Old 05-31-2020, 10:07 AM   #43
Gamace
Gamace's Avatar
Drives: 2012 Toyota 86
Originally Posted by saltywetman View Post
use google translate camera function. it really helped translate the japanese TRD instructions to install the aero kit. I find the camera feature works better than copy pasting actual text from the pdf over into google translate
I realized that the pdf translation does not work for me. So I had to use the camera function as you said.
Sent from my SM-N975U1 using Tapatalk
Gamace is offline   Reply With Quote
Old 06-02-2020, 12:09 PM   #44
Gamace
Gamace's Avatar
Where do you install the Thermashield that comes with the HKS Header?
Old 06-02-2020, 04:12 PM   #45
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
Not really sure you need that to be honest. Can you let me know where you got your HKS UEL header? Looking to buy one.
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 06-02-2020, 04:41 PM   #46
tomm.brz
Drives: brz 2017 hksv2
Oil pan
Old 06-02-2020, 04:47 PM   #47
Gamace
Gamace's Avatar
I got it from FT86SPEEDFACTORY.COM. They're on back order now though but I got one out of the last remaining three (3) they had in stock at the time lol.
Old 06-02-2020, 04:48 PM   #48
Gamace
Gamace's Avatar
Originally Posted by tomm.brz View Post
Oil pan
I saw this is in another post. Gonna check back the instructions to see if it specifically mentioned that to confirm.
Old 06-02-2020, 05:23 PM   #49
x1UP
One & Done (AOZORA)
x1UP's Avatar
Damn lucky! I asked them when they would be back in stock and they said it's on backorder and has a wait time of 150 days...
Old 06-02-2020, 06:47 PM   #50
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Have you looked at other places? I think Kamispeed has them; idk about in stock though.
MS, CSCS, TSAC-F, CPT
Old 06-02-2020, 06:59 PM   #51
Gamace
Gamace's Avatar
Wow....5 months. That's what I was afraid of. So I made sure to close my eyes and click buy before others decided to purchase it lol.
The Following User Says Thank You to Gamace For This Useful Post:
x1UP (06-02-2020)
Old 06-02-2020, 09:50 PM   #52
x1UP
One & Done (AOZORA)
x1UP's Avatar
I checked FRSport and they said the same thing. I tried Kamispeed, but it looks like they're away until tomorrow. It does say on their website that it's made to order and over 4+ weeks though.
Really can't find it anywhere else either.
Old 06-04-2020, 01:05 AM   #53
tomm.brz
Man if told you that is because i had those header, i translated instructions, i installed them and run them for 2 year
i even dynoed them
you can minimize instructions in:
-put thermal adesive on your oil pan, cutting it to shape it
-use the Grey extension to extend front primary lambds, which will go directly to the exit of the header while the second lambda goes to the single runner' hole
stop. They aren t different from any other header just becuase they got a 20pages Manual of use with them
in fact, they are quite shitty performing, cat is too small and useless and only blocks the relative small exit they got
Yes sound is cool... but tomei UEL are better in every way if you want UEL at all costs
They are good at keeping value, even if most people would not buy them
it took me another 2 years to actually sell them to someone in Europe
Old 06-04-2020, 01:20 AM   #54
Gamace
Gamace's Avatar
i even dynoed them
Thank you for the tips!
Can I tell you, I was going for Tomei UEL at first but I feel it causes some rasps in some exhaust setups since its catless and then its louder as well. I guess I wanted to get a catted header to be on the safer side in terms of volumes and emissions. Plus the Tomei is even cheaper too but I'm hoping the rumble will make the HKS worth it!
But I don't care too much about the gains more than that rumble which you will get from others. I was impressed by the HKS Packages, as those to me are the best rumbles for this platform.
Toyota 86 in the building!
tomm.brz (06-04-2020)
Old 06-04-2020, 01:27 AM   #55
tomm.brz
that was sound of my car
mind you it s all hks, but the midpipe.. it s stock
dyno
bolder lines are HKS boxer spec header with stock oem My17 tune
thinner lines, tune @ knock limit with 100ron
same day we dynoed and tuned similar car but with Skunk2 EL 4-1 header, it got 12whp more from 6000 rpm to redline, but 10whp less at 4k rpm
This dyno gives 173bhp only for stock cars
Old 06-04-2020, 01:44 AM   #56
Gamace
Gamace's Avatar
dyno
Very interesting. I can hear the pure rumble from the setup. Not bad at all. I am not changing my over pipe or front pipe. Just sticking with the requirements for the deep package: HKS Hi-Power Spec L Catback Exhaust and HKS UEL.
I am still on the fence about the over pipe, whether its necessary or not. I think the description of it says its for racing applications.
Loud exhaust / Buddy Club Spec II exhaust help! chiefshayan Engine, Exhaust, Transmission 26 12-06-2019 06:59 PM
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 10:30 PM
Exhaust header / manifold gaskets (Subaru part number) ft_sjo Engine, Exhaust, Transmission 1 07-15-2013 10:24 AM
Need factory exhaust manifold dorifuto Engine, Exhaust, Transmission 1 01-24-2013 02:05 PM
Rwd-boxer's backyard exhaust fix RWD-boxer Engine, Exhaust, Transmission 9 06-11-2012 07:15 PM
