Old 06-01-2020, 02:16 PM   #785
RFB
RFB's Avatar
Drives: FRS
Originally Posted by Anthonyc777 View Post
Good to know, did you install them with any shims/grease? So far with my set up ive only noticed squealing in the wet typically after the car has been sitting, but after the initial brake I usually dont hear anything.
My discs still have a coating of the track pads, the metal rusts when sitting in the wet. Start up is dead quiet when wet, and when polished shiny after a few stops, still quiet.
No shims, and no grease as it instantly sizzles smokes and burns when tracking
Will report after my next tracking day as to results of hard use. I hope the pads will be useful on the track due to the overbraking capacity of the stage IV and hi bias on a light car ( the track pads are very abrasive and erode the discs quickly )
RFB is offline
Old 06-01-2020, 03:25 PM   #786
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by jflogerzi View Post
Yup. Much much better. 95% squeal free. Having a hard time bedding the back rotors. The fronts were pretty tight to get on there. Dusting is light compared to the bp-20s. I might get my rear rotors turned cause they still have a decent amount of the old pad material left on certain parts of the rotors. This is also no shims or grease as well.
I have the stage 2 in the fronts and sports rear. I was thinking of ordering the Carbotechs, so the wife stops whining about the squeal. I want to make sure I am getting the right pads. The 1521's fit the front? What about the rear? For some reason I find it very difficult shopping for brake pads for aftermarket calipers.
Irace86.2.0 is offline
Old 06-01-2020, 11:44 PM   #787
jflogerzi
jflogerzi's Avatar
Yes they are the 1521's. Make sure for the fronts you get the correct pad size. These you can get anywhere. The rears you need to order from RR racing as they modify them to caliper mounting of the pads. I sure you could fab the back plate after you see them one time but don't chance it yet
The front part is 7420-1521. Google this part for the best price
2013 Series 10 FRS #553
jflogerzi is offline
The Following User Says Thank You to jflogerzi For This Useful Post:
Irace86.2.0 (06-02-2020)
Old 06-02-2020, 01:07 AM   #788
Irace86.2.0
That’s what I’m saying; I never know what is the right pad size. I go searching and the searches are always based on make and model.
Are you saying there are no Carbotechs for the rears, so I have to get some custom cut down?
Old 06-02-2020, 01:15 AM   #789
jflogerzi
jflogerzi's Avatar
RR racing sells them on their site. They just modify the backing plate I believe
Old 06-02-2020, 04:21 PM   #790
Ernest72
This is what happens when you modify your brakes to non stock. My 04 WRX has 4 pots up front and the H6 upgrade on the rear from the legacy. It runs 02-03 shaped pads. I have ordered 04 pads by accident and had to exchange. Getting old you can forget things.
Ernest72 is offline
The Following User Says Thank You to Ernest72 For This Useful Post:
Old 06-09-2020, 11:43 AM   #791
Jedifar
Drives: 2022 Toyota GR86
The 1521s have been working great...I have barely minor/occasional noise to none. Thanks to RR for the recommendation.
I wanted to shift towards the performance on this kit, seems like there hasn't been an update for a while
I am about to go to the first HPDE this season in 2 weeks or so and I plan to run an X8 set up squared in my stage 1 front only, hoping braking is strong
How have recent experiences been in terms of performance and reliability?
For those running fronts, have you guys been able to measure temps across front and rears after runs and confirm the bias? How often are you locking up? How has your performance been vs other stock and different set up 86s on track?
When I was researching pads for track, I called Carbotech directly and spoke to one of their engineers who told me to do some spirited braking and measure temps afterwards to determine heat distribution and get a brake recommendation. I could only get it so hot on the street but from some heavy braking, it seems that the fronts are slightly getting hotter than the rear but the distribution is fairly balanced.
Carbotech then recommended going with the XP8s both front and rear given the readings. He had advised against going with a higher compound in the rear given it may lock the rear faster than the front and cause a spin. So based on this, looks like the kit bias is close to OEM as advertised.
Looking to see what others are experiencing
Jedifar is offline
The Following 2 Users Say Thank You to Jedifar For This Useful Post:
Irace86.2.0 (06-24-2020), lamawithonel (06-25-2020)
Old 06-09-2020, 04:22 PM   #792
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
First off, we cant see your pictures.
Secondly. I have the Stage II front and Sport Rear. The RR kit does very well on the track. Since installing the kit I have removed my brake cooling because I could no longer get the temps hot enough for the pads to work properly (DTC60) even at Watkins Glen. With proper braking technique you shouldn't be locking up although I have buzzed ABS a few times when pushing a little too hard. It is easier to activate the ABS with this kit if that is what you are asking. The bias feels better than OEM but I have no proof it is better, other than what RR said.
After 2500 track miles in 2019 the kit held up well. I had uneven pad wear in the front which seemed odd but rebuilt them and so far so good for the limited miles I have on the car in 2020.
I recommend spending some money on pads and buy cheap rotors on rock auto. CSG's compounds are amazing and I was told they are coming out with a front set for the willwoods. I know G-loc makes a set as well I would be interested in trying. I went through 1.5 sets of front rotors last year (2500 track miles) but at 50 bucks each, you cant complain. If my brake component ocd wasnt so bad I could have ran 1 set the whole year.
I wish the quality was a little better on a few of the components as I have communicated in this thread but overall, for the money, it works great on the track.
Unless you are some sort of prodigy, the stage 1 kit will be overkill for your first track day. Just make sure the fluid is fresh and preferably not the oem fluid.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline
Old 06-09-2020, 06:09 PM   #793
Jedifar
Updated the pictures.
I decided to stick with carbotechs since I have the 1521s and they are interchangeable with higher carbotechs.
I'm glad to hear you've had a good experience.
I know its overkill but I've done some track cross last year completely stock (my first year) and going to hit the ground running with hpde this year.
Concerned about the rebuilding though, I'll have to learn how to rebuild if this is a consistent issue with these kits.
Jedifar is offline
Old 06-24-2020, 09:21 PM   #794
Irace86.2.0
I just got the 1521s. Excited to try these. I would prefer to install these on fresh rotors or resurfaced rotors, but I think my rotors are smooth enough.
Old 06-24-2020, 09:48 PM   #795
jflogerzi
jflogerzi's Avatar
Get them turned. I still have some sqeak even with the carbotech pads but I did not turn my rotors. I am curious if you have the same issues but I feel more of squeal is from the back. Been to lazy to try and get the rears only turned and my fronts look good
Old 06-24-2020, 10:38 PM   #796
Irace86.2.0
Did you not sand them a bit to remove the shine/top layer?
Old 06-24-2020, 10:44 PM   #797
DarkSunrise
DarkSunrise's Avatar
Just finished up an open lapping day a week ago. Brakes held up amazingly in 4 hrs track time in 105F ambient temps. I'm running stage 2 fronts with bp20 pads and xp10 pads in the rear, and was on worn/old hankook RS3's for the event.
When threshold braking, I can hear the front tires chirp first, even with the more aggressive pads on the rear, so I can say the fronts will lock first.
I let a friend with stickier tires (a052) and stock brakes on his BRZ drive my car and he loved how strong and consistent my brakes were. Both he and I were braking deeper into the brake zones with my setup vs. his due to knowing that the brakes wouldn't fade.
Personally I love being able to trust my brakes over repeated laps and also knowing the consumable costs are much lower as well.
2022 BRZ Build
2013 FR-S Build
DarkSunrise is offline
The Following User Says Thank You to DarkSunrise For This Useful Post:
Irace86.2.0 (06-25-2020)
Old 06-24-2020, 11:06 PM   #798
jflogerzi
jflogerzi's Avatar
I did not. Was not aware it was advisable
big brake kit, competition, track
AP Racing brake systems in development track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 872 09-17-2017 08:43 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 06:53 PM
AP Racing Factory Big Brake Kit, NOT Competition Lonergt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-25-2013 05:51 PM
Official street racing thread. All street racing goes here! bkblitzed Off-Topic Lounge [WARNING: NO POLITICS] 8 07-19-2013 12:31 PM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 02:32 PM
