Old 04-04-2020, 12:41 PM   #99
spike021
spike021's Avatar
Thanks again @tehShirt!
I can vouch for the quality of the piece. It works super well and is easy to “install” depending on the female piece you need to use.
As far as sound quality, I haven’t attempted to record myself with the mic but I have had phone calls in the car since putting the mic in this adapter and there haven’t been any complaints of people not being able to hear me. I also use Siri a lot for Apple CarPlay and have yet to get an incorrect dictation or command (well, there’s always some degree of error but that’s regardless of using this adapter or not).
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following 3 Users Say Thank You to spike021 For This Useful Post:
Nails (04-06-2020), tehShirt (04-04-2020), vintagemxer (08-31-2020)
Old 04-20-2020, 10:07 PM   #100
Nopower_BRZ
Drives: Stock BRZ
Full Throttle Modifications Throttle Pedal Spacer
Hey guys, I have seen some people asking about throttle pedal spacers and 3D printing them. I have started 3D printing spacers, and they are on sale on Import Image Racing as well for 49.99. If you are interested in purchasing, you can DM me at @Nopower_BRZ and I will hook you up with one for 29.99.
Nopower_BRZ is offline   Reply With Quote
Old 05-01-2020, 07:26 PM   #101
Anthonyc777
Drives: White Toyota 86
Been looking for something like this, figured it would be a cool part for someone to 3D print. What do you guys think?
Anthonyc777 is offline   Reply With Quote
The Following User Says Thank You to Anthonyc777 For This Useful Post:
solidONE (05-24-2020)
Old 05-01-2020, 08:19 PM   #102
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I like my stock shift boot better. Surprised they make filament that looks leathery
Old 05-03-2020, 03:28 PM   #103
iam_ibrahemalbanawi
Drives: i dont own a car but my dream is 86
GT86
Hi im looking for a 3d model of the GT86 i couldn't find one for printing
i found this but its not for printing https://www.thingiverse.com/thing:2496041 but if anyone can
make it printable i will be very thankful
thanks
iam_ibrahemalbanawi is offline   Reply With Quote
Old 05-12-2020, 02:30 PM   #104
adamas
Drives: Toyota Camry
By searching on Pinshape I found this Toyota 86 printable model: https://pinshape.com/items/54871-3d-...6-rocket-bunny hope it could help.
I take the chance to ask for an advice about 3D printing. I need some help choosing my first printer. Already had a look at technical guides (like this one) trying to understand the minimum requirements a printer should have to be considered "decent". However, when it comes to choosing a model or a brand I get confused. I'd like to buy a reliable printer capable of printing at a good resolution (50 microns?) without breaking the bank. My budget is around $500. I can also consider printer kits (as long as they are easy to assemble).
Any recommendations?
adamas is offline   Reply With Quote
Old 05-12-2020, 04:01 PM   #105
RayRay88
Drives: 2017 86 860 Special Edition
At that price you're pretty much limited to the low end of the chinese brands (creality etc.).
By 50 microns do you mean X/Y resolution or Z layer height. Either way you're getting no where close to that. Ideal scenario you're going to get about 4-5 thousandths of an inch accuracy X/Y/Z on most FDM printers, this is going to vary greatly depending on your settings and initial leveling procedures. The only way you're going to get consistent highly repeatable accuracy with minimal work is with full enclosures/heated beds tons of upgraded specs usually reserved for commercial printers. You're going to be hitting the 5k+ range for that.
Hobby level printers are just that. Hobby level. Have fun with them and play around but don't expect too much from them.
RayRay88 is offline   Reply With Quote
Old 05-12-2020, 07:59 PM   #106
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
How deep do you think you are going to get into 3d printing, what are you most interested in printing? High resolution parts, or just DIY simple stuff? The thing with cheaper printers is a lot of times they only use a single stepper motor on the Z axis and so the extruder can get out of plane with the build plate. They also may not have the settings you need for finer adjustment. Also, what is your ability to create 3D models?
Old 05-15-2020, 03:51 PM   #107
reh8388
Drives: 2016 Scion FR-S Release Series 2.0
To me this looks like a simple piece of metal with a bend at the top and maybe one under it at the bottom with 3 holes for gauges. Far cheaper and faster to fabricate it from metal or even a sheet of plastic.
reh8388 is offline   Reply With Quote
Old 05-15-2020, 07:11 PM   #108
Anthonyc777
What I was looking for was more of a 3D printed piece that actually installed in place of the stock cubby or used a similar attachment method vs just a piece of metal that just kind of sat there
Old 05-24-2020, 06:35 PM   #109
Notmichael9
Drives: 2017 Toyota 86
NEW Show about 3D printing car parts!
Hey Ft86!! Check out my new show about 3D printing car parts and installing them on my 2017 86!
My first vid has 3 items
Notmichael9 is offline   Reply With Quote
The Following User Says Thank You to Notmichael9 For This Useful Post:
FRSToyota86 (06-16-2020)
Old 05-25-2020, 10:54 AM   #110
RayRay88
Please stop using PLA on your car. Especially near your brakes. I worry this is going to give you false confidence and you're going to replace a critical part and cause some serious harm.
The Following User Says Thank You to RayRay88 For This Useful Post:
NoHaveMSG (05-25-2020)
Old 05-25-2020, 11:34 AM   #111
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
This. PLA has a glass transition temp of 150F. Your brakes will do double that in normal daily use. ABS will go soft too at ~230F. Just because you can 3D print it doesn’t mean you should.
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post:
NoHaveMSG (05-25-2020), timurrrr (01-12-2021), Wally86 (04-28-2021)
Old 06-05-2020, 12:47 AM   #112
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Would be nice if anyone can make this emblem! I want, I want!
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Official DTM Autobody Services Thread for FT86Club! DTMAUTOBODY Southern California 9 12-31-2013 02:09 PM
Official FT86Club Chatroom? wrxgoose Site Announcements / Questions / Issues 13 09-15-2012 05:26 PM
Official FT86Club decal idea? Hanzo Scion FR-S / Toyota 86 GT86 General Forum 71 06-21-2012 08:09 PM
