Old 05-18-2020, 06:52 PM   #57
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Most heater hose I've seen is rated to 275 F. As Weeder mentioned, I put some thermal sleeving on mine where they run close to the block or exhaust - just as a precaution.
If you use silicone hose the temp rating bumps up to something like 350 F.
In addition, I picked up a molded 5/8" silicone 90 degree "L" to make the transition from the exit of the Forester/WRX coolant pipe to the OEM heater hose cleaner.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 05-20-2020, 03:56 AM   #58
86zn6
Drives: White GTS then Black GTS
Yes I am planning to get silicone hose. That is very good idea to have L connector, but worry that would introduce more risk for leaking.
86zn6 is offline   Reply With Quote
Old 05-20-2020, 10:36 AM   #59
jflogerzi
jflogerzi's Avatar
Why not just use the throttle body method?
2013 Series 10 FRS #553
Old 05-21-2020, 03:26 AM   #60
86zn6
Yes I am going to try the TB method. I wonder if anyone running into heat problem for the hose when connecting the TB? I am sure the hose would touch the metal part. Do I need to use some kind of heatshield like this one to protect the hose? https://www.ebay.com.au/itm/172355932574
Old 05-21-2020, 11:50 AM   #61
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
before switching over to the Cusco set up, I had the TB method. I did not put any sort of shielding on the hoses. The parts that touch the TB were perfectly fine, but there was some abrasion on the hoses as they touched the engine block.
MS, CSCS, TSAC-F, CPT
Old 05-21-2020, 03:22 PM   #62
Capt Spaulding
Persona Non Grata
A couple of reasons.
First, I bought the various parts to do the OEM(ish) approach 3 or 4 years ago and never got around to installing them. The current environment offers the time to finally put that together.
Second, aesthetically, I like the cleanliness of that installation.
Third, functionally. I have a hunch it may offer better coolant flow through the heat exchanger than the TB approach - admittedly, I'm just pulling that out of my ass but, oh well.
If I were going to use a different variation, I'd use the feed side of the OEM approach and run the return line over the top of the engine around to the rear of the water pipe that bridges the two cylinder backs and swings around the passenger side to the upper radiator hose.
There's a plate on the rear of that pipe that blocks off what on automatic trans cars is the return line from the trans cooler. I considered just buying the housing that bolts to that port and returning the coolant there. But, as I noted earlier, I already had the parts to do it this way and now have the time.
The Following User Says Thank You to Capt Spaulding For This Useful Post:
jflogerzi (05-21-2020)
Old 05-21-2020, 03:26 PM   #63
Capt Spaulding
Persona Non Grata
I wouldn't worry about heat, but as Weeder noted, abrasion could be a problem over the long term. The material you link to would probably deal with abrasion issues, or you could pick up some sleeve material to protect the hoses. I used some hose protection sleeving on mine where the hoses run close to the engine or accessories.
Old 05-21-2020, 03:36 PM   #64
weederr33
weederr33's Avatar
Something like this will help: https://www.spectreperformance.com/3...er-hose-sleeve
I was fortunate that the Cusco kit came with some plastic covering, but I still used the braid on a few sections, too.
Old 05-21-2020, 07:57 PM   #65
N_Raged
Drives: 2019 BRZ Sport-Tech RS
I used Vibrant hose #20425. Highest temp rating I found (350F). One hose is more than enough - I had a bit left over.
https://vibrantperformance.com/catal...fe4e30d2eeed54
N_Raged is offline   Reply With Quote
Old 05-24-2020, 09:00 AM   #66
86zn6
Thanks guys, I will go with silicone hoses + shield
Old 05-24-2020, 09:33 AM   #67
86TOYO2k17
Drives: 2017 toyota 86
Bypass the TB. You don’t need the coolant heat soaking the TB.
Old 05-24-2020, 12:29 PM   #68
T0rt0r0
Drives: European gt86
If the coolant flows from the TB to the oil cooler its ok no ?
I don't know which pipe on the TB is the coolant entry / exit thougth
T0rt0r0 is offline   Reply With Quote
Old 05-24-2020, 01:10 PM   #69
86TOYO2k17
It’s only purpose is to warm up the TB when it’s below freezing and you park outside. Otherwise the 190f+ coolant will heat soak the TB, a lot of people just delete it from the loop. It isn’t going to hurt anything keeping it, but no point for most.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
T0rt0r0 (05-25-2020)
Old 05-25-2020, 09:26 AM   #70
T-Steve
Drives: 2014 BRZ
Agreed. I bypassed the throttle body on my '14 about four years ago and have had no problems in temperatures as low as 0 F.
(Incidentally I did the same mod to my Forester as well with no problems.)
T-Steve is offline   Reply With Quote
The Following User Says Thank You to T-Steve For This Useful Post:
Perrin Oil Cooler Kit Installation and Review!!! Sony Engine, Exhaust, Transmission 29 03-27-2017 02:03 PM
Texas Heat Sale- Perrin Oil Cooler 10% Off with Installation! GSpeed Southwest 0 07-30-2015 02:47 PM
Beat the Texas Summer Heat! Perrin Oil Cooler 10% Off with Installation! GSpeed Engine, Exhaust, Bolt-Ons 0 07-30-2015 02:44 PM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
Oil Cooler usability: Changing oil, installation, etc post_break Engine, Exhaust, Transmission 20 06-12-2013 02:36 AM
