Old 05-10-2020, 10:45 PM   #69693
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
So I checked the connector to the backup sensor in the tranny, and checked the fuse, everything looks good and still no backup lights or "R" on the dash. So I guess the sensor is bad?
Sapphireho is offline
Old 05-10-2020, 11:08 PM   #69694
Jump the pins with a wire and look for the reverse lights. That'll confirm it.
Ultramaroon is offline
Old 05-10-2020, 11:18 PM   #69695
I'm issei... in English, I'm first gen Japanese coming to US.
That's called being a naturalized citizen or immigrant. My parents immigrated. I'm first gen. Hungarian. Your kid will be first gen.
Dadhawk (05-11-2020), Spuds (05-11-2020), Tcoat (05-11-2020)
Old 05-10-2020, 11:30 PM   #69696
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Good idea.
Old 05-10-2020, 11:38 PM   #69697
Good idea.
I know.
Old 05-11-2020, 12:16 AM   #69698
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I know.
Yep. Jumped and have backup lights. Man that switch looks hard to get to from under the car.
First toyota/Subaru failure at 5 years 23k miles.
Ultramaroon (05-11-2020)
Old 05-11-2020, 12:40 AM   #69699
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Go super excited as I found some billet toggles that might work for my dash panel project...
Sadly after a half hour of measurements it seems they are about 1/2" too tall to work without covering the HVAC display. I could possibly cut the toggle bases down and then grind, sand and smooth all them but, it is way too much work required when each switch is $90 USD. If all else fails I'll shoot them a message to see about custom work I guess.
The search goes on.
Kiske is offline
Old 05-11-2020, 12:49 AM   #69700
I don't remember just how much I had to remove before I could pull down on the rear extension enough to get at it. I think it was just the flexible coupling between the over and front pipes.
Old 05-11-2020, 12:57 AM   #69701
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Worst backup light switch design ever!
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
soundman98 (05-11-2020), Tcoat (05-11-2020), Ultramaroon (05-11-2020)
Old 05-11-2020, 01:07 AM   #69702
lolol... I just told Mrs. Ultra about the long running worst-design-ever joke to explain my outburst.
Old 05-11-2020, 01:07 AM   #69703
Did you and @Ultramaroon get your oximeters?
If so, how do they work.
I received mine and it works good, shows I usually have from 95 to 98% whatevers.
humfrz is offline
Old 05-11-2020, 01:10 AM   #69704
I know.
humfrz is offline
Old 05-11-2020, 01:11 AM   #69705
humfrz (05-11-2020)
Old 05-11-2020, 01:12 AM   #69706
Yeah. We got ours. It has a neat display. I get about the same whatevers.
humfrz (05-11-2020)
