Old 06-02-2020, 11:10 PM   #1
isaiah990
Drives: Scion FR-S
Help!!! LOST Wheel Lock Key
I lost the key to my locking lug nuts and need help figuring out which key to get! I bought a key, but it was too small. I’m trying to remove the wheels so I can replace the brake pads ASAP. I have a buyer waiting for the car!! Any help is appreciated thanks!
UPDATE: Thanks everyone! I took it to my local wheel shop and they were able to remove them!
isaiah990 is offline   Reply With Quote
Old 06-02-2020, 11:12 PM   #2
p1l0t
p1l0t's Avatar
Just sell the car.
Old 06-02-2020, 11:16 PM   #3
isaiah990
Drives: Scion FR-S
Hahahaha I’m actually the one buying it, I just posted for the owner, any help is greatly appreciated!!
Old 06-03-2020, 12:30 AM   #4
You might consider taking the car into an automotive shop, maybe they can rattle it off.
Bubba says he can take it off with a cold chisel and a BFH -
Old 06-03-2020, 04:40 AM   #5
Any tire shop will have something to work.
Old 06-03-2020, 05:55 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
tire shops usually have 2 immediate methods of removal.
1. they rummage through a random box of assorted wheel locks that have gone missing under mysterious circumstances over the years until they find the one that works.
2. they keep a bunch of high quality full-replacement-warranty sockets on hand. they beat the nearest size on with a hammer, and then impact it off, discarding the lug, and warrantying the socket for next time.
or, if you're me, you buy aluminum lug nuts because they look pretty, they seize onto the studs due to the miracle of galvanic corrosion, and the only way out is to use an air hammer with a splitter end, and split the lug off, like splitting wood... i actually sold the car before doing anything with it.
Old 06-03-2020, 06:11 PM   #7
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
In the old days, we had to weld a nut to the end!
Really though, bring it to a shop with the intent to buy new ones
Old 06-03-2020, 07:21 PM   #8
ls1ac
ls1ac's Avatar
There is a set of tools for removing stripped nuts or bolts. They look like sockets but are meant to be tapped on and then wrenched off. The only possible problem could be the tool wall thickness as these are deep set.
I just lost 1 pcs of adhesive weight on the wheel mitama Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 07-31-2019 03:52 PM
East Bay NorCal: OEM Wheels, free wheel lock set and wheel totes akacinna Wheels and Tires 2 05-07-2018 12:53 AM
Help! Lost Wheel Lock Key DonAngeloDM Northern California 4 04-28-2016 02:10 AM
Lost wheel lock nut - what to do next? Trikle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-17-2015 12:55 PM
Wheel lock on only one per wheel: unbalanced? stocktc1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 03-24-2013 11:37 AM
