Old 05-11-2020, 06:01 PM   #211
churchx
churchx's Avatar
Drives: 2014 GT86
@CSG Mikes: but what degrades in calipers? Doesn't rehauling/cleaning/replacing seals and guide rubbers/regreasing restore them almost like anew? Trying to imagine, what can wear/degrade in metallic parts in calipers/pistons to be noticeable in braking, if there are no scratches or alike at time of overhaul? :/
Old 05-11-2020, 06:03 PM   #212
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
They could be scoring the piston and piston bores which would tear up the seals.
Old 05-11-2020, 06:59 PM   #213
RayRay88
Drives: 2017 86 860 Special Edition
Seals also degrade with high heat. It's the main reason most "proper" aftermarket calipers don't come with them.
RayRay88 is offline   Reply With Quote
Old 05-11-2020, 07:08 PM   #214
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I should clarify I was mostly talking about why you would replace the whole caliper as opposed to just swapping the seals. Could cause them to get sticky too.
Old 05-11-2020, 07:10 PM   #215
CSG Mike
CSG Mike's Avatar
when you massively overheat the metal over and over it fatigues over time, and eventually you'll get non-plastic deformation.
Generally, if you are burning off outer dust boots, you are MASSIVELY overheating calipers.
Originally Posted by Brembo
For those running fixed, multi-piston calipers (Brembo GT, for example), recommended working temperature is < 200°C (392F), whereas the maximum acceptable working temperature is 220°C (428F);
Over 240°C (464F), the seals fitted into the calipers can be overheated and they will not guarantee the right performances of the caliper (sealing, roll back, fluid absorption,…);
If the caliper temperature goes over 240°C (464F), the dust seals and pressure seals should be refreshed.
Brembo, AP, Alcon, Advics, Project Mu, PFC, etc. all have the same recommendations.
churchx (05-11-2020)
Old 05-11-2020, 07:12 PM   #216
CSG Mike
CSG Mike's Avatar
Are they scoring the piston bores that badly?
The caliper itself is getting soft and flexing
NoHaveMSG (05-11-2020)
Old 05-11-2020, 07:12 PM   #217
CSG Mike
CSG Mike's Avatar
Race calipers dont have outer dust boots. Street/mixed duty calipers do.
DylanJZA (02-01-2023), RayRay88 (05-11-2020)
Old 05-11-2020, 07:12 PM   #218
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Ahhhh. Thanks for the clarification.
Old 05-12-2020, 08:07 AM   #219
Ohio Enthusiast
Drives: 2018 BRZ
Although this sound correct, I wonder how does that jive with track-oriented pads for stock calipers? If dust boots need temps lower than 400 F, why bother with non-stock pads? If you run track pads that can handle higher temps, are you ruining the calipers in short order? Or is it that the calipers don't come close to the friction surface temperatures?
Ohio Enthusiast is online now   Reply With Quote
Old 05-12-2020, 10:13 AM   #220
churchx
churchx's Avatar
Drives: 2014 GT86
There are people that need to use for various reasons stock brakes (eg. class requirements or street legality for dual-used car in some countries). Dust boots are there mostly to keep road salt out & maybe some extra dirt/sand/dust, no? And in winter there are way less load/temps on brakes. Seeing no relation of using or not track pads when, well, tracking, and street pads elsewhere, related to if calipers have or haven't dustboots. One just needs to understand, that proper braking on track (even if with stock pads, that may underperform in several areas on track) most probably will burn off those dustboots. Though it seems beneficial to replace burnt off dustboots in autumn, when summer tarmac tracking season ends. They don't cost exorbitant sums (eg. SU00304523 + SU00304098)
Old 05-12-2020, 12:06 PM   #221
CSG Mike
CSG Mike's Avatar
Often times, you don't get the choice (luxury) of more caliper and rotor. It may not fit the budget, or the rules of a certain class, or such a system may just straight up not exist.
Then you have to accept that the calipers are going to get hot.
Have you ever seen a brake change in pro level endurance racing? They often change out the entire assembly during stops. Guess what's going to happen to that caliper? Straight to rebuild.
Here's an example.
The Following 7 Users Say Thank You to CSG Mike For This Useful Post:
53Driver (05-19-2020), churchx (05-12-2020), DylanJZA (02-01-2023), Grady (05-13-2020), Ohio Enthusiast (05-12-2020), Racecomp Engineering (05-12-2020), x808drifter (05-12-2020)
Old 05-19-2020, 11:52 PM   #222
53Driver
T64-416Ax3=13,140shp
53Driver's Avatar
Drives: 2002 AP1 and 2015 F-150 EB (DD)
Here's an example.
Man, I wish those guys would show up at my garage and do a brake, wheel/tire swap like that for me. Jeez, only took them about 70 seconds. I could easily done it in an hour and a half by myself.
53Driver is offline   Reply With Quote
Old 05-20-2020, 08:29 AM   #223
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
You want to swap wheels quickly? Here, have this. Admittedly they are not changing brakes but still.
Don't blink.
Old 05-20-2020, 09:37 AM   #224
RayRay88
Don't blink.
Red Bull hold the record at the moment, 1.82 seconds. It's astounding.
The Following User Says Thank You to RayRay88 For This Useful Post:
Captain Snooze (05-20-2020)
The Truth Will Set You Free~ Kiske Off-Topic Lounge [WARNING: NO POLITICS] 8 01-06-2015 07:53 AM
Moment of truth. Humor is welcome! gt8613 Off-Topic Lounge [WARNING: NO POLITICS] 12 11-11-2014 02:08 PM
any truth to this? fluffy-reindeer-slayer Scion FR-S / Toyota 86 GT86 General Forum 17 06-11-2014 08:00 PM
An inconvenient Truth Maxim Scion FR-S / Toyota 86 GT86 General Forum 49 06-17-2011 10:35 PM
