Old 05-26-2020, 07:47 PM   #70309
Why do I need 1/8" drill bits?
Nice tight fit if using 1/8" rivets.
Tcoat is offline
ichitaka05 (05-26-2020)
Old 05-26-2020, 07:51 PM   #70310
I love riveting metal together...
the underside of the outer wing of the airplane in my basement waiting for me to pop some domed rivets...
Never did nice flat surfaces like that but have put thousands in a down and dirty floor pan/trunk fix to get through a safety check. Not worth welding then bend some scrap sheet to the right basic size to cover the hole, throw in a few dozen pop rivets, cover the whole mess with some nice stick tar and bingo when they try to stick a screwdriver through the floor they can't.
Tcoat is offline
Dadhawk (05-26-2020)
Old 05-26-2020, 08:00 PM   #70311
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Ah~ gotcha! noted
ichitaka05 is offline
Old 05-26-2020, 08:01 PM   #70312
soundman98
ProCrastinationConsultant
soundman98's Avatar
Bought rivet tool. I needed for future mods, so it’ll be interesting to see how it turns out. Need to test em out on few thing, so I won’t mess it up on actual thing I wanna do.
you mean nutsert/blind nut tool rivet tool is a little different. i've got an astra nutsert-er as well. i love it! i use it all over!
Go buy a bunch of QUALITY 1/8" drill bits. I mean a bunch! If using larger it isn't so bad but still get good ones.
Practice, practice, practice.
Pop riveting is more of an art form that a mechanical action.
not pop rivets. nutserts. a little different in that things can come apart later if needed.
it's like the last mechanical fastening option before welding nuts to surfaces.
soundman98 is offline
Old 05-26-2020, 08:18 PM   #70313
ichitaka05
Site Moderator
ichitaka05's Avatar
Ah~ my bad. Yes, I got the nutserts.
Old 05-26-2020, 08:21 PM   #70314
You have an airplane in your basement and it has an "inner" wing?
humfrz is offline
Old 05-26-2020, 08:26 PM   #70315
soundman98
soundman98's Avatar
they also have middle, front, and rear wings!
humfrz (05-26-2020)
Old 05-26-2020, 08:41 PM   #70316
AHHHH The pic was too small to see what it was so I took his word for it.
Whole different ballgame then.
Tcoat is offline
Old 05-26-2020, 09:23 PM   #70317
Airplane kit actually so really plane parts. The Outer wings are the parts you see. The inner wing runs under the fuselage and is what the outer wings connect to.
In the view below the inner and outer wing join where the extra ribs (6-V1-2) are on the mid-left. The extra ribs make up the wing walk. The part that appears flat is the inner wing, the angled up portion is the outer wing.
Dadhawk is offline
The Following 4 Users Say Thank You to Dadhawk For This Useful Post:
bcj (05-26-2020), humfrz (05-26-2020), NoHaveMSG (05-26-2020), soundman98 (05-26-2020)
Old 05-26-2020, 10:14 PM   #70318
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Sapphireho is offline
The Following 4 Users Say Thank You to Sapphireho For This Useful Post:
Dadhawk (05-27-2020), NoHaveMSG (05-26-2020), p1l0t (05-26-2020), soundman98 (05-26-2020)
Old 05-26-2020, 11:06 PM   #70319
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Is it strange I'm getting some serious flashback/deja vu from that picture, but can't quite place the situation? It had to have been at college. I think we made a wing section in Aircraft Structures or something. Or a prior class did. Or...
Spuds is offline
The Following User Says Thank You to Spuds For This Useful Post:
Old 05-26-2020, 11:08 PM   #70320
soundman98
soundman98's Avatar
lol, a one of anything isn't so bad! i've got the equivalent of this in my basement:
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
Dadhawk (05-27-2020), NoHaveMSG (05-26-2020), Spuds (05-27-2020)
Old 05-26-2020, 11:13 PM   #70321
Oh, I seeeee -
So now, I was ah feared, that under the stress of the lockdown, you were going to build the whole plane in the basement - like the fellow that built the boat in the basement. How big is this wing?
humfrz is offline
p1l0t (05-27-2020), soundman98 (05-27-2020)
Old 05-26-2020, 11:21 PM   #70322
really?
humfrz is offline
p1l0t (05-27-2020)
