#323 |
Drives: Scion FR-s, xB, iA, Silverado Z71 4
#324 |
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
any new 100k mile club owners ? Anyone report any major issues on there rides, at a certain milage ?
Math is like Love, simple idea at first that quickly gets complicated
#325 |
Drives: manual Toyota 86
mines a 2016 with 24000miles I might hit 100k by 2030.
#326 |
Drives: 2013
I just had a bunch of work done on mine at 93k. Clutch, flywheel, forward and rear struts. What kind of parts are on ebay? I wouldn't buy struts because they could be mine that the dealer or mechanic is selling. Handling was degraded. It was stock suspension.
#327 |
Drives: 2013 Asphalt FR-S
I'm just over 320,000 km which works out to just around 200,000 miles on my 2013 which I bought new just over 7 years ago. Car has been great during this time span, with the following notable maintenance events aside from the routine oil changes, fluid changes, spark plugs etc. All the notes below are km references
Coil pack failure ~150k - got a CEL for one of the coil packs failing, swapped it out and no further failures since Clutch change at 212k - this was mainly a throw out bearing issue, but since I was doing the work for the bearing I decided to replace the entire clutch while at it. Alternator failure at 215k - this was the most notable issue I had with the car, unit just died randomly so had to swap it out. Right rear wheel bearing failure at 300k - wheel was starting to rub, bearing failed and needed to be swapped out. No issues since. Aside from that, the car has been great and quite reliable for year round driving in Canada. The car isn't beaten up on too hard and hasn't been tracked but the daily spirited driving has not caused many issues above and beyond the normal for a car with this many km's thus far. Car has been running with an OFH, OFT Stg 2, Nameless DP, Perrin CB and stock suspension. Hoping to enjoy it for as many km's she will give me....she still puts a smile on my face every time I drive it so I can't really ask for much more |
#328 |
Drives: Subaru BRZ
#329 |
Drives: car
123k here. Car has worn in significantly, daily driven. Had the valve springs, clutch throwout bearing, spark plugs replaced last year and it's running well. Fixing up the wear and tear by stiffening up my mounts and subframe (whiteline) to reduce drivetrain lash. Fuel pump can be a bit noisy when its not in crickets mode. Body and paint is in ok shape for and outdoor kept car in the city.
| The Following User Says Thank You to radroach For This Useful Post: | phm14 (08-10-2020) |
#330 |
Drives: FR-S 10 Series
Had her since Aug 2013, just hit 46,100 miles
Issues: Small leak from cam plate 4/15 (easy fix) Oil + filter changed every 7k miles (dealer only) Battery 11/17 (replaced with AGP type) Four tires 9/18 (stock summer tires) Changed all brakes 4/20 (went w/ OEM brake pads) Changed both driver side gears 4/20 ($2k expensive!) <- dipstick O ring replaced due to this repair Wipers, air filter, and cabin filter changed every other year |
#331 |
#332 |
Yesterday (05/11/2020) was eight years and 165,354 miles which equals 6.6 times around the equator.
Some more details on my owner's log here. It's been a fun eight years, and I have no plans to trade in the car soon, although I have started looking for a potential new DD or at least another to share time with. the 86. Probably not for 12 to 24 months though. Right now this change in direction has my attention.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | DarkSunrise (05-13-2020), phm14 (08-10-2020) |
#333 |
Drives: 2016 Scion FR-S
#334 | |
Drives: FR-S,GTI
That's a change in direction alright. About as big a change as you could make! |
| The Following User Says Thank You to WNDSRFR For This Useful Post: | Dadhawk (05-12-2020) |
#335 | |
I'm definitely going bigger with my next car though since it will probably be our travel car after retirement. Looking at the CT5-V series but there is something about a 600+HP 4WD SUV that makes me smile.
#336 |
Drives: Subaru BRZ
| How many miles on your car? | Sitha@ft86club | Scion FR-S / Toyota 86 GT86 General Forum | 333 | 12-30-2015 05:49 PM |
| 1st 86 400 miles | 75 carrera | Cars for Sale/Trade | 0 | 11-25-2014 05:15 AM |
| 2000 honda civic si 33k miles on body 3k miles with turbo kit | Anthony7515 | Cars for Sale/Trade | 3 | 07-28-2014 09:10 AM |
| 11k miles and I still.... | bdanisi | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 06-19-2013 01:24 PM |
| How many miles are on your BRZ? | Jayde | BRZ First-Gen (2012+) — General Topics | 26 | 11-20-2012 04:10 PM |
