Old 05-08-2020, 05:22 PM   #1
EASTEUROPID
Drives: 2016 Scion FRS
2016 Scion FR-S CODES
Hello, I just bought a Scion FR-S from an auction about a week ago. It was side swiped on the driver side but the damage is not super bad. It runs and drives. However, I get codes U0100 and P0700. My only idea of what it can be is that somehow the PCM or TCU(it’s an automatic lol) got damaged during the crash or a wire or connector. Anyone else ever have to deal with this? Maybe there is a simpler solution? Thanks
EASTEUROPID is offline   Reply With Quote
The Following User Says Thank You to EASTEUROPID For This Useful Post:
humfrz (05-08-2020)
Old 05-08-2020, 05:46 PM   #2
Originally Posted by EASTEUROPID View Post
Hello, I just bought a Scion FR-S from an auction about a week ago. It was side swiped on the driver side but the damage is not super bad. It runs and drives. However, I get codes U0100 and P0700. My only idea of what it can be is that somehow the PCM got damaged during the crash or a wire or connector. Anyone else ever have to deal with this? Maybe there is a simpler solution? Thanks
Hello EASTEUROPID and welcome to our forum -
Oh, those are a couple of nasty ones that are waaay over my pay grade.
I suggest you google them for some insight.
Hopefully someone will come along with some tips.
Old 05-08-2020, 06:06 PM   #3
extrashaky
Drives: 2014 BRZ Limited
Those are communication codes that can be tripped by a tuner or OBDII code scanner. First thing I'd do is reset the codes and see if they come back.
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
humfrz (05-08-2020), Spuds (05-09-2020)
Old 05-09-2020, 04:22 PM   #4
EASTEUROPID
I got a BlueDriver obd scanner and it won’t let me clear these codes, says they are permanent codes that clear once issue is resolved. The car shifts properly and I don’t see any damage to the TCM or the wiring I checked the wiring harness all the way from the TCM down to the transmission.
So I don’t know what to do. Should I just replace TCM or what.
Old 05-09-2020, 04:25 PM   #5
EASTEUROPID
Thanks for the welcome. I’ve been looking all over google and get general explanations haven’t found anyone with this code on a Scion FRS yet
Old 05-09-2020, 04:35 PM   #6
Well, OK. I'll ring up ol @steve99 to see if he has any suggestions.
Meanwhile, you may try disconnecting the battery for a spell, and see if the codes come back once you fire it back up.
Old 05-10-2020, 04:48 AM   #7
steve99
Drives: FT86
As above you can reset all the car modules by pulling a battery terminal for a few minutes
also as others mentioned tgose codes are a communication error on can buss beterren the engine ecu and fhe auto trans computer
this often happens if fhe engine ecu is reset and bot the auto trans computer
does the auto trans shift correctly if so its likely ok. if it shifts roughly it may be in failsafe mode and have a real problem
The Following 2 Users Say Thank You to steve99 For This Useful Post:
extrashaky (05-11-2020), humfrz (05-10-2020)
Old 05-11-2020, 12:32 AM   #8
extrashaky
You need stronger Google-fu. There aren't many, but it has been reported.
site:ft86club.com "U0100" "P0700"
Might be a few red herrings in there where people have some additional codes you don't.
Old 05-11-2020, 08:23 AM   #9
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
What is the condition of the battery? Both can be triggered by low battery voltage.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
FS: 2016 Scion FR-S SSC Bitters Canada Classifieds 1 08-09-2019 11:08 AM
FS: 2016 Scion FR-S 41,765 senselogic Cars for Sale/Trade 0 01-10-2019 05:22 PM
2013 Scion frs speed sensor/codes loganmarston9696 Engine, Exhaust, Transmission 10 12-29-2018 08:43 PM
2016 SCION FRS NEWS.... 5AD86D Scion FR-S / Toyota 86 GT86 General Forum 339 07-19-2015 05:00 AM
