Old 05-19-2020, 06:28 PM   #70043
Hopefully this is better.
Much better. If nobody gives you an answer tonight I will check at work tomorrow.
Tcoat is offline
NoHaveMSG (05-19-2020)
Old 05-19-2020, 06:44 PM   #70044
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Made a kick-ass workbench with my dad as a birthday present to me!
Spuds is offline
The Following 5 Users Say Thank You to Spuds For This Useful Post:
Dadhawk (05-19-2020), humfrz (05-20-2020), NoHaveMSG (05-19-2020), soundman98 (05-19-2020), Ultramaroon (05-20-2020)
Old 05-19-2020, 06:55 PM   #70045
Anyone know what this component symbol means? I though it was a mosfet but I am not sure. It is off of a cheap DC motor speed controller. Trying to find specs on it so I can find it's rated operating temperature. Google has turned up zilch. @Ultramaroon Triac?
Killing me with that image. LiteOn Schottky rectifier G30100ctw
Ultramaroon is offline
Spuds (05-19-2020)
Old 05-19-2020, 06:57 PM   #70046
Spuds
The Dictater
Spuds's Avatar
You're a wizard 'arry!
Spuds is offline
The Following User Says Thank You to Spuds For This Useful Post:
Ultramaroon (05-19-2020)
Old 05-19-2020, 07:00 PM   #70047
Good times!
I gots my bros
Spuds (05-19-2020)
Old 05-19-2020, 07:27 PM   #70048
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Thank you!
I thought that was a "C" on the front
It is just this cheap motor controller I am playing with. I was curious if it would be up to snuff for a project I am working on. Looks like all the main components are good enough to handle it. I am only getting about 100-110F and everything that is getting hot is rated for 300F continuous. Now to see if it gets too hot when I 3d print an enclosure for it. I haven't opened it up to poke around inside yet but it looks like it has 5 mosfets that run into that rectifier. I thought it was PWM but it's not according to the mfg.
https://www.amazon.com/UCTRONICS-Con...9&sr=8-24&th=1
NoHaveMSG is offline
Old 05-19-2020, 09:06 PM   #70049
soundman98
ProCrastinationConsultant
soundman98's Avatar
looks like it's a discontinued part
https://www.avnet.com/shop/apac/prod...entoryfeed_VSE
here's a similar metal tab version via vishay
https://www.digikey.com/product-deta...WGI-ND/2048216
and an isolated tab version in case the heatsink isn't supposed to be part of the circuit
https://www.digikey.com/product-deta...WGI-ND/4875900
and i'm late... i love a good component hunt anyways...
soundman98 is offline
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
NoHaveMSG (05-19-2020), Ultramaroon (05-19-2020)
Old 05-19-2020, 10:38 PM   #70050
Thank you!
Well yeah. And you didn't have to divine it from a fucking capcha thumbnail. I started looking at what the characters could be if the smudges weren't there.
Old 05-19-2020, 11:24 PM   #70051
It was fun.
Old 05-20-2020, 12:11 AM   #70052
I salvaged a motor and controller board out of a front loader washing machine a few years back. Am still planning on using it as a variable speed drive for my old Atlas 912.
NoHaveMSG (05-20-2020), soundman98 (05-20-2020)
Old 05-20-2020, 01:06 AM   #70053
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
My turkey... I mean chicken... I mean Griffon is coming along nicely
ichitaka05 is offline
The Following 5 Users Say Thank You to ichitaka05 For This Useful Post:
Dadhawk (05-20-2020), NoHaveMSG (05-20-2020), soundman98 (05-20-2020), Spuds (05-20-2020), Ultramaroon (05-20-2020)
Old 05-20-2020, 03:01 AM   #70054
I put together our new spray rig today. Now I need a mask like Humfrz' to spray Roundup.
Nice spray rig.
Oh, yes, Roundup (glyphosate) and I go way back, to when I was a scienteest with Stauffer Chemical Company. We patented glyphosate (composition of matter patent) as a chemical chelator. A few years later Monsanto acquired a use patent as a herbicide and called it Roundup.
"Discovery
Glyphosate was first synthesized in 1950 by Swiss chemist Henry Martin, who worked for the Swiss company Cilag. The work was never published.[15]:1 Stauffer Chemical patented the agent as a chemical chelator in 1964 as it binds and removes minerals such as calcium, magnesium, manganese, copper, and zinc.[16]
Somewhat later, glyphosate was independently discovered in the United States at Monsanto in 1970."
Yep, our brilliant patent department didn't see that one coming, till it was too late.
So, back to spraying that stuff. While I was a field scienteeeest, I sprayed tons of it's analog to try to prove enhanced biological activity over glyphosate (Roundup). Yep, sprayed a ton of Roundup as a standard.
So, don't be afeared of spraying that stuff - look how I turned out - and I've only had cancer twice -
SERIOUSLY - when spraying Roundup, use a respirator, goggles and rubber gloves.
Don't worry about the after effect, impotence, at your age, that will happen anyway -
humfrz is offline
The Following 3 Users Say Thank You to humfrz For This Useful Post:
NoHaveMSG (05-20-2020), Sapphireho (05-20-2020), Ultramaroon (05-20-2020)
Old 05-20-2020, 03:07 AM   #70055
NICE workbench! -
humfrz is offline
Spuds (05-20-2020)
Old 05-20-2020, 09:34 AM   #70056
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That would be a fun project. I have seen quite a few video's on old equipment being updated with varible speed drives.
I bought an arduino uno kit to start playing with. Work won't let me go to school so I have to try to learn on my own.
