Old 05-26-2020, 05:10 PM   #155
churchx
churchx's Avatar
Drives: 2014 GT86
"secure" as to not fall off, maybe.
But as vents are not meant to have something heavy mounted on, being flimsy by design/themselves, vent mounts imho are rather ratlish way i wouldn't want to use.
Old 05-26-2020, 05:35 PM   #156
norcalpb
norcalpb's Avatar
Originally Posted by N_Raged View Post
Sooo... magnetic mounts suck lol. Any bit of spirited driving and my phone flies off its mount.
I've resorted to a vent mount off amazon until I can DIY something like ozafar did.
I used to have the same problem because I’d either have to put the magnet behind the case and it wouldn’t have enough hold, or put it on the back of my case and the heat would mess with the adhesive and the metal would fall off my case.
But I found this phone case company, Pitaka, where the metal pieces are actually built into the case. This holds really well on canyon drives, maybe not the best for track though.
Old 05-26-2020, 05:37 PM   #157
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I have a two-piece dash trim, so I use the Beatsonic QBF13 mount and QBA17 phone holder.
I ordered a cut-to-size piece of acrylic, stuck a Scosche Mount to it, and have the phone holder grip it. Now it's the best of both worlds, and I can switch between whatever holding method I want at the moment.
EndlessAzure is offline   Reply With Quote
Old 05-26-2020, 05:48 PM   #158
N_Raged
Drives: 2019 BRZ Sport-Tech RS
Depends on the application. On my wife's Kia Soul using a vent mount on the center vents is sketchy since it wobbles around.
On my BRZ I've wedged it in the corner and the mount is resting on the bottom of the vent instead of just hanging off the fins. It's pretty sturdy up & down and side to side.
But generally I hate sacrificing a vent just to mount a phone. Especially in cars were you can't shut the vent, resulting in your phone getting blasted by heat in the winter.
N_Raged is offline   Reply With Quote
Old 05-27-2020, 04:13 AM   #159
saltywetman
Drives: 2020 Toyota 86 GT 6M
The Magicmount pro extendo is pretty great. I have it stuck on the flatter portion of the dash and because you can have the arms come downward and towards you, it does not obscure any windshield visibility. Will take pictures tomorrow. The pro series has stronger magnets too and is able to hold my Note 10+ in place even under harder braking and quick accelerations/jerky turns. Will attach a picture tomorrow
saltywetman is offline   Reply With Quote
Old 06-01-2020, 10:34 AM   #160
ThatYeti
I've used this one attached to top left vent above the radio, been in the car for 6 months and hasn't dropped my Nexus 2XL even once. Looks ok, and i have my phone on it everytime I'm in the car (running Waze & JBV1) so it really doesn't matter.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
ThatYeti is offline   Reply With Quote
Phone holder Tim_Asphalt_FRS Cosmetic Modification (Interior/Exterior/Lighting) 79 04-02-2016 03:28 PM
Is it possible to use a phone as a BRZ key? Killianti Electronics | Audio | NAV | Infotainment 19 08-13-2014 04:55 PM
Window weld motor mounts (poor man's solid mounts) unsurety Engine, Exhaust, Transmission 8 06-05-2014 02:36 AM
Let's talk phone mounts l0aded Electronics | Audio | NAV | Infotainment 41 06-14-2013 12:53 PM
Phone app. DanoFA20 Site Announcements / Questions / Issues 6 10-22-2012 11:55 PM
