#43 | |
Sent from my ONEPLUS A5010 using Tapatalk |
| The Following User Says Thank You to Ashikabi For This Useful Post: | solidsnake11 (04-29-2020) |
#44 |
pessimistic skeptic
That has been a remarkable job, especially running the VTEC with Subaru ECU. Will you do a dyno? And also a video, please!
| The Following User Says Thank You to mrg666 For This Useful Post: | solidsnake11 (05-02-2020) |
#45 |
Drives: brz 2017 hksv2
i'm amazed at your work
i have a question: how is it possible to define the cc size of direct injectors in the fa20? they work with variable pressure, from like 0.4 to 20-22MPa at what pressure are they defined 450cc ? |
| The Following 2 Users Say Thank You to tomm.brz For This Useful Post: | mrg666 (05-04-2020), solidsnake11 (05-03-2020) |
#46 |
i m stalking your YouTube channel waiting for a video of a WOT to 9000 rpm (:
| The Following User Says Thank You to tomm.brz For This Useful Post: | solidsnake11 (05-16-2020) |
#47 |
Drives: Q5 + BRZ + M796
From what I read, the crossover point is like 3500-4000. Any sooner and there isn’t any gains or there are losses. Economy obviously hurts if you lower it too, and you won’t feel the delayed boost of VVVVTEEECCCHHHH!
#48 |
Which is logical thinking on Honda’s part. If someone gets into VTEC then they probably are aggressively driving so they lower the threshold until the driver is clearly not aggressively driving. If you drop the threshold for getting out of vtec too low then the system could be jumping lobes too much when city driving. I guess it depends on what you plan to do with the car and how you drive. Maybe an aggressive map and an economy map would be a good idea.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Zer0 (05-19-2020) |
#49 |
Uhhh 30psi?!! How does that feel?
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | solidsnake11 (05-24-2020) |
#50 |
I The pdf about racerom you find on Help files on Proecu
explains this very well, the boost limits are always on It worth a read Anyway it s very noticeable the boost limit, in contrary to fuel cut caused by wheel slip that closes throttle , boost limit closes Accelerator pedal only and the % of cutting is settable.. like the hysteresis of the overboost before limit activation It s a nice touch also for supercharged cars if you reach too high boost because of cold weather and you want to avoid, you can set the boost limit very soft, closing accel pedal just a little bit and the cut becomes very smooth |
| The Following User Says Thank You to tomm.brz For This Useful Post: | solidsnake11 (05-24-2020) |
#51 |
The new K20 turbo doesn’t have traditional VTEC on the intake. I guess the idea is that the turbo does enough work. The heads have less flow too. VTEC on the exhaust helps with spool I guess.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | solidsnake11 (05-27-2020) |
#52 |
That Guy
Drives: 2013 asphalt FRS MT
I've never understood this. If there's that much of a power increase that only means you should have been on that cam sooner. If you're after the max area under the curve the transition should be smooth as the power of one cam drops off and the other comes on.
| The Following User Says Thank You to Calum For This Useful Post: | solidsnake11 (05-30-2020) |
#53 |
you have to push trc off for 4 seconds to completely disable and allow spinning
vsc is not enough if you see accel100 and throrrle closing normally is because of wheel spin if you press trc only quickly it wont disable it totally and it will deacticate after 50km/h Last edited by tomm.brz; 06-01-2020 at 06:09 AM. |
| The Following User Says Thank You to tomm.brz For This Useful Post: | solidsnake11 (06-01-2020) |
#54 |
then no idea at the mom, it looks like a traction control cut but i can't help you
Try pedal dance or even the pedal dance that ecutek offers in the app, it s at the end of the list under DTCs, called Traction Control i think |
#55 |
is the hose with maf same diameter as the one you had with fa20
#56 |
what a beast.
Did you resolve the throttle closing while spinning? why don t you try e85 :P |
| Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 856 | 06-14-2018 03:53 PM |
| BRZ headlight swap to Monogram Series *UPDATE:10/12/14 w/ Pics* | JDis3 | Cosmetic Modification (Interior/Exterior/Lighting) | 31 | 04-12-2015 06:31 PM |
| ADVAN GT 18" Concave Face ** Actual Wheels Pics and Weight Pics | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 11-21-2014 12:16 AM |
| Release Series 1.0 FR-S & FT-1 Pics from NYIAS (Warning: iPhone Pics) | TM | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 26 | 04-30-2014 04:31 PM |
| More stock pics. My Raven FR-S with graffitti background. Sick Pics | Hardrock4445 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 6 | 11-12-2012 12:29 AM |
