Old 06-02-2020, 03:06 AM   #3529
jayjay06
Drives: 2016 Scion FR-S RS 2.0
Yeah, 60-80lb range I think.
Edit:
60lbs manifold
81lbs total parts
Per:
https://www.ft86club.com/forums/show....php?p=2406569
Sent from my Pixel 3 XL using Tapatalk
jayjay06 is offline   Reply With Quote
The Following User Says Thank You to jayjay06 For This Useful Post:
BR-ZED (06-02-2020)
Old 06-02-2020, 08:25 AM   #3530
BR-ZED
BR-ZED's Avatar
Drives: 2014 WRB BRZ Limited
Originally Posted by jayjay06 View Post
3. I tried using the no spill funnel, but of course mine didn't come with the right attachment to fit the surge. So I just turned key to on to get pump running and kept filling it up. It sucked it down a couple times, so just started over. I'm sure I had a little air in there, but if you read line 8 of the purge, it notes over time the air will escape into the surge. I had to add coolant after a couple times running, so that tells me air is purging.
Which one did you order? I want to make sure I get a different one then lol. Saw a handful on Amazon. If the one I get fits I'll report back here
BR-ZED is offline   Reply With Quote
Old 06-02-2020, 01:13 PM   #3531
toast
Drives: 14 BSP Edelbrock BRZ
Originally Posted by Kodename47 View Post
Why get a second TMAP? Why not just an IAT sensor, likely to be cheaper....
I don't know what the response curve of whatever IAT sensor you might buy is, I do know that the tmap sensor response curve is what is expected by the tune.
Saving $20 isn't worth having to have the tune adjusted.
toast is offline   Reply With Quote
Old 06-02-2020, 01:13 PM   #3532
jayjay06
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The radiator cap fit the radiator fill for doing the JR Dual Rad/OC, but none of the caps worked for the surge tank on Edelbrock LTR.
BR-ZED (06-02-2020)
Old 06-02-2020, 06:18 PM   #3533
Kodename47
Kodename47's Avatar
Drives: UK GT86
My IAT sensor uses the same curve as OEM (I believe it's Bosch), so do most Bosch TMAPs that I'm aware of.
In fact, after a quick search part number 0 280 130 085 has an identical output to their TMAPS and is the same wire type as I run.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-03-2020, 10:07 AM   #3534
Hikari1
Hikari1's Avatar
Drives: 2016 BRZ Hikari
Anyone else had any issues with LSPI? I've had my kit on for about a month now, tuned by delicious about a week after running the supplied Edelbrock tune, I noticed a bit of light bogging around 2000RPM under light acceleration, like 10%. Talked to Bill and he almost immediately sent me some documentation on the heart of the issue as well as a revised tune. It seems to have gone away now.
Overall my experience with the kit was super easy, managed to get it on with 1 helped over the course of 8 hours, spent the next day topping up fluids and bleeding stuff. Delicious was fantastic as well, I can't recommend Bill and Nazar enough.
I've got the kit combined with Tomei UEL header, Tomei Overpipe, HKS dual resonated front pipe, and FT86SF V1 exhaust. Previously ran an Invidia catless front pipe and if I so much as even looked at the throttle pedal I heard the sound of a thousand murder hornets coming from the exhaust. Sounds much better since the HKS front-pipe, hoping the welds don't crack...
2016 BRZ Hikari Edition
@BRZHikari1
Build Thread:
http://www.ft86club.com/forums/showthread.php?t=107326
Hikari1 is offline   Reply With Quote
The Following User Says Thank You to Hikari1 For This Useful Post:
BA9092 (06-03-2020)
Old 06-04-2020, 02:41 AM   #3535
CSG Mike
CSG Mike's Avatar
You shouldn't have any LSPI issues whatsoever. If that occurs, that's a tuning error.
However, downshift. The engine doesn't like being loaded up at low rpms.
Old 06-04-2020, 02:58 AM   #3536
tomm.brz
Drives: brz 2017 hksv2
No critique here, but if he was tuned by delicious before the LSPI modification they did on lates version... he was then probably tuned by your actual company tuner!
LSPI is legitimately hard to keep off with boost on this car with stock compression ratio, unless you heavily retard ignition timing on transient (and you feel this temporary lack of torque somehow) and possibly play with PI injection timing
Are the newer sn+/dexos2 oils really as helpful for LSPI as they claim anyway? normally i use 0w40 but there isn t any with that rating
Old 06-04-2020, 03:37 AM   #3537
CSG Mike
CSG Mike's Avatar
There was never any LSPI to begin with
I'd find it difficult to believe an oil can somehow influence what's going on in the combustion chamber of a healthy engine.
Old 06-04-2020, 03:46 AM   #3538
tomm.brz
well, then you mean you re stating you re sure his Delicious tune that is presenting LSPI knocks was nt done by Zach, even if Zach was probably the main tuner at that time
Also, oil is going to be mixed somehow to the charge as soon as DI fires up, so it becomes parts of combustion
Old 06-04-2020, 03:52 AM   #3539
CSG Mike
CSG Mike's Avatar
How?
Old 06-04-2020, 04:11 AM   #3540
tomm.brz
How?
just 2 first links on google are good to me
https://www.jstor.org/stable/26278010?seq=1
https://www.sae.org/publications/tec.../2015-01-2811/
also, both Zach and Delicious use earlier DI injection , earlier also than stock, for high load and medium and high rpm while keeping PI fixed @360 degrees that causes surely more impingment on pistons?
it's true though that LSPI = lower rpm and there there is always later injection, but
if charge can dilute oil film and go past ring seals, then oil film can dilute charge to me
Old 06-04-2020, 04:41 PM   #3541
CSG Mike
CSG Mike's Avatar
Accurate articles, but not really applicable as LSPI primarily is for low rpm high boost, as stated directly in your linked publications. An edelbrock is not trying to push 1bar+ at 2500 rpms. It's barely making perhaps 0.2 bar, being generous.
tomm.brz (06-05-2020)
Old 06-04-2020, 11:28 PM   #3542
devtec
Drives: 2015 Subaru BRZ Limited
Just an update on the MAP sensor relocation re fuel economy. My commute is about 80/20 highway/city and 20 miles each way.
Previous to MAP relocation: 25.8mpg
After MAP relocation: 30.7mpg
Bone Stock before s/c: 28.5mpg
I know the fuel economy indicator isn't the most reliable, but the delta does seem real.
devtec is offline   Reply With Quote
The Following User Says Thank You to devtec For This Useful Post:
CSG Mike (06-05-2020)
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
