Old 05-15-2020, 09:51 PM   #155
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Work Emotion CR Kiwami Ultimate 17x9+38
Confirmed to fit on Performance Package Brembos as-is
EndlessAzure is offline   Reply With Quote
Old 05-19-2020, 03:13 AM   #156
bp servo
Drives: 2017 brz sports pack
would the rota mxr-r 18x9.5 +38 fit
bp servo is offline   Reply With Quote
Old 05-19-2020, 08:01 AM   #157
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by Yoshoobaroo View Post
What clearance do we need to the caliper to claim they fit? 3mm? 5mm?
Is minimum spoke clearance different than minimum barrel clearance?
I found an answer at Tirerack:
For the next inspections it will be necessary to temporarily install the wheel by snugging down the lug nuts or bolts in order to verify disc brake caliper clearance. You should have at least 3-4mm of clearance between your wheels and the brakes on the vehicle.
Old 06-02-2020, 11:13 AM   #158
N_Raged
Drives: 2019 BRZ Sport-Tech RS
Enkei PF05
Enkei PF05 fit.
17x9 +40 plenty of clearance:
https://minkara.carview.co.jp/userid...175/parts.aspx
Not sure what this size is:
http://tk-yamaguchi.com/archives/10394/
17x8.5 +48 seem to fit:
https://www.fujicorporation.com/shop..._review=56209#
18x9 +42 plenty of clearance (Enkei's site only lists +40 for 18x9, dunno where this person got +42 from):
https://www.fitmentindustries.com/wh...-kw-suspension
I wish these came in black and 17x8 +45.
N_Raged is offline   Reply With Quote
Old 06-03-2020, 04:27 PM   #159
gpvecchi
gpvecchi's Avatar
Anyone knows if Work Emotion CR Kiwami 18x8.5+47 fits?
Old 06-04-2020, 05:14 PM   #160
STI-ish
STI-ish's Avatar
Drives: 13 BRZ Sport Tech Turbo
Gracm Lights 57CR 18x9.5 +38 cleared by ATS brembos with loads of space
Sorry the bottom 2 photos are sideways...just turn your head lol
STI-ish is offline   Reply With Quote
Old 06-09-2020, 07:21 AM   #161
boxan59
Drives: Subaru BRZ 2013 Limited
RAYS 57XTREME Gramlight's
Front: 18x8.5 ET42 (12MM Spacers) 245/40/18
Back: 18x9.5 ET44 (No Spacers) 235/40/18
Do not ask about tires size, it happened.
boxan59 is offline   Reply With Quote
Old 06-10-2020, 01:45 AM   #162
cirros
Drives: 2018 Subaru BRZ tS
Wheel Name: Sparco Trofeo 5
Wheel Size: 17x7.5 +48mm
Wheel Weight: 19.85 lbs
Wheel Construction: 1pc gravity cast
Tire Name: Bridgestone Potenza RE-71R
Tire Size: 245/40R17
The wheels were to comply with SCCA C Street rules, so the tires are wide for the wheels. After a full season of autocrossing and 1 track day, there is no sign of rubbing on the sidewall and the strut.
cirros is offline   Reply With Quote
Old 06-14-2020, 10:11 AM   #163
Bearbones
bearbones
Bearbones's Avatar
Drives: 2018 Red BRZ with PP
Titan 7 5S 17x9 offset +37. Loads of clearance for calipers. A little tight with front spring perch but still clears. Wheels are 16.8 lbs. Tires are 245/40 17. Great looking affordable forged wheels. Light and strong.
Bearbones is offline   Reply With Quote
The Following User Says Thank You to Bearbones For This Useful Post:
juenedgi (06-17-2020)
Old 06-14-2020, 11:09 AM   #164
soundman98
ProCrastinationConsultant
soundman98's Avatar
do you have more pictures of the oem spring clearance? this was the setup i've been looking at, but it looked really close to the spring perch...
Old 06-14-2020, 06:56 PM   #165
spike0
Drives: 2020 BRZ Sport-Tech RS (PP)
Fast Wheels FC04 in 17x8.0 +40 clear. Nice, cheap and light (17lbs) flow formed wheel. I little stretched with the stock 215/45/17 Primacy.
spike0 is offline   Reply With Quote
Old 06-14-2020, 09:14 PM   #166
Bearbones
bearbones
Bearbones's Avatar
Here are a few pictures of the clearance with and without tires. Could not really measure, but you can see that there is decent clearance for this setup. I am on Eibach prokit springs, so lowered 1 inch, and have factory alignment settings. I plan to get a little more negative camber all around for autocross, but not sure how much the clearance will allow. I would bet I can still get 1.5-2 degrees. I weighed the OE wheel/tire, and the new set up for comparison, and they were almost identical (about 45 pounds total). So, I widened the wheel/tire setup significantly without adding any weight. So far very pleased with the performance and appearance.
soundman98 (06-14-2020)
Old 06-15-2020, 06:48 PM   #167
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Nice choice! Also check out my earlier post
Having gone through a similar problem myself, I recommend just going straight to coilovers if you can. You'll most likely get coilovers evantually anyways, so might as well save money on avoiding all the extra trial-and-error-and-alignment iterations. I'm really happy that my friend gave me that advice before I invested money into any suspension upgrades and just went straight to coilovers.
If you do want the extra steps, you might consider camber plates instead of bolts — this will give you more adjustability, more stability, and less worrying about a camber bolt going loose on a pothole or a curb at the track and the perch cutting your tire. If you do go with camber bolts, use the bottom bolts not top to get a couple of extra mm of clearance.
Old 06-15-2020, 09:25 PM   #168
Bearbones
bearbones
Bearbones's Avatar
Thank you. Coilovers would have given more clearance and adjustability, and I may still go that direction in the future. I will have to get a more aggressive alignment and see what it feels like. Camber plates sound like a good idea too, and I will look into that.
brz, performance package, wheels
Finding wheels to clear brembos jojosbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-13-2018 08:46 AM
Performance package Brembos Ernest72 Want-To-Buy Requests 2 07-14-2018 08:06 AM
Performance Package Brembos Freezing to Wheels? texastwurkt3am Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-23-2018 08:31 AM
What pads fit the Performance Package Brembos? mistople Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-03-2018 05:15 PM
