Old 09-26-2019, 10:17 AM   #1
Chuckable
Drives: 2017 Toyota 86
Front sway bar links with KW-based coilovers
Figured I’d share my experience in case it helps anyone in the future. Car is 2017 Toyota 86.
While using KW-based coilovers (KW, ST, RCE) the stock end links may or may not be too long depending upon what front sway bar you run.
In my case, I am running a Perrin 22mm front bar. With this setup the stock end links are too long, resulting in slight contact between the sway bar and control arm halfway between full droop and ride height.
I originally tried Whiteline KLC180-195 end links based on recommendations I found on this forum. These end links moved the sway bar from below to above the control arm which avoids any contact issues with the control arm. However, at full compression the sway bar would just barely contact the chassis in this area.
Even when adjusting these beyond what Whiteline recommends I still had very slight contact with the chassis, like just barely touching the paint. Here’s the clearance at ride height.
So, I researched and found that Whiteline KLC180-215 is a longer version. With this setup, I have plenty of adjustment in the link and have gained about 1/2” in clearance to the chassis, which should be all that is needed. Here’s the clearance at ride height.
Here’s a comparison of all 3 end link lengths.
If you run a different front sway bar then this may not be an issue for you. However, I did notice the problem even with a stock front bar.
Chuckable is offline   Reply With Quote
The Following User Says Thank You to Chuckable For This Useful Post:
StraightOuttaCanadaEh (09-26-2019)
Old 10-18-2019, 05:37 PM   #2
steved
Drives: 2013 FRS
@Chuckable how much lower are you than stock? I feel like the ride height plays in here as well when trying to determine which length endlink to buy.
steved is offline   Reply With Quote
Old 10-18-2019, 05:44 PM   #3
Chuckable
Definitely it does. I’m about 1” lower than stock.
Old 10-27-2019, 11:53 PM   #4
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I'm lowered about 1.25" on RCE Tarmac 2's. Which version would be best for me?
smg1138 is offline   Reply With Quote
Old 10-28-2019, 01:54 PM   #5
Chuckable
I hesitate to make a recommendation since I don’t want to be wrong and waste your money, but if you have a Perrin front sway bar then I think the KLC180-215 will work. You won’t have much adjustment in the end link because it will be nearly the right total length.
If you had a stock front bar then I’ve been told that the OEM link will work, but I don’t know if that’s true.
Old 10-28-2019, 03:35 PM   #6
norcalpb
norcalpb's Avatar
I’m wondering if this thread is relayed to the issue I’m hearing. Driving over bumps I’ll hear a clunk sometimes coming from the front crossmember.
I know the Perrin front bar isn’t exactly shaped like the stock one so that could be causing issues, but I also have 1/6 of the crossmember bolts stripped and therefore no bolt is there.
Maybe the extra leverage from the bigger front bar is causing the crossmember brace thing to flex?
Old 10-28-2019, 10:55 PM   #7
Chuckable
Any noise I’ve ever heard in that area was a loose end link, though your thought is certainly just as plausible.
Old 05-11-2020, 07:35 PM   #8
trinidadj
Drives: '16 FRS-MT Ablaze Red
Hey everyone sorry to revive this thread but I'm having the same issue making contact with the lower control arm.
My set up is RCE tarmac 2's with RCE camber plates at -2.4 and I'm using the stock sway bar. I'm lowered about 1.25" maybe a bit more. Do you think the KLC180-215 will help fix that?
Thanks
trinidadj is offline   Reply With Quote
Old 05-11-2020, 07:50 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Thanks
I’m running those with T2’s. No hitting on my hoopty.
trinidadj (05-12-2020)
Old 05-11-2020, 09:52 PM   #10
Chuckable
Trinidadj, responded to your PM.
Old 05-12-2020, 08:41 AM   #11
trinidadj
Thanks Chuckable and NoHaveMSG, I'm going to post a pic of what it currently looks like maybe that can a give a bit more insight.
Old 05-12-2020, 03:46 PM   #12
trinidadj
See link below for pics of my set up
https://drive.google.com/drive/folders/14dPwCDo6IPZhwK5CK_ucM_kpbucLGJBO?usp=sharing
Old 05-12-2020, 04:13 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
An adjustable sway bar link like the Whiteline should take care of it. My setup is very similar, I am running the 22mm Perrin adjustable sway, lowered 1.25 inch from stock, -3.2 camber and mine clears with the whiteline endlink. I had to shorten in most of the way to get it there but it clears by a good amount as you can see from my previous picture.
Old 05-12-2020, 04:38 PM   #14
trinidadj
okay thank you so just to confirm you went with the KLC180-210?
ISO Front sway bar and end links vladniko86 Want-To-Buy Requests 0 05-30-2019 02:59 PM
Front Sway bar end links rick s Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-09-2015 11:33 PM
Need help! coilovers/sway links issue P_say86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 03-19-2015 08:35 PM
WTB: Whiteline Front sway bar Links. Filipino Royale Brakes, Suspension, Chassis 0 08-06-2014 02:46 AM
Stance super sport coilovers with front sway bar end links 900.00 kimchangil424 Brakes, Suspension, Chassis 4 02-06-2013 02:25 AM
