Old 05-09-2020, 08:05 AM   #253
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by why? View Post
Toyota knows what the aftermarket can do to a car's reputation, and is courting them by making sure what they put out has some reasonable amount of head room.
Do you know whether anyone in the aftermarket world is looking at the GR4? Any early releases to the "great and good"?
Old 05-09-2020, 12:39 PM   #254
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Are you asking if they are giving out inside information to parts suppliers and tuners like they did with the Supra or like Apple does to case manufacturers with new iPhones? I doubt such things would be leaked.
Like I have said before, a next gen could have the same power and displacement, and I would be fine with that. If they put in stronger rods, larger bearings, engine support/girdle, fixed cornering oil/fuel starvation and gave us a stronger transmission, and if the chassis was stiffer and the rear seats were dropped in favor of a better 50/50 distribution then I would be good. I would buy that car 100%. I can tune more power. I just don’t want a 350hp/250tq ceiling before the motor needs to be built or transmission swap needs to happen.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
JD001 (05-09-2020)
Old 05-09-2020, 01:06 PM   #255
JD001
JD001's Avatar
Drives: Subaru BRZ
For homologation purposes certain items will need to match the rally car therefore I presume chassis stiffness, certain engine parts and other bits and pieces will tolerate tweaking.. I can see 300bhp could be attainable and that would be more than enough for a little pocket rocket..
The Following User Says Thank You to JD001 For This Useful Post:
why? (05-09-2020)
Old 05-09-2020, 01:56 PM   #256
Irace86.2.0
I just realized after my rant that I lost track of the thread topic, and I jumped to talking about the next gen 86 lol
Because of the rules, it seems like the car could be overbuilt, so I agree.
https://en.wikipedia.org/wiki/World_Rally_Car
The 1.6 L turbo-charged engine was retained in the 2017 World Rally Car regulations, but the turbo restrictor diameter was increased from 33 mm to 36 mm, increasing the engine's power output from 310 bhp (223.7 kW) to 380 bhp (283.4 kW). Minimum vehicle weight was decreased by 25 kg.
JD001 (05-09-2020)
Old 05-09-2020, 02:11 PM   #257
sato
sato's Avatar
Drives: Dodge Patitas
Originally Posted by Guru Woodman View Post
It seems that the petition to get in to North America is getting traction (+16k signatures)
It is even grabbing some attention on social media. Toyota USA is on Twitter asking about the GR Yaris.
Well, I pitched in!
sato is offline   Reply With Quote
The Following 2 Users Say Thank You to sato For This Useful Post:
Guru Woodman (05-09-2020), why? (05-09-2020)
Old 05-09-2020, 02:20 PM   #258
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Who knows. But if you can get 20 hp out of the twins just changing the header, saying no one will get near 300 out of this engine is silly. I'd be stunned if you leave the engine and turbo stock but add tuning and e 85 you could not hit 300. I'd also be stunned if the engine wasn't totally overbuilt so you didn't have to open it up until some gigantic amount of boost was being pushed through it.
I'm not saying it can hold at some dumb number, but thinking the proper bolt ons and tune cannot get to 300 is silly. That isn't a massive amount extra. Toyota knows what the aftermarket can do to a car's reputation, and is courting them by making sure what they put out has some reasonable amount of head room.
300 bhp (at the crank), I agree, should be possible with some bolt ons and e85.
300 whp I'll bet against, that's almost what the wrc car puts out, someone will try and I bet it blows.
They can't make a profit overbuilding the engine compared to the wrc version. I guarantee it has cheaper pistons and rods and a less aggressive cam, I wouldn't be surprised if the wrc cars have intakes/exhausts sculpted by hand and checked on flow benches while the consumer products will make sacrifices for mass production.
Please show me the +20hp header without a tune, I must have missed that one.
There will be so few of these made that the aftermarket will be weak aside from stuff that can be easily brought over like coilovers due to shared tnga components.
ineedyourdiddly
Old 05-09-2020, 02:53 PM   #259
Guru Woodman
Guru Woodman's Avatar
Drives: 2015 BRZ Sport Tech CWP
Originally Posted by sato View Post
Well, I pitched in!
Too late Sadly not for North America. They decided in all their wisdom to give us the GR Corolla Hatch instead of the Yaris.
I am still hoping that it will come with AWD, but IO am not holding my breath.
Guru Woodman is offline   Reply With Quote
Old 05-09-2020, 03:01 PM   #260
JD001
JD001's Avatar
Drives: Subaru BRZ
The "hot" Corolla will be competing with the Focus ST.. However, if Ford hadn't cancelled the next gen RS then who knows?? You may have got your AWD GR Corolla..
Old 05-09-2020, 03:05 PM   #261
Irace86.2.0
The FA20 puts out 200hp and holds about 350whp before needing internals, which is about double the power. Some have done more, but reliable power is 350whp, which is equal to about 280whp on a 1.6L, except the 1.6L is built for boost and has 268hp. If Toyota is building reliability into that power plant then it should definitely be able to add an extra 50-75whp with E85.
Exotic materials (titanium, magnesium, ceramics and composite) were forbidden except when present in the base model.
https://toyotagazooracing.com/wrc/cars/2020/
https://www.wrc.com/en/championship/...ategories/wrc/
Cylinder block and head based on those in the standard road car.
Modifications allowed to crankshafts, con rods, pistons, cylinder linings, valves and camshafts.
The engine will definitely be reinforced for rally racing, but I'm sure there will be room for power because of the limitations on materials and block/heads. The move to a 3 cylinder is probably to improve flow of air into the cylinder with larger bore sizes, while reducing weight and friction loses. A 4 cylinder could probably be stronger, but I don't see 300whp being a hard number to hit.
Old 05-09-2020, 03:22 PM   #262
strat61caster
You clearly don't know how much low volume precision manufactured parts cost.
I do like the comparison to the FA20 on boost, 280whp with full intake, exhaust, tuning and e85 out of the three banger I could buy into. Time will tell if it needs a different turbo to hit that number and I bet it needs a whole new cooling upgrade to make that power for more than a few minutes. But I'd argue that the FA20 is widely considered to not be a 'lots of Head room' engine.
ineedyourdiddly
Old 05-09-2020, 03:38 PM   #263
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I'm sure big tuner names like HKS and GEeddy will pop out some parts for the GR Yaris and Corolla. It would be nice to see some aftermarket support. Hell TOMS is doing it with the regular Corolla hatchback lol
MS, CSCS, TSAC-F, CPT
Old 05-09-2020, 03:43 PM   #264
strat61caster
The US Focus was canned two years ago. There's no 2019 or 2020 models in the US and so far no inkling of a 2021 model.
ineedyourdiddly
Old 05-09-2020, 06:14 PM   #265
Irace86.2.0
It probably got canned when I lighter and cheaper Civic Type R bested the RS, proving AWD just isn't always better, especially on the street.
That, and the dealer markups destroyed sales.
Old 05-09-2020, 06:18 PM   #266
JD001
JD001's Avatar
Drives: Subaru BRZ
We have tuning houses in the UK turning out RS's with circa 520bhp.. you can't do that with a front wheel drive..
why? (05-09-2020)
Toyota Yaris GR Sport revealed ahead of Paris debut gymratter Other Vehicles & General Automotive Discussions 8 09-16-2018 02:04 PM
Toyota Yaris WRC announced vh_supra26 Other Vehicles & General Automotive Discussions 55 08-12-2017 05:59 AM
My Review of 2011 Toyota Yaris (Loaner Car) danthedirt Other Vehicles & General Automotive Discussions 19 07-13-2012 02:42 PM
2012 Toyota Yaris Dark Other Vehicles & General Automotive Discussions 13 10-10-2010 11:57 AM
