Old 05-20-2020, 07:51 PM   #70071
Originally Posted by ls1ac View Post
Up north===Wisconsin
down here===Florida
Was supposed to be driving to Portland area now, but all seems to be on hold.
Oh don't go there they are all jerks.
Tcoat is offline
bcj (05-21-2020), Opie (05-21-2020)
Old 05-20-2020, 09:13 PM   #70072
echo419
echo419's Avatar
Drives: 2014 BRZ Limited
Portland is great if you like bad smells and homeless people.
Did you forget how to use the forum?
How have you been otherwise?
not bad. started a new job in banking with the intent that it will open doors etc to me when I finish my degree in Finance. it's only been a few weeks but I've decided that this retail type of banking atmosphere is 100% not for me. I'm not someone that needs to deal with the public on a regular basis. but that's ok. they have other options and I will continue to explore my options.
in other car related news I might be picking up a 95 3000GT VR4 soon. found one in St.Louis that I really like but I need to get someone to check it out before I make the trip. I'd hate to go all the way there and find out that it's knocking or has some other major issue I don't feel like dealing with out the gate. Hopefully it checks out, I miss the platform and wish I had never sold mine in the first place.
echo419 is offline
The Following 2 Users Say Thank You to echo419 For This Useful Post:
Tcoat (05-21-2020), Ultramaroon (05-20-2020)
Old 05-20-2020, 10:09 PM   #70073
Originally Posted by Opie View Post
Could be a M1 Garand...
Yep, could be, ol @Sapphireho is pretty old.
humfrz is offline
Opie (05-21-2020)
Old 05-20-2020, 10:20 PM   #70074
down here===Florida
Well, you might as well not come to Portland, you missed their annual naked bike ride -
Is that @Ultramaroon I see off in the distance?
humfrz is offline
Old 05-20-2020, 10:23 PM   #70075
not bad.
Not bad is great. Like Portland
I drooled over the 3000GT for a while but never got over the AWD. I probably wouldn't have fit anyhow. We'll never know.
Ultramaroon is offline
echo419 (05-25-2020)
Old 05-20-2020, 10:43 PM   #70076
spike021
spike021's Avatar
Almost got pulled over by CHP a bit ago on 101. I was in the lane next to the carpool lane, it was still 6pm-ish, so within carpool lane hours. I got stuck behind a flatbed truck and the traffic to the right wasn't free and clear enough for me to (unsafely) pass on the right, and the truck wasn't merging either. But there was absolutely nobody ahead of him.
Carpool lane was completely clear so I think to myself "I wouldn't normally go in the carpool lane during carpool hours but I think I can pass this guy quickly enough anyway and nobody's around".
So I downshift to 5th, speed up to 75ish, merge over, 5-10 seconds later I'm ahead of him and merge back. Right as I settle back in the correct lane, a CHP officer in a Dodge Charger quickly tearing through the carpool lane catches up to me, slows down to pace me (by then I'm going 70 and when I notice him I left off the gas and slowed to 68ish). So I look over and he shakes his head at me, and then speeds off.
Like okay I get it, carpool lane law is I can't use it without a passenger. But absolutely nobody else was in the damn lane, you're telling me I can't do a safe pass that takes ~20 seconds that would be perfectly fine if me and the truck had been shifted over one lane toward the right??
I guess I shouldn't really complain since he basically did let me off with a warning shake of his head, but it's still kind of a dumb law in this kind of situation. It's always the _one_ time you do something that you get caught.
Anywho back to your regularly-scheduled programming.
Instagram: @spike.grc
spike021 is offline
The Following User Says Thank You to spike021 For This Useful Post:
humfrz (05-21-2020)
Old 05-20-2020, 10:56 PM   #70077
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Thinking of making rear diffuser out of aluminum. It will start from diff area and connect (start) to rear lip, so looking from the back, prob won't see it.
What would be an ideal thickness? Decently thick, so it won't bend easily, but easy enough to work/cut.
ichitaka05 is offline
Old 05-21-2020, 01:03 AM   #70078
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Up here in WA, you can buy your way into the HOV lane if you're rich enough. Plebe.
Yah. Me too. If you cross a double white you get get to fund the state lottery!
6061 has been a go-to for years. Dealing with bird strike and FOD.
Not a lot of fist size rocks or tumbling suspension links over 1000 feet though.
Usually they buy thick and mill or acid etch between attachment point areas that need to be more resistant to tearing (tension).
Would recommend polycarbonate cardboard panels - for mock up at least.
Can get 4'x8' panels in a rainbow of colors. Much cheaper and easier to work.
Unless mirror polished show car with mirrors under.
bcj is offline
ichitaka05 (05-21-2020)
Old 05-21-2020, 01:09 AM   #70079
ichitaka05
Site Moderator
ichitaka05's Avatar
Yeah, I’m planning to use cardboard to mock the design first then work on the sheet. Measure twice, cut once right?
Old 05-21-2020, 01:31 AM   #70080
bcj
Geo Tyrebighter Esq
bcj's Avatar
The plastic board they use for political signs all over.
Can get it up to 1/2 inch with thicker cell walls.
Really think it's a superior aero panel material for underneath.
Can glue bond layers for support points and cut with a hot wire or solder iron.
Poke holes for lots of zip ties
bcj is offline
The Following 2 Users Say Thank You to bcj For This Useful Post:
Cole (05-21-2020), Ultramaroon (05-21-2020)
Old 05-21-2020, 01:41 AM   #70081
You just now finding that out -
- don't do that no more!
You got off easy.
It could have been "the first time" you decided to have an affair, with that cute little coworker and you run across your wife at the same motel -
humfrz is offline
spike021 (05-21-2020)
Old 05-21-2020, 01:49 AM   #70082
It's great stuff. Durable, no rust, dirt cheap...
Old 05-21-2020, 02:36 AM   #70083
This is old .... but, it seemed appropriate, especially now.
humfrz is offline
The Following 6 Users Say Thank You to humfrz For This Useful Post:
bcj (05-21-2020), NoHaveMSG (05-21-2020), Opie (05-21-2020), spike021 (05-21-2020), Stephen W. (05-21-2020), Ultramaroon (05-21-2020)
Old 05-21-2020, 07:51 AM   #70084
Agh! Going back to using CAD I see (cardboard aided design)
Dadhawk is offline
ichitaka05 (05-21-2020), Stephen W. (05-21-2020), Ultramaroon (05-21-2020)
