Old 05-27-2020, 12:29 PM   #43
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
If you guys want to (somewhat) protect the battery from discharge when the car is sitting; winter, at the airport, etc, you can swap a fuse in the fuse box that will kill all of the "always on" devices that cause parasitic draw. This is the same fuse that is moved during the PDI process. Car will still start, but keyless remote, A/C, radio and several other features do not work when this fuse location is swapped. See below for what fuse, move from position A to B when car is not being regularly used (A = empty, B = fused), to return the car to normal operation move fuse from position B to A, (A = fused, B = empty)
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 7 Users Say Thank You to Opie For This Useful Post:
AKITA (05-27-2020), Dave-ROR (05-27-2020), ls1ac (05-28-2020), Overdrive (06-05-2020), Sapphireho (05-30-2020), soundman98 (05-27-2020), why? (05-31-2020)
Old 05-27-2020, 02:43 PM   #44
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
Originally Posted by COBlue View Post
My '17 is showing 0.47a parasitic drain - curious what other people are seeing?
It sat for 13 days and was dead - even with a warranty replaced bigger battery last year. The Maestro RR/Pioneer setup I have had parasitic drain issues but supposedly wiring/firmware fixed that. (https://www.ft86club.com/forums/showthread.php?t=131462)
I know that's a relatively high drain, but this is my first car that's always "looking" for a key fob etc so don't know what's normal parasitic drain in these.
Did you allow 20-30 minutes for all your computers to go to sleep when checking for the draw?
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
Old 05-28-2020, 01:50 PM   #45
COBlue
COBlue's Avatar
Drives: 2017 Subaru BRZ Limited PP
Yeah, it had been sitting for a couple days at that point.
COBlue is offline   Reply With Quote
The Following User Says Thank You to COBlue For This Useful Post:
Ernest72 (05-29-2020)
Old 05-30-2020, 03:12 AM   #46
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
When my 2017 brz was just over a year old, I went on vacation in Asia for 3 months and was surprised that it fired up instantly when I came back. By the end of year 3, it was completely useless, I would be afraid to leave the ignition in the on position for anything more than a minute or two.
Good thing I was able to have Subaru upgrade me to their Subaru branded 550cca. I think the stock one was like 380cca? Smh
Oxyg3n is offline   Reply With Quote
Old 05-31-2020, 11:31 AM   #47
COBlue
COBlue's Avatar
Good information - thank you!
But for now I'm ok with normal drain - it's my DD so normally not an issue, I'm just not working right now so it's been sitting.
Just curious what's a "normal" parasitic drain so I know if I might need to hunt down a unique (likely Maestro) drain.
Opie (06-01-2020)
Old 05-31-2020, 11:40 AM   #48
soundman98
ProCrastinationConsultant
soundman98's Avatar
usually no more than 500mA is considered typical.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
ActionMaxon (05-31-2020), COBlue (05-31-2020)
Old 05-31-2020, 11:45 AM   #49
COBlue
COBlue's Avatar
Ok, so I'm right there at 470mA - thanks, I won't bother hunting fuses or pulling my radio out for the umpteenth time then.
I do have a trickle charger, but sounds like a good excuse for more regular pleasure drives.
soundman98 (05-31-2020)
Old 05-31-2020, 12:27 PM   #50
Ernest72
This is what I do. It’s the best way, get out on some mountain curvy roads.
The Following User Says Thank You to Ernest72 For This Useful Post:
COBlue (05-31-2020)
Old 06-01-2020, 10:17 PM   #51
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
500??
I think you mean 50 mA.
When I was in automotive school 10 years ago, we learned 30 mA but that has gone up in today's vehicles. 50-60 mA today is okay. 500 mA is a problem
https://www.optimabatteries.com/en-u...parasitic-draw
https://www.yourmechanic.com/questio...-battery-drain
After you go in line between the battery and terminal though, you wake up some systems, did you wait some time after hooking up your meter for those systems to go back to sleep?
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 06-01-2020, 11:08 PM   #52
soundman98
soundman98's Avatar
you're right. i believe i was originally told it was 100mA absolute max. i don't recall ever hearing a number lower than that before.
but some of it could have to do with the resolution accuracy of older test meters...
Old 06-01-2020, 11:16 PM   #53
COBlue
COBlue's Avatar
Originally Posted by NARFALICIOUS View Post
500??
50 sounds more reasonable, but I've never tried a newer car "listening" for key fob etc.
I did not wait after putting the meter on, I'll try that. Regardless, 13 days is awfully fast to completely drain a battery, but I know a lot of folks seems to have issues with this car doing that.
Old 06-05-2020, 03:34 PM   #54
COBlue
COBlue's Avatar
FWIW - haven't tried checking the parasitic draw again yet because in the middle of another experiment:
Day 1 - 12.65V (immediately after trickle charge top off)
Day 2 - 12.48V
Day 3 - 12.44V
Day 4 - 12.41V
Day 5 - 12.38V
Day 6 - 12.36V
Day 7 - 12.34V
Old 06-12-2020, 01:56 PM   #55
COBlue
COBlue's Avatar
This test day 13 down to 12.1V, started up just fine so not sure what happened last time. I'll keep the battery jumper in there in case but good to know a couple weeks shouldn't be a problem. Off to the track. :-D
Covid Lockdown Activities Boomerang Off-Topic Lounge [WARNING: NO POLITICS] 1471 09-29-2020 03:38 PM
PERRIN Steering Rack Lockdown PERRIN_Mladen Brakes, Suspension, Chassis 30 06-10-2018 05:45 PM
Steering Rack Lockdown/Bushings Apex_BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-18-2014 01:01 PM
Perrin Steering Rack Lockdown: Anyone Have Experience? TouchMyHonda Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-20-2014 01:27 PM
