter when moving it left right. I was mad. Clearly, they forgot/lost a bushing when installing it back on. It took 4 visits to fix it and now I have another problem with it again not long after. It wont properly return to center so it's not unlocking form reverse or going easily into third. I installed the Perrin back bushing shifter thinking it might fix the problem without going to them but it did not at all. Then when I got my car back they didn't fix the problem at all and they charged me for it. They also charged me again by mistake for a check engine check.
nickson555 is offline   Reply With Quote
Warranty question: Tear in BRZ seat leather BRZGary Issues | Warranty | Recalls / TSB 22 08-05-2016 08:40 PM
Warranty Work With Mods + Extended Warranty Wyattkb Issues | Warranty | Recalls / TSB 3 01-20-2015 04:23 PM
Extended Warranty? huangddg84 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 33 11-03-2014 01:50 PM
Where should we go to buy extended warranty? qqzj BRZ First-Gen (2012+) — General Topics 8 02-25-2014 12:43 PM
Extended Warranty? FoxtrotRomeo-Sierra Scion FR-S / Toyota 86 GT86 General Forum 4 05-31-2012 01:02 PM
