Old 10-31-2016, 01:54 PM   #43
7 skulls
Drives: 2014 scion frs
I believe the Cusco oil cooler bypasses the rad, running hot coolant from the engine through the oil cooler and back to the engine coolant (cool) intake. During steady state highway driving, I see 92 C on the coolant (OBD port) and 87-92 on the oil (OBD port). But driving hard with the rpm above 4000, I get less than a mile before oil temps top 116 C. When I back off the rpm, oil temps cool down fast but as others have said, this oil cooler makes no difference to max. oil temp.
7 skulls is offline   Reply With Quote
Old 06-20-2018, 04:55 AM   #44
Harey
Drives: 2013 Toyota 86
Originally Posted by SkiRideDrive View Post
The canyon run temperatures above were absolute worst case scenario, driving the car very hard on a very steep and very tight road. I have included two more comparison graphs below. They are on a more typical canyon road, predominantly third gear. These runs however, also utilize everything the car has to give. A more casual canyon run will likely have different results.
These runs (east grade) were also done very soon after running the very demanding road above (south grade). You may notice that the oil temperatures on the WITH cooler logs are decreasing. This is the cooler doing its job and dropping the oil temperature which were elevated by the very aggressive road driven prior. In the logs above, you will notice approximately a 11 degree max difference in oil temperature. In the more conventional canyon road below, you will notice after the cooler stabilizes the oil temperature, a more significant 20 degree drop or more. I think this is more representative of what a typical canyon driver will see, if not more, since this road is still being driven quite aggressively.
More Typical Canyon Run without Cooler
More Typical Canyon Run WITH Cooler
I hope this helps, please let me know if you have any questions.
Firstly I want to say thanks heaps for doing this write up and going to the effort of getting this data and sharing it with us.
It is very difficult on the street to get an exact comparison I understand that. I think this second example it not super accurate as the example with cooler has a lower coolant temp. If anything the coolant temp with the cooler should be below or at the very least equal to without the cooler.
I think the first example is more beneficial and while it is not a huge difference i think 10 degrees is still a nice drop and you can see without the cooler it keeps rising where the cooler keeps it levelled out.
Harey is offline   Reply With Quote
Old 07-21-2018, 11:24 PM   #45
jflogerzi
jflogerzi's Avatar
One thing to add is if you have a tune you can request to have your rad fans run at lower temps which might help keep things a bit more cooler and and allow for quicker cool downs
Old 07-22-2018, 11:31 AM   #46
majixmatrix
BRZ Wannabee
majixmatrix's Avatar
Drives: 2013 Limited BRZ
What options exist for including a pressure and temperature sensor in-line with this setup? I imagine you can't run a typical sandwhich plate along with the oil cooler?
majixmatrix is offline   Reply With Quote
Old 10-26-2018, 07:18 PM   #47
jflogerzi
jflogerzi's Avatar
One question. I am about to install this cooler along with doing a fresh oil change. Was is needed to burp the coolant... and second does it matter which port under the TB do the hoses go to? Or does it not matter
2013 Series 10 FRS #553
Old 10-26-2018, 08:21 PM   #48
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
If you want to be lazy with the burping:
Cut the tubes to desired lengths
Prefill the tubes & cooler with coolant
Plug both ends for easier installation of cooler to engine,
Plug in the ends of the tubes to respective ports (you can keep the ends of the tubes at equal heights to minimize coolant spill; I suggest you plug in the bottom port in first)
Old 10-26-2018, 08:40 PM   #49
jflogerzi
jflogerzi's Avatar
Thanks for the info. Does it matter which hose goes into which port under throttle? IE one is an inlet and one is an outlet...
Sent from my ONEPLUS A5010 using Tapatalk
Old 10-26-2018, 08:44 PM   #50
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Honestly, I've wondered that too and I tried to find diagrams of coolant flow, no luck.
I've also tried to look for the 14+ Forester and the 15+ WRX coolant flow diagrams (very minimal effort, got lazy) and didn't find anything.
Honestly, I doubt it matters.
The Following User Says Thank You to Bonburner For This Useful Post:
jflogerzi (10-26-2018)
Old 11-11-2018, 10:22 PM   #51
Turdinator
Señor Member
Turdinator's Avatar
Just an FYI for anyone getting this kit, as it is barely mentioned in the original post. The cooler itself has a 3/8" and 1/2" barb while the throttlebody has 5/16" barbs. The hose supplied is 3/8" so it only fits one of the four barbs properly. You can probably make it work but I chose to get some adapters and short lengths of the correct size hose.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Bonburner (11-12-2018)
Old 08-06-2019, 12:22 AM   #52
jacjac3
jacjac3's Avatar
Drives: WRB BRZ
What oil weight did you use for this measurement?
jacjac3 is offline   Reply With Quote
Old 05-17-2020, 03:30 AM   #53
86zn6
Drives: White GTS then Black GTS
Just start to look into this oem cooler, does anyone know the length of the coolant hose? Is 1m enough?
86zn6 is offline   Reply With Quote
Old 05-17-2020, 05:30 AM   #54
mrjj
Drives: GT86 2013
I think hose length is covered by this install video:
mrjj is offline   Reply With Quote
Old 05-17-2020, 08:44 AM   #55
86zn6
Thanks. 24" and 30".
I wonder what degree should the hose be rated? would it go over 100C or 212F since it's just carrying coolant?
Old 05-18-2020, 12:33 PM   #56
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
If you get good brand heater hose, it should be fine. I'd add some sort of thermal sleeve to protect it from the engine block heat.
MS, CSCS, TSAC-F, CPT
Perrin Oil Cooler Kit Installation and Review!!! Sony Engine, Exhaust, Transmission 29 03-27-2017 02:03 PM
Texas Heat Sale- Perrin Oil Cooler 10% Off with Installation! GSpeed Southwest 0 07-30-2015 02:47 PM
Beat the Texas Summer Heat! Perrin Oil Cooler 10% Off with Installation! GSpeed Engine, Exhaust, Bolt-Ons 0 07-30-2015 02:44 PM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
Oil Cooler usability: Changing oil, installation, etc post_break Engine, Exhaust, Transmission 20 06-12-2013 02:36 AM
