Old 05-23-2020, 01:03 AM   #70169
soundman98
ProCrastinationConsultant
soundman98's Avatar
Sorry guys, @soundman98 , my bad, I was confused.
I went out and checked my fuse box and after I scraped a little on my "yellow" wires, I discovered they were "white" wires that were kind of burnt looking, cracked and yellowed.
lick it. if it doesn't tickle, just tastes funny, it's a neutral.
if it tickles, and tastes funny, it's a hot.
if it tastes like dirt, it's a ground.
soundman98 is offline
The Following 4 Users Say Thank You to soundman98 For This Useful Post:
humfrz (05-23-2020), JD001 (05-23-2020), NoHaveMSG (05-23-2020), Ultramaroon (05-23-2020)
Old 05-23-2020, 01:24 AM   #70170
it started simple.
We will looking forward to "the rest of the story" -
humfrz is offline
soundman98 (05-23-2020)
Old 05-23-2020, 01:28 AM   #70171
soundman98
soundman98's Avatar
hopefully the rest of the story is boring.
current plan is:
dump dirt.
get gravel.
spread gravel.
mix concrete.
pour concrete.
finish concrete.
be done before rain at 1pm.
yeah, i don't think i'm going to get that far either.
Old 05-23-2020, 01:35 AM   #70172
But, but, but, with the COVID19 threat, should I use a jumper wire and lick the other end of the wire -
Reminds me of the time my father was trying to start a engine on a grain elevator. He pulled off the spark plug wire and ask me to hold on to it to see if it was firing, as he pulled the starter robe. That only works once per kid -
humfrz is offline
Old 05-23-2020, 01:37 AM   #70173
current plan is:
dump dirt.
get gravel.
spread gravel.
mix concrete.
pour concrete.
finish concrete.
Hells bells, that would be a week long project for me -
humfrz is offline
Old 05-23-2020, 01:52 AM   #70174
OK, it's 10:45 pm, time to take the granddaughters to their home for the weekend.
This home schooling is getting stressful. For their PE they had to run around the block. Of course the 3 ager had to go too, just because. Which meant pa-pa had to go too. I'm too damn old for that shit.
Oh, ma-ma is starting to yell - better get them home - YIKES!
humfrz is offline
Old 05-23-2020, 03:05 AM   #70175
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
More and more I start to gravitate towards being able to track my car. Currently trying to put the last two sets of ARP extended studs on the rear wheels (having trouble BTW but just check the WHAT DID YOU DO thread).
Afterwards, I'm looking into LCAs and eventually an oil cooler. I've got a lot of time before quarantine is over, so hopefully before the end of the year I can finally take my FR-S to the track.
KR-S is offline
Old 05-23-2020, 03:05 AM   #70176
soundman98
soundman98's Avatar
I've been telling people I'm trying to get 4 days worth of work done this weekend. I'm probably underestimating. I also need to change and re-vent a water heater somewhere in all this too.
Most nerve wracking part of that is the gas line.
humfrz (05-23-2020)
Old 05-23-2020, 03:07 AM   #70177
soundman98
soundman98's Avatar
I'm wishing i could get quarantined right about now...
Old 05-23-2020, 06:43 AM   #70178
JD001
JD001's Avatar
Drives: Subaru BRZ
current plan is:
dump dirt.
get gravel.
spread gravel.
mix concrete.
pour concrete.
finish concrete.
Don't forget to cover setting concrete before the rain or before the local neighbourhood kids decide to leave their tags (historical significance)..
JD001 is offline
The Following User Says Thank You to JD001 For This Useful Post:
Old 05-23-2020, 11:41 AM   #70179
Don't forget to uncover and evenly wet the concrete again once a day for at least a week. Two weeks would be better but is not usually practical.
Tcoat is offline
JD001 (05-23-2020), soundman98 (05-23-2020), Ultramaroon (05-23-2020)
Old 05-23-2020, 12:29 PM   #70180
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It's a slippery slope.
NoHaveMSG is offline
KR-S (05-24-2020)
Old 05-23-2020, 12:51 PM   #70181
JD001
JD001's Avatar
Drives: Subaru BRZ
current plan is:
dump dirt.
get gravel.
spread gravel.
mix concrete.
pour concrete.
finish concrete.
Forgot to ask, what type of finish have you applied to the wearing surface?
JD001 is offline
Old 05-23-2020, 12:54 PM   #70182
JD001
JD001's Avatar
Drives: Subaru BRZ
Is that "your" fusebox? It should be on Antiques roadshow!! Looks bloody old and dangerous. New wiring and box me thinks!!
JD001 is offline
humfrz (05-23-2020)
