Old 06-03-2020, 11:15 AM   #1
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Help! STI push start button / Ignition switch
I Want to get the red PSB/IS for my 2019 BRZ limited.
Did a search and got confused with so many part # for the JDM STI and USDM versions.
Do not need the indicator light (like the wrx) but it would be great if the letters light up when you turn on the car.
The STI (latest) Part# ST83031ST031
and the US Subaru part # 83031CA023 are the latest part numbers I found.
1) Any difference between them?
2) Both will fit me AT 2019 limited -plug and play?
3) Do the letters light up when turning on the car or when the dome light is on?
I was aware of some topics and replies regarding the PSB, but there were so many numbers around and most of the posts were kind of old.
Thanks (Would really appreciate if you can share some pics)
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
The Following User Says Thank You to Busybee For This Useful Post:
Plumbus (12-12-2020)
Old 06-03-2020, 12:03 PM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
The lights on the CA023 come on with the lights. I assume the ST031 is the same.
Also, a little cheaper here
The Following 3 Users Say Thank You to dragoontwo For This Useful Post:
Busybee (06-03-2020), Plumbus (12-12-2020), Yoshoobaroo (06-03-2020)
Old 06-03-2020, 12:24 PM   #3
Busybee
Busybee's Avatar
Thanks. Any idea if they used this one in the 2020 ts ?
Thanks
Old 06-03-2020, 12:29 PM   #4
dragoontwo
dragoontwo's Avatar
Thanks
Yes. It is listed under the fitment on the site I linked.
Old 06-03-2020, 04:27 PM   #5
dragoontwo
dragoontwo's Avatar
So, I was wrong. The button lights up when the car is on, not with the lights.
Edit- Seems I may have been fooled by having my sun shade on.
Will need to play around with it a bit.
The Following User Says Thank You to dragoontwo For This Useful Post:
Old 06-03-2020, 08:44 PM   #6
norcalpb
norcalpb's Avatar
I have the original JDM STi start button and the “STi” logo lights up when I put my hand on the door sensor. Sometimes even when I’m walking by the car. I think it stays lit regardless if the headlights are on, and will turn off when I lock the car.
The Following User Says Thank You to norcalpb For This Useful Post:
Busybee (06-04-2020)
Old 06-04-2020, 01:16 AM   #7
ItsReiko
ItsReiko's Avatar
Drives: 2017 subaru brz
I just ordered the 83031CA023 yesterday for my US 2017 Brz Limited. Hopefully it works with no problems. Interested to find out though if this is the actual module that senses and connects with your individual key fob.
ItsReiko is offline   Reply With Quote
The Following User Says Thank You to ItsReiko For This Useful Post:
Old 06-04-2020, 01:30 AM   #8
Busybee
Busybee's Avatar
Please, let us know if you have the similar function that Norcalpb’s JDM has. Thanks
Old 06-04-2020, 01:46 AM   #9
ItsReiko
ItsReiko's Avatar
Function as to when the lights turn on? I would suspect that it operates the same as how the stock black push button works.
Old 06-04-2020, 08:34 AM   #10
dragoontwo
dragoontwo's Avatar
I messed about with mine a bit. It does come on when unlocking and getting into the car. If the lights are off it does turn off when you start the car. It lights up with the headlights, and has a delay to turn off when the lights are turned off.
Old 06-04-2020, 09:31 PM   #11
Busybee
Busybee's Avatar
Then It's very similar to the stock black PSB.
Old 06-05-2020, 02:55 AM   #12
spike021
spike021's Avatar
It works exactly the same way, the only difference is the lettering is different and so the backlighting is obviously different from the black button. Functionality is the same though.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following User Says Thank You to spike021 For This Useful Post:
Busybee (06-16-2020)
TRD Push Button Start boxer_boy Want-To-Buy Requests 0 08-02-2017 05:26 PM
TRD Push Start Button MNGBRZ Interior Parts (Incl. Lighting) 4 06-18-2015 04:11 PM
Push-button start clutch switch mike the snake Engine, Exhaust, Transmission 8 04-15-2014 12:31 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 07:06 PM
Aftermarket Push Button Ignition Smart Entry System zAnSh1n Electronics | Audio | NAV | Infotainment 75 08-19-2012 03:23 PM
