DADA
Drives: 2013
Roof trim line coming off
Not sure if this is the correct spot for this, If not mods please move it.
Is anyone else having this issue ? Mine is on the right side closer to the rear windshield , it's coming off but I looked under it and there is only 2 clips that hold it, which are fine just the rubber piece itself doesn't seem like its holding properly . |
| The Following User Says Thank You to mashal For This Useful Post: | Marrk (08-05-2012) |
#2 |
Drives: Silver AT Limited
Has it been really hot?
#3 |
Super easy fix. It comes on and off like a ziplock bag. Just protects the metal seam. Maybe it is deformed?
#4 |
DADA
Drives: 2013
Ye I think it deformed for some reason, I took it out completely and put it back in and same thing, just that one spot bulges
#5 |
Drives: Whiteout / MT FR-S
I would take it back to the dealer and get a new piece just in case then.
#6 |
Drives: 13'FRS,10 TC(trad),09'370z(totaled)
It has two clips one on each end one is misplaced making the mohican strip to lift. Easy fix but better take it to the dealer.let me know if you need some help I work installing this strips @ the plant in Texas
| The Following User Says Thank You to francosolracer For This Useful Post: | Lee358 (08-05-2012) |
#7 |
DADA
Drives: 2013
#8 | |
Drives: FR-S MT
It looks one of three things happened to yours. Either the insert lengthened, or the clips were placed too close together on the insert, or the clips were placed too closely together on the roof. The dealer should measure all three components to see if they are within specifications. I would start by asking them to replace the insert. If that doesn't solve the problem, they should replace the clips on the roof. |
#9 |
Drives: 2013 Raven FRS
Sorry to bump this old thread.
I recently bought an old 2013 FRS and a few weeks later the driver side roof trim flew off my car while driving. I checked the passenger side and its loose as well (but held in at the ends where there are clips. I got a replacement for the driver side and it fits snugly with no movement whatsoever. I think im going to replace the passenger side as well as a preventative measure. I highly recommend everyone checks their trim for movement and replaces them if loose. You'll get better waterproofing/rust protection in the area and reduce the risk of it actually flying off, which could obviously be dangerous. The trim itself is $20CAD ($15USD) per side and you don't need to replace the clips. |
#11 |
It's certainly possible. I should mention that the pieces were not deformed as shown in the OP of this thread, just loose (you can push on either endcap and the trim will bend, move freely).
The new one is extremely tight, and looks water sealed, so water shouldn't be getting in there. The car was winter driven but not garaged so there shouldn't have been that much freeze-thaw going on anyways. I'll check on it next spring and see if there's a difference (and hopefully remember to report back here). There's been a heat wave (around 40c/105f) here recently and that could also be a cause, as my car is black and parked outside at work. Regardless of the cause, I'd just recommend people check them. A friend (also in Canada) has a 2015 and when I told him he checked and both were loose. (ps - I know this thread is in the wrong spot, but it was the only one I could find related to the roof trim and thought it best to keep the discussion together) |
| The Following User Says Thank You to ottawafrs For This Useful Post: | Tcoat (07-20-2018) |
#12 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Crows, jays and flickers like to prod at bits of rubbery stuff hoping to find something squirmy underneath.
I've heard that a New Zealand kakapo can mostly dismantle a land rover in under 45 minutes. They're not hungry. They just like being D1cks.
"I gotta rock." -- Charley Brown Last edited by bcj; 07-20-2018 at 05:19 PM. |
| The Following 3 Users Say Thank You to bcj For This Useful Post: |
#13 | |
| Interior trim trim clips (Dash Trim Panel) | ubersoph | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 08-11-2022 08:47 AM |
| Factory Roof Rack? | \o/ | Scion FR-S / Toyota 86 GT86 General Forum | 92 | 02-15-2013 04:25 AM |
| WTT: BRZ(mine) trim pieces for FRS(yours) trim pieces | Flat Black VW | Interior Parts (Incl. Lighting) | 14 | 07-27-2012 11:01 PM |
| Dry Carbon Roof | quik1987 | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 07-17-2012 05:48 AM |
| No Carbon Fiber Roof!? | Slide | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 07-15-2012 11:16 PM |
