#21827 | |
I tried to ship one and it was going to cost about $150 to send it to Florida. You don't want to know what it was going to cost to send one to eastern Europe! The problem is that it is too rigid to roll or fold so the package is huge. I threw mine in with the FRS when I sold it.
| The Following User Says Thank You to Tcoat For This Useful Post: | squall leonhart (05-07-2020) |
#21828 | |
Sporadic Member
Drives: 2016 Halo FR-S M/T
Stock bracket, stock rotor.
Also, I was stupid and broke the WSS bolt. Anyway to remove the broken bolt without resorting to drilling and retapping? |
#21829 |
Site Moderator
Drives: ichi 86 Project
If you have open nuts, you can tighten to see if really touches the bracket or not. Or you already done that & still touches. Make sure bracket bolts are install correctly.
#21830 |
#21831 | |
Professional Auto Fixer
Drives: 2016 Oceanic FR-S as Designed
Disconnect your battery before welding.
Work Hard. Play Hard.
2016 Oceanic |
#21832 | |
Sporadic Member
I certainly wish I could remove this wheel speed sensor bolt stump.
Are there any bolt extractor tools small enough to reach in? |
#21833 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
They do make small screw extractors. |
#21834 |
The "put a slot in it" trick can be a gamble. The metal near the break is twisted up and weak, so sometimes the bolt material just breaks away. Then your next option is drilling it out, but you just put a slot in the bolt which will make it difficult to keep the drill bit centered.
If you have enough bolt material to flatten it out again in the event the slot trick doesn't work, it's not a big deal. If you're gonna try the slot trick spray repeatedly with PB Blaster and allow plenty of time to soak in to give you the best chance for success. Not WD-40, PB Blaster. It's the best.
2016 Oceanic |
| The Following User Says Thank You to ActionMaxon For This Useful Post: | Spuds (05-07-2020) |
#21835 | |
The Dictater
Drives: '13 Red Scion FRS
#21836 | |
Simply Forgotus
#21837 |
Dimple with center punch before drilling.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | BirdTRD (05-07-2020) |
#21838 | |
Sporadic Member
Gonna take pictures of the broken stud in a bit. |
| The Following User Says Thank You to KR-S For This Useful Post: | Tcoat (05-08-2020) |
#21839 | |
Sittin' Sideways
Drives: 2016 Toyota FR-S
Also, to note before I forget, I didn't get the fancy pants tap-turn relay with all the cool features, I got the very basic one that is just built to eliminate hyperflash and provide a 3-flash tap-turn. Wouldn't mind one that gave me something more like 5 flashes, but it's better than nothing. Also-also, swapping that relay was the most difficult and time consuming part of this entire process, lol. Second hardest I would say was probably dealing with removing the rather stubborn stock side markers. But all worth it.
-O/D
2016 FR-S, Hot Lava |
| Tags |
| :popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
| Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
| If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 10:19 PM |
