Old 05-10-2020, 02:27 PM   #99
meWant
Drives: '16 BRZ Limited
Originally Posted by why? View Post
When my battery died I went with the most ridiculous overkill I could find because it came with a 5 year warranty.
https://www.batteriesplus.com/produc...cca/sli35agmdp
Ive got the same battery, no issues with it. But agreed that it isnt the most cost effective battery. Definitely been a solid performer for my twin in the almost year or so ive had it
meWant is offline   Reply With Quote
The Following User Says Thank You to meWant For This Useful Post:
why? (05-11-2020)
Old 05-11-2020, 06:58 PM   #100
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Originally Posted by Overdrive View Post
I realize it's not always an option for everyone depending on where you live and having access to electrical power where you park your car, but if I know my car is going to sit for more than a week without being started, I will hook it up to a battery tender just to be safe, especially since I live in a region where winter is an actual thing. Any battery will last you that much longer if you're able to take care of it. Even an Optima has its limits, and they're not the same batteries they were 15 years ago that gave them the reputation they still have.
My factory Panasonic finally got replaced at around 3 years of ownership (the car was effectively 4 years old by build date). I think because it was the dealer's showroom car it sat with a flat battery for most of the year it was there (in hindsight I should have requested that they put a new battery in it when I bought it because they had to jump it in order for me to test drive it) and that took away a lot of lifespan in combination with living through 4 pretty cold winters with me. Had to jump it twice, though one instance was totally my fault. The other was from the car just sitting in the garage but in cooler weather and for long enough that the battery just drained. This past winter it got to where I didn't trust it to crank on too many more below freezing cold mornings. Replaced it about 6 months ago with a nothing-fancy Duralast from AutoZone and it has been flawless. Even let it sit for about two weeks (no ability to put it on a tender where I had to leave it) right after I replaced it, and when I came back to it it started up just as strong as it sitting overnight. Other than that situation I'll still be practicing my maintaining method if the car has to sit longer than a week.
They make little solar charger you can just put on the dash just for that purpose.
My Panasonic was 3 years old last month from the delivery date, I forgot the dome light a few times while at the gym this winter, battery didn't mind, I'm curious to see how long it lasts with the 2017+ charging system. The Panasonic in my old RAV4 I replaced after 12 years, it was still starting the truck below -20C.
The Following User Says Thank You to RZNT4R For This Useful Post:
Overdrive (05-11-2020)
Old 05-11-2020, 08:19 PM   #101
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Made by Northstar, enough said. I'd put Northstar over Odyssey and Odyssey is head and shoulders above Optima.
why? (05-12-2020)
Old 05-11-2020, 10:57 PM   #102
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Didn't know that actually, but I'll have to check it out. Doesn't help me when the car is in the garage, but it spends plenty of time outside when I'm parked at work, so that sounds like something worth looking into, especially if I forget to turn something off before I step away.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 05-12-2020, 03:35 AM   #103
spike021
spike021's Avatar
the best battery for a daily driver is the same one subaru put in from the factory.
Couple days late but I'll have to disagree.
My first battery from factory died within a year of purchasing the car.
Second battery died a few months ago, which was maybe 1.8 years after replacing the first one.
I've switched to some random one that the local Subaru performance shop had on hand, which I'll try until it dies (hopefully not for a few years at least!).
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following User Says Thank You to spike021 For This Useful Post:
why? (05-12-2020)
Old 05-12-2020, 03:41 AM   #104
I'm still on my factory battery. DOM 06/2013
Busybee (05-12-2020), soundman98 (05-12-2020), spike021 (05-12-2020)
Old 05-12-2020, 03:50 AM   #105
spike021
spike021's Avatar
Wasn't it @Tcoat or someone a while back who was theorizing that the BRZs' batteries die quicker because of the keyless entry or something along those lines? Still, < 2 years per battery even for a drain like that is abysmal.
Old 05-12-2020, 04:03 AM   #106
radroach
Drives: car
Pretty funny reading about you guys noticing the difference in weight on your batteries.
Pretty funny. LOL.
Old 05-12-2020, 07:07 AM   #107
RZNT4R
People think winter and deep cold kills batteries, but heat is actually worse. Adding a battery blanket (not heated) may improve the life of your batteries.
Old 05-12-2020, 07:58 AM   #108
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Pretty funny. LOL.
why? There can be a huge difference. Mine is kind of the monster at near 50 pounds. Some of these new lightweight lithium ones are 3 pounds. That is a massive range, far more than most wheels will get.
why? is offline   Reply With Quote
The Following User Says Thank You to why? For This Useful Post:
Bunta93 (05-12-2020)
Old 05-12-2020, 11:30 AM   #109
ogada
Drives: bmw m3
anyone suggest me good battery as my daily usage. my daily usage is pretty heavy
ogada is offline   Reply With Quote
Old 05-12-2020, 10:01 PM   #110
soundman98
ProCrastinationConsultant
soundman98's Avatar
mine's got to be pretty close to that same age.
Old 05-12-2020, 11:55 PM   #111
I have a cell that's been sulfating. @Spuds shamed me, so,
Spuds (05-13-2020)
Old 05-13-2020, 02:01 AM   #112
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Those are very interesting connection points for a charger btw. Very clever. And is that an oil pressure sensor I see down below? I need one of those...
Also
Spuds is online now   Reply With Quote
The Following User Says Thank You to Spuds For This Useful Post:
Ultramaroon (05-13-2020)
New to me daily driver.. 95 M3. Dave-ROR Other Vehicles & General Automotive Discussions 58 07-17-2014 03:05 AM
Is your FR-S your daily driver? Drive Scion FR-S / Toyota 86 GT86 General Forum 136 02-10-2014 10:10 AM
FRS as a Daily Driver? Pake1 Scion FR-S / Toyota 86 GT86 General Forum 104 08-16-2012 12:48 AM
BRZ as daily driver? Pakjk89 BRZ First-Gen (2012+) — General Topics 80 03-22-2012 10:50 AM
The daily driver KiingDavid CANADA 25 02-06-2012 02:14 PM
